Dashboard LED conversion cost chart - no longer available
Goto page Previous  1, 2, 3, 4, 5  Next
pyroay
Donating Member
PostPosted: Wed May 25, 2005 11:43 am    Post subject: Reply with quote
I'll take some and get them up... It may be hard to photograph but i'll see
data_mine
PostPosted: Wed May 25, 2005 12:40 pm    Post subject: Reply with quote
This has got me interested.
nicco
PostPosted: Wed May 25, 2005 10:45 pm    Post subject: Reply with quote
neons in behind, that sounds good...
some quick explaination of how you did it would be greatly appreciated also...
pyroay
Donating Member
PostPosted: Thu May 26, 2005 9:21 am    Post subject: Reply with quote
Ok quick rundown.
Materials List
4 x 100mm mini cold cathode neons (Jaycar) with seperate invertors
- Remove daqsh surround and remove instrument cluster
- Remove all esixting globes from instrument cluster
- Remove needles (speedo, taco, oil pressure etc...)
- Remove the printed gauge background
- You can now see the motor's that drive these needles behind a plastic cover
- Remove the scres and plastic cover
- Place neon's evenly inbetween motors (use bluetak)
- Wrap the invertors in electrical tape (as the back has exposed connections) and use doubble sided tape to hold them to the bottom edge of the cluster, there is plenty of space for upto 6 or maybe 7 starters
- Connect neon's to starters
- Run power and earth out the back of the cluster through the original globe holes
- Place plastic cover on and speedo/taco backing and test for consistency and spread
- Move neons as needed to get a consistant spread then silcone in place
- Re-assemble
All up if you have the parts it should take 30min...
Ryan0001
PostPosted: Tue Jun 14, 2005 5:17 pm    Post subject: Reply with quote
top idea mate,
how bright are they? to they distract you when driving? etc
EFfalconsrule
PostPosted: Tue Jun 21, 2005 1:51 am    Post subject: Reply with quote
nicco wrote:
EFfalconsrule wrote:
Yep cleared it up good. I found out that the LED online shop is actually a 20 min drive from my mums place to so will probably go and check it out.
I am in cairns too, where abouts is that?
They are in Herberton but there shop is in Athertom om the tablelands.
nicco
PostPosted: Thu Jun 23, 2005 11:40 am    Post subject: Reply with quote
Cool, thanks
Bug
PostPosted: Fri Jul 29, 2005 8:58 pm    Post subject: Reply with quote
Something to watch for in really high MCD led's is a s**t narrow viewing angle, which is the last thing you want for dash led's.. always worth comparing to the lower ones.
blue
PostPosted: Tue Sep 13, 2005 4:32 pm    Post subject: Reply with quote
quick question is one of these globes going to be enough for my climate control? Coz in the tech doc it says u need 6 of the ones u make up ur self.
blue
PostPosted: Tue Sep 13, 2005 4:44 pm    Post subject: Reply with quote
when i say one of those globes i mean the LED T5mm wide angle wedge 12V DC from ledshoponline.com. I wonna make my whole dash blue.
bundy_rum
PostPosted: Sun Sep 18, 2005 10:05 pm    Post subject: Reply with quote
Hay all
As soon as i seen the led conversion i had to do it. I wasn't to sure about doing the instrument clustors but did go and do the door handles and climate controll and clock. After the time it took to do i thought u must be able to buy led already coverted to a twist-lock socket base.
i have been doing a bit of looking and australia has nothing so i decided to look oversees as my old man buys lights from the states all the time and they are great. After a quiet a bit of time i have found an LED bulb installed in twist-lock socket base Available with White,Blue,Green,Red and Amber Wide Angle LED. I have jut recieved them and they look like they will go right in, compared it next to an old one i pulled out doing the first mods. Havn't had the chance to put one in and see how bright it is yet but as soon as i do i will post another msg.
They are cheap to. Bought them just as cheep as what you can here but you don't have to do aa thing to them, no soldering resisters and c**p.
Pick of one.
 Description:
 Filesize:  2.02 KB
 Viewed:  1711 Time(s)
blue
PostPosted: Mon Sep 19, 2005 8:17 pm    Post subject: Reply with quote
Cool, if the work tell us how much $ and how to get em.
efgiar
PostPosted: Sat Oct 08, 2005 8:46 am    Post subject: Reply with quote
yeah where to buy! and can you trust the yanks icon_razz.gif jk icon_biggrin.gif
fordzatmyplace
PostPosted: Sat Oct 08, 2005 10:06 am    Post subject: Reply with quote
Hey dudes, a quick question, will the "T10mm wide angle wedge 12V DC" fit in the normal bulb holders behind the ED instrument cluster?
data_mine
PostPosted: Sat Oct 08, 2005 8:17 pm    Post subject: Reply with quote
nope, they're too big. 8mm is about the biggest that'll fit.
fordzatmyplace
PostPosted: Sun Oct 09, 2005 12:00 pm    Post subject: Reply with quote
what ones do you recomend i use then?
bigkev531
PostPosted: Sun Dec 04, 2005 10:03 pm    Post subject: led dash Reply with quote
i did mine for about $30 including climate control and clock
Grumblexr6
PostPosted: Mon Jan 09, 2006 10:59 am    Post subject: Reply with quote
Put the Blue LED lights in other day to mach my ute looks unreal and very happy about it, but 1 drama i didnt know and they had to go in 1 way as for power coz there LED's and guy that sold them didnt let me know about that but im Happy icon_evil.gif
Efxr6
PostPosted: Wed Jan 11, 2006 10:36 pm    Post subject: Reply with quote
i spent $12 on my conversion bout a year ago, got then in packs of2 from autobarn and cost like $2 each
castlegreyskull
View User Gallery (34)
PostPosted: Tue Jan 31, 2006 8:59 am    Post subject: Reply with quote
bringing ot back from the fault....
what size LEDS would u reccommend to put in a NL fairlane..??
going to atttempt it shortly, and wanna go order all the parts..
Page 3 of 5
[50 queries :: 0.08217 seconds ]
