fordman Fordmods Newbie
Age:21 Posts: 5 Joined: 21 Nov 2004 Location: Perth WA, Australia
Posted: Tue Dec 07, 2004 3:47 pm Post subject: Disable boot release button |
How would i go about disabling the boot release button, unless the key is in the ignition? I have an EB, and theives can just smash the drivers side window and open the boot (which happened to me)
Has anyone managed to disable this button? |
Dellboy999 Fordmods - Getting Side Ways
Age:37 Posts: 1036 Joined: 05 Nov 2004 Location: Melbourne VIC, Australia
Posted: Tue Dec 07, 2004 4:00 pm Post subject: |
Just re-route the power via the ignition seems a bit stupid as it is only useful with the ignitoin off.
But i like your thinking none the less, might route mine via the alarm, but as the rear seat folds down why bother, the less damage the better, they break in, they take what the y want leave the car, i will live. |
Age:21 Posts: 2417 Joined: 05 Nov 2004 Location: Manjimup WA, Australia
Posted: Tue Dec 07, 2004 4:36 pm Post subject: |
| if you have a keyfob with release, id just remove it all together, but ive got very little ausio gear in the rear at the moment, so it isnt worrying me. |
Posted: Tue Dec 07, 2004 4:55 pm Post subject: |
| Andrew J wrote: | | if you have a keyfob with release, id just remove it all together, but ive got very little ausio gear in the rear at the moment, so it isnt worrying me. |
nah my key fob dont have boot release on it. I might investigate what outputs my alarm has for this sort of thing. The alarm is fairly basic so i dont know if i'll have any luck |
Vic Cruise Moderator
Posts: 5560 Joined: 05 Nov 2004 Location: Melbourne VIC, Australia
Posted: Tue Dec 07, 2004 5:25 pm Post subject: |
Piss easy fellas.
Do what the trusty XF had built in - have a switch fitted inside the boot lid that is in series with the boot release circuit. JUst turn it off and then you can only open the bootlid with the key.
Mind you that won't help if the car thieves just pull down your backseats and crawl in or grab what they can but better than nothing! |
Vibrate Fordmods Tyre Shredder
Age:24 Posts: 384 Joined: 08 Nov 2004 Location: Narre Warren VIC, Australia
Posted: Tue Dec 07, 2004 10:14 pm Post subject: |
| you could try disconnecting it and relocating the button somewhere else? |
Age:23 Posts: 2339 Joined: 07 Nov 2004 Location: Perth WA, Australia
Posted: Tue Dec 07, 2004 10:42 pm Post subject: |
did the high series BEM's in ED's do that?
i know EF onwards the high series BEM's turned off the switch a minute after the key was taken out |
Aaron_EF8 Fordmods Stock as a Rock
Age:25 Posts: 133 Joined: 05 Nov 2004 Location: Adelaide, SA SA, Australia
Posted: Sun Dec 12, 2004 2:04 pm Post subject: |
| Quote: | | i know EF onwards the high series BEM's turned off the switch a minute after the key was taken out |
My EF S1 doesn't do that, its on EL's though, and may be on EF S2's.
I have disconnected the boot key, as I haven't used it once in 2 years, and it stops people from smashing the bootlock in, and making off with my stereo gear. |
Age:22 Posts: 2012 Joined: 05 Nov 2004 Location: Penrith NSW, Australia
Posted: Sun Dec 12, 2004 3:02 pm Post subject: |
| ELs leave it on for 10 minutes, quite handy I reckon.. |
comhelp Fordmods Tyre Shredder
Age:25 Posts: 391 Joined: 06 Nov 2004 Location: Melbourne VIC, Australia
Posted: Sun Dec 12, 2004 10:34 pm Post subject: |
Does anyone know if this can be done to the EFS1? or if it is just a simple NO connection? u see i COULD do this to mine as my car is on LPG so they cant climb through the back seats  |
Leszek Fordmods - Getting Side Ways
Posts: 881 Joined: 05 Nov 2004 Location: Menai NSW, Australia
Posted: Mon Dec 13, 2004 7:50 pm Post subject: |
must be only EFs1
my EF disables the boot relase after awhile not sure how long though |
View User Gallery (33)
Posted: Mon Dec 13, 2004 8:06 pm Post subject: |
| hmm if they want the stuff in ure car they will find away to take it, if the cant open the boot they will try prying it open with a crow bar or something, some window tints now are supposed to make the glass shatter proof that may help. |
kday Technical Contributor
Age:22 Posts: 40 Joined: 05 Nov 2004 Location: Kalgoorlie WA, Australia
Posted: Wed Dec 15, 2004 1:29 pm Post subject: |
that explains alot
i always thought my boot button was f**k since it only worked when the car was running.....
never occured to me why.... |
LG Fordmods - Getting Side Ways
Age:23 Posts: 647 Joined: 05 Nov 2004 Location: Melbourne VIC, Australia
Posted: Wed Dec 15, 2004 1:34 pm Post subject: |
| kday wrote: | that explains alot
lol |
