| Are you interested in a Plug and Play ECU |
| I would like a plug and play Package. |
75% |
[ 18 ] |
| I would like the parts to build my own. |
25% |
[ 6 ] |
| Total Votes : 24 |
devojet Fordmods Oompa Loompa
Age:30 Posts: 27 Joined: 21 Apr 2008 Location: Gold Coast QLD, Australia
Posted: Fri May 02, 2008 1:14 pm Post subject: E seires Plug and Play ECU. |
I am currently researching the market for a plug and play ecu for e series falcons starting with one for EF falcons. The system will be based on a megasquirt and I plan to supply a complete plug and play package.
The package would consist of the assembled and modified megasquirt 2, tuning software, base tune, an adaptor loom and any other required sensors or components.
I currently have a prototype fitted to an EF I6, so this will be the first avaliable version. With this set up the factory ECU is left in place so none of the factory features are lost. The Megasquirt will control fuel and spark and will also have some spare outputs for things like boost control, water injection, shift lights, etc.
I will also consider selling the loom parts as well for those who want to go it alone and assemble there own megasquirt.
Please let me know if this is something you think you might be interested in.
Regards
Daniel. |
xr8ute Fordmods - Getting Side Ways
Age:28 Posts: 647 Joined: 02 Dec 2004 Location: Wollongong NSW, Australia
Posted: Fri May 02, 2008 3:51 pm Post subject: |
| I thought this sort of thing was already available? Are you talking about something like this, http://megaefi.com/ ...? |
Age:21 Posts: 2327 Joined: 08 Nov 2004 Location: Townsville/Cairns QLD, Australia
Posted: Fri May 02, 2008 4:01 pm Post subject: |
| justfordima did this a few years ago. using megasquirt too |
1965tbird Fordmods Stock as a Rock
Age:20 Posts: 123 Joined: 20 Jul 2007 Location: Melbourne VIC, Australia
Posted: Fri May 02, 2008 7:28 pm Post subject: |
Yeah for sure i think this would be a goodidea especially for someone like me who has no clue about resistors and stuff. if its a plug and play thing then ill ask how soon can you have it ready lol. the only reason is becaseu i have an auto so all i really need is a piggy back system no point spending a couple of grand on a system that will be held back by standard ECU.
pm me if your up for it.
cheers |
Posted: Fri May 02, 2008 9:44 pm Post subject: |
Thanks for the feed back. The adaptor sold by megaefi is for an EECIV but an EF runs a EECV. I believe he is working on an EECV but it still doesn't allow for the factory ECU to remain in place. I have also read that there are a few differences between the american EECV and the Australian EECV. I looked into it when I first looked at doing mine.
I haven't been able to find any posts buy justfordima about plug and play Megasquirts.
Once I sort the details out I could probably make adaptor harnesses for any after market ECU. But for now I'm concentrating on megasquirts.
Daniel. |
Posted: Fri May 02, 2008 11:09 pm Post subject: |
he called them the dimasquirts, should be able to find something on it. I'll try and hav a look for you
i'm not trying to shut down your idea btw.  |
Posted: Fri May 02, 2008 11:16 pm Post subject: |
Yeah I remember reading about Dimasquirts, but it apears they no longer exist?
Thanks
Daniel. |
mitchg911
Age:22 Posts: 872 Joined: 06 Nov 2004 Location: Sydney NSW, Australia
Posted: Fri May 02, 2008 11:58 pm Post subject: |
| you'll find all the megasquirt/dimasquirt threads and posts were in the RPD forum, which has since been removed... |
stoj79 Fordmods - Smokin em up
Age:29 Posts: 217 Joined: 24 Jul 2006 Location: Taylors Hill VIC, Australia
Posted: Thu May 22, 2008 12:56 am Post subject: |
| will this system also work with the el's or there a different kettle of fish |
Posted: Thu May 22, 2008 8:16 am Post subject: |
I beleive EL is different. I would have to look at an EL to see what the differances are.
I paln to start with EF as that is what I have and then move on to the other models.
Daniel |
glenneaux Fordmods - Getting Side Ways
Age:21 Posts: 1213 Joined: 05 Apr 2005 Location: Hawthorn VIC, Australia
Posted: Wed May 28, 2008 1:42 pm Post subject: |
The EF is like the worst car to start with.. what you'll be doing is specific to EF...
EA-ED / EL will work with the same megasquirt setup. the only difference being that it has to control the BBM and 2 fan signals.... however a boxcar will give no F**k for that and seeing as those outputs are already being brought out to the socket it makes it easy to wire up to it in a boxcar and then reconfig for other functions...
yes i have an ms2 in an eec-iv case in my EB with EL motor. |
Posted: Wed May 28, 2008 1:55 pm Post subject: |
| Yeah I know the EF is the odd one out of the E series and is probably the more difficult to Megasquirt as it runs coil packs. But I own an EF and I'm running MS2 on it. After I installed my MS2 I thought the way I did it would be easy for others to do if I made up the adaptor looms. That's why I'm trying to get a idea of the market size. |
Posts: 1948 Joined: 27 Dec 2004 Location: melbourne, sunshine VIC, Australia
Posted: Wed May 28, 2008 8:05 pm Post subject: |
| I would be interested but mostly for ED and EL not so much EF |
Age:21 Posts: 2601 Joined: 06 Nov 2004 Location: Sydney NSW, Australia
Posted: Thu Jun 19, 2008 4:27 pm Post subject: |
plug and play MS2 for the EF is a challenge indeed. You must remember that the MS2 only has the ability to drive 1 ignition output, requiring a module to switch between the coils (FORD did this with an EDIS module, but this is only external on american cars, and an internal module on the australian ecus).
The easiest route is to change over to a dizzy setup (which is what we did) on EFs. A small price to pay considering the gains.
However a true plug and play system will have to incorporate 3 ignition outputs, with a driver for each one (I guess the standard VB921 would do, or an equivalent of), and then code to work out timing, and the triggering. Last time I checked all this was missing from the MS2.
EA/EB/ED/EL are chronoligcally easy to hard. With the EL including a digital link (DOL), communicating dash variables amongst all sorts of other interesting data.
I guess the only other problem you might face is getting the connected (desoldering them from ECUs becomes a tedious task to say the least).
And after all that, it's really good to have an ECU that you can just install and uninstall just as easily.
Good Luck!
justfordima |
HiBoost Fordmods Stock as a Rock
Age:21 Posts: 172 Joined: 02 Jun 2005 Location: melbourn VIC, Australia
Posted: Thu Jun 19, 2008 7:39 pm Post subject: |
| would u guys be interested in a MoTeC plug and play? |
Posted: Thu Jun 19, 2008 8:00 pm Post subject: |
Hi Justfordima,
I already have a prototype working on my EF fairmont turbo. Have a look for my thread in the forced induction section.
I have modified the MS so it has 3 ignition drivers and uses the MS2extra firmware (www.msextra.com). My set up leaves the factory ECU in place to control everything except the engine (Auto, gauges, fans, fuel pump etc).
I just need to sort out a few more details with my car and organise some parts suppliers before I can start producing the kits.
Daniel. |
newby Fordmods Stock as a Rock
Age:33 Posts: 115 Joined: 12 Jun 2006 Location: LA LA LAND VIC, Australia
Posted: Tue Jun 24, 2008 6:27 pm Post subject: |
Very interested in what you have going.
Any idea of possible $$$ and if the transmission being auot would be an issue? |
Posted: Tue Jun 24, 2008 9:44 pm Post subject: |
The auto transmission is no problem as the factory ECU is left in place to control it. My EF with the prototype is auto.
Not sure about $$ as I'm still organising suppliers, but I'm aiming for less than $1k for the complete kit. |
