Age:22 Posts: 10141 Joined: 15 Nov 2004 Location: Hobart TAS, Australia
Posted: Thu Jun 26, 2008 8:38 am Post subject: E-Series firewall reinformenet for manuals |
| I'm sure this has been covered a zillion times, but I can't find a sticky, and the search is just being useless. Anyone know of a doco or thread or anything with details on this? |
TROYMAN Technical Contributor
Age:34 Posts: 2650 Joined: 07 Nov 2004 Location: South Western Sydney NSW, Australia
View User Gallery (29)
Posted: Thu Jun 26, 2008 8:41 am Post subject: |
i made a tech doco and submitted it to happy a few months ago but it hasnt be put up yet..
ill post up the info for you.. |
PIMP_LTD Fordmods - Getting Side Ways
Age:22 Posts: 775 Joined: 25 Apr 2008 Location: Brisbane QLD, Australia
Posted: Thu Jun 26, 2008 12:30 pm Post subject: |
Great write up troyman.
I had to do this recently, and as an alternative, i welded mine. Only because i didn't think of bolting it.  |
OsbornThomas Fordmods Tyre Shredder
Age:20 Posts: 322 Joined: 02 Jul 2007 Location: Central Coast NSW, Australia
Posted: Thu Jun 26, 2008 4:43 pm Post subject: |
| haha i sent my car away when the clutch cable snapped and they ended up doing this, score, but now the cable is sitting on the extractors. |
stalker Fordmods Tyre Shredder
Age:20 Posts: 386 Joined: 15 Feb 2008 Location: adelaide SA, Australia
Posted: Thu Jun 26, 2008 4:51 pm Post subject: |
| just out of interest what are the benefits of doing this? i got a manual ED fairmont, im fairly sure its firewall hasnt been reinforced. how worth wild is it to do? |
Posted: Thu Jun 26, 2008 4:56 pm Post subject: |
The factory clutch cable bezel cracks around where its welded to the firewall. Eventially your cable will break through the firewall and you'll have no clutch.
Its a pretty simple fix, and worthwhile doing before it breals if you can.
Andrew. |
Posted: Thu Jun 26, 2008 4:58 pm Post subject: |
| hmm sounds bad, though ive lost my clutch befor and still got home.... |
Posted: Thu Jun 26, 2008 5:17 pm Post subject: |
It's good fun ay, you're better off re-enforcing it before you need to fork out more money for other things that can go wrong.
btw I swear my cable used to never touch the extractors? |
Whiteknight1 Fordmods - Getting Side Ways
Age:20 Posts: 559 Joined: 16 Apr 2006 Location: Sydney NSW, Australia
Posted: Thu Jun 26, 2008 5:53 pm Post subject: |
Mine's a good 5 cm or so away from my extractors, you sure its running the same route as it was before?
Might be able to get a photo of where mine runs if I can find the camera. |
Posted: Thu Jun 26, 2008 6:14 pm Post subject: |
oh mate that would be tits if you could.
Coast mechanics can suck my d**k as far as I'm concerned, you try to tell them something and they treat you like you have no idea.
I've told mechanics many times what is wrong and they dismiss it straight away, the fact is i don't have the time or patience to do a lot of the engine work on my car, so i will keep getting f**k around. |
Posted: Thu Jun 26, 2008 6:24 pm Post subject: |
thats why i made the doco.
mine had also cracked and had been welded before i got the car.
but it then cracked again right next to where it was welded (due to a s**t clutch cable)and got that bad the pipe had been pulled right through the firewall and cracked the pedal box..doh.
so this plate will never crack and has a large surface area to prevent any more cracking..
especially if you have a hd clutch...
now if you havnt re-enforced the pedal box that might be something to also look at...
and my clutch cable sits about 10cm away from the extractors. but i guess it might depend on the brand of the extractors |
Posted: Thu Jun 26, 2008 6:29 pm Post subject: |
nah you see mine has an aftermarket plate fitted.
What has happened is they've installed the clutch cable not giving a f**k and it's not sitting where it should be, i can pull the cable out from under the block and it will sit out for about 5 pumps of the clutch then it's straight back under the block.
I've heard there are brackets the clutch is meant to lock into?
There needs to be more T5 owners on the coast. |
Posted: Thu Jun 26, 2008 6:31 pm Post subject: |
| Theres saddles for the clutch cable, by memory, one is behind the block, another right infront of the clutch fork. Mine was rubbing down on the engine mount, but a bit of plastic tube kept it from rubbing away. |
Posted: Thu Jun 26, 2008 6:33 pm Post subject: |
| my cable runs behind the drivers side engine mount then down under the sump and is cable tied with the battery cable onto the k frame.. |
nightstalker Fordmods - Smokin em up
Age:42 Posts: 287 Joined: 27 Jan 2005 Location: Bathurst NSW, Australia
Posted: Mon Jun 30, 2008 1:42 pm Post subject: |
Just discovered why my clutch is playing up...bloody firewall is cracked around where the clutch cable goes in.. As i dont have the tools or material would someone be able to make up that reinforcement piece like in TROYMANs doco, I will of course pay for materials your time and postage.
Thanks.
PS need asap... |
Posted: Mon Jun 30, 2008 5:26 pm Post subject: |
| nightstalker wrote: | Just discovered why my clutch is playing up...bloody firewall is cracked around where the clutch cable goes in.. As i dont have the tools or material would someone be able to make up that reinforcement piece like in TROYMANs doco, I will of course pay for materials your time and postage.
Thanks.
PS need asap... |
If anyones interested in making them, I'm also keen to purchase one... |
Posted: Mon Jun 30, 2008 7:06 pm Post subject: |
| yea im in the same vote, would be interested in buying one. |
Posted: Mon Jun 30, 2008 7:14 pm Post subject: |
ok..
i might get some prices in the sheet metal,cutting disks,welding rods ect.
and see if i can make up some...?
ill get bact to you after i find out how much the materials will cost. |
