Posts: 1475 Joined: 30 Apr 2006 Location: Melbourne VIC, Australia
Posted: Tue May 13, 2008 10:25 pm Post subject: EA clutch into EB2? |
Hi All,
Just wondering if an EA clutch can be used in an EB2? I have a new Exedy clutch for an EA, and was hoping I could use it in my EB2.
Appreciate any advice!
Thanks,
Justin. |
FLASH Fordmods - Smokin em up
Age:28 Posts: 264 Joined: 05 Mar 2006 Location: sydney NSW, Australia
Posted: Tue May 13, 2008 10:56 pm Post subject: |
as long as your eb has a 3 bolt clutch then your ok. (i think they do) i did a t5 convertion or my EBII and got rid of the EA clutch that it came with a went for the bigger EL xr6 6 bolt unit. (its now turbo). but the ea ones stod the test of time no worries.
On another note if you want two spare i have one stock EA clucth with heaps of meat and another Excedy h/d that has plenty of k's left in her. Both are to suit EA. |
Posted: Tue May 13, 2008 10:58 pm Post subject: |
| FLASH wrote: | as long as your eb has a 3 bolt clutch then your ok. (i think they do) i did a t5 convertion or my EBII and got rid of the EA clutch that it came with a went for the bigger EL xr6 6 bolt unit. (its now turbo). but the ea ones stod the test of time no worries.
The one I have is an Exedy Heavy Duty for an EA - it's brand new. |
Damo Fordmods - Getting Side Ways
Age:24 Posts: 1012 Joined: 25 Apr 2005 Location: Melbourne VIC, Australia
Posted: Tue May 13, 2008 11:12 pm Post subject: |
I think what flash meant was if your car has an EA-EB1 flywheel it will bolt up fine.
So yes it will bolt up to an EA-EB1 flywheel. If it's going into your EB2 than I think you would be much better off getting a clutch to suit(you'd have to put an EA flywheel to use the clutch anyway). The EB2 clutches are larger and have a 6 bolt pressure plate with 3 dowels, as apposed to the EA one you have which would have 3 mounting points and no dowels and smaller clutch plate.
Having said this Sundeep on e-series forums has been using my old t5 for quite some time with an EA Flywheel and 3 bolt Excedy standard clutch with no dramas (2nd gear clutch dumps) etc. |
Posted: Tue May 13, 2008 11:19 pm Post subject: |
| Damo wrote: | I think what flash meant was if your car has an EA-EB1 flywheel it will bolt up fine.
Thanks Damo, now I get it!! Just had a look at the clutch itself, and all makes sense! Sorry Flash, didn't quite understand what you meant earlier.
Yep, going into my EB2 - I knew I'd read somewhere they were different from EA-EB1 but wasn't quite sure how.
Stuff going backwards, I'll sell it and grab something more suitable. |
[32 queries :: 0.03419 seconds ]
