EA ON GAS
ragga_ed
PostPosted: Wed May 21, 2008 9:37 am    Post subject: EA ON GAS Reply with quote
hey all,
iv got an ea sitting out the front of my house, it hasnt been driving or started for about 6months, gonna try get it started today. is there anything im gonna have to do for the gas? some people already told me it mite be frozen? is this true and if so what should i do?
i dont know much about lpg lol, as you can probably tell
ragga_ed
PostPosted: Wed May 21, 2008 5:08 pm    Post subject: Reply with quote
i just changed leads and plugs and battery, the car wont turn over, shes trying to, but every time it gets close its just backfiring really bad. i dont wanna keep pushing it and blow something.
the car never use to run on petrol, so i dont wanna try starting it on petrol, cause it could cause problems.
i know if i did get it started on petrol it would warm the moter and hopefully un freeze the gas.
what do you all reckon i should do? or what else could it be?
any answers at the moment would be a big help, cause i dont got a clue
Rick's EF Fairmont Wagon
PostPosted: Wed May 21, 2008 8:06 pm    Post subject: Reply with quote
I generally start on petrol until it warms up
Punnisher_42
PostPosted: Wed May 21, 2008 8:41 pm    Post subject: Reply with quote
if it's not "turning over" then is can't possible be " backfiring"
please explain what it is doing better.
ragga_ed
PostPosted: Wed May 21, 2008 9:54 pm    Post subject: Reply with quote
man if its not backfiring, then i dont no what the hell it is
it almost kicks over then BANG.
gogetta
PostPosted: Wed May 21, 2008 10:40 pm    Post subject: Reply with quote
ring one of those guys that comes and picks up old bombs....
ragga_ed
PostPosted: Thu May 22, 2008 11:18 am    Post subject: Reply with quote
lol thats what i thought
ragga_ed
PostPosted: Thu May 22, 2008 11:27 am    Post subject: Reply with quote
i really dont wanna get rid of it like that, the body is in good condition and the engines only done 50000, with a little bit of work i reckon i can get it running
PostPosted: Thu May 22, 2008 7:56 pm    Post subject: Reply with quote
auto or manual?
if manual then tow start.
did it used to run?
I think you may have a stuck valve or something similar.. rusty bores? valve seats?
ragga_ed
PostPosted: Thu May 22, 2008 8:47 pm    Post subject: Reply with quote
yeah its an auto, yeh it use to run
ill keep playing with it
elf100capri
View User Gallery (17)
PostPosted: Thu May 22, 2008 11:46 pm    Post subject: Reply with quote
sounds like the leads are on wrong somewhere
ragga_ed
PostPosted: Fri May 23, 2008 11:40 am    Post subject: Reply with quote
i think your right, because now there is no power at all. ill double check every thing. see if everything is on properly
Punnisher_42
PostPosted: Fri May 23, 2008 5:35 pm    Post subject: Reply with quote
shove a s**t on the harmonic balancer and see if the motor will actually rotate. this all sounds really wierd.
ragga_ed
PostPosted: Sun May 25, 2008 4:36 pm    Post subject: Reply with quote
just blown the air box to peices lol
ghia97
PostPosted: Sun May 25, 2008 5:21 pm    Post subject: EA start Reply with quote
Leads are definatly on wrong then. You should of left the old ones on till you ran it first. Large backfire on startup is usually due to too much gas and then ignition =BANG!. Once you sort leads check oil and coolant levels then drive it easy for first few kms and be easy on brakes to wipe rust off then you should be all good>
[42 queries :: 0.03809 seconds ]
