Earth
bgamble
PostPosted: Fri Jun 27, 2008 6:14 pm    Post subject: Earth Reply with quote
Does any one know of a good earthing point in the boot area of an ef/el fairmont?
Krytox
PostPosted: Fri Jun 27, 2008 6:35 pm    Post subject: Reply with quote
You'll be making it, so pick a spot with some solid steel.
pref chassis rail.
wild_ef
PostPosted: Fri Jun 27, 2008 7:36 pm    Post subject: Reply with quote
think mines just underneath the parcel tray on the chassis, do it wherever it doesnt matter just make it close to the amp or watever it is, and get a good connection
phongus
PostPosted: Fri Jun 27, 2008 8:53 pm    Post subject: Reply with quote
Mine is under the parcel shelf. I used the factory sub mounting holes as my earth...after I sanded the paint off. Used a nut and bolt to hold the earth lugs into place.
phong =P~
outlawxr6
PostPosted: Sat Jun 28, 2008 11:33 am    Post subject: Reply with quote
Technically there is no such thing as an earth in a dc system it is a ground. To acheive a good solid ground find some metal work where you can get to both sides of and clean all the paint and undercoat off till it is shiny metal, bolt your terminal on and then coat the whole area with a good sealant to prevent rust and moisture ingress.
Don't bother with the old wives tail of making it as close as possible make sure it is a solid ground and use appropriate size cable and you will be fine....
[32 queries :: 0.03249 seconds ]
