2446terry Fordmods Newbie
Posts: 3 Joined: 10 May 2008 Location: wauchope NSW, Australia
Posted: Sat May 10, 2008 3:10 pm Post subject: EB CLUSTERS |
hi just wondering if any body can help me with an answer i have eb 11 gli
an i have updated the cluster to the fairmont cluster now thiers a problem with the fairmont trip not working. can i swap the gli trip which works fine , with the fairmont cluster, will the be any problems with the speedo( will it read true speed ) |
PIMP_LTD Fordmods - Smokin em up
Age:22 Posts: 222 Joined: 25 Apr 2008 Location: Brisbane QLD, Australia
Posted: Sat May 10, 2008 3:18 pm Post subject: |
Do you mean just the little trip dial under the speedo? If so, its just a plastic type cog in the speedo that wears out. just swap in the GLI one and it'll be fine.
I'm 99% sure its the same part between them.
Andrew. |
Posted: Sat May 10, 2008 3:55 pm Post subject: EB CLUSTER |
| COULD I JUST SWAP THE SPEED & THE TRIP FROM THE GLI TO THE FAIRMONT CLUSTER AN WILL THE SPEEDO RUN JUST A IF IT WAS IN THE GLI CLUSTER ( THE SPEED ON THE SPEEDO SHOULD RUN THE SAME) |
Posted: Sat May 10, 2008 4:47 pm Post subject: |
you should be able to put the whole speedo unit in, but i'm not entirely sure if the screws that hold it are the same, but with both clusters out, you can just double check.
The speed will be the same.
Andrew. |
Posted: Sat May 10, 2008 10:52 pm Post subject: EB CLUSTER |
YEAH THANX ANDREW ,I ALL READY DONE THAT EVERY THING IS THE SAME AN FITS STRAIGHT IN. JUST ASKING BECAUSE IT SEEMS/ FEELS THAT I`M TRAVERLING SLOWER THAN THE SPEEDO IS READING.
TERRY |
EBIIexpress Fordmods Oompa Loompa
Posts: 41 Joined: 01 Sep 2007 Location: Perth WA, Australia
Posted: Tue May 13, 2008 7:42 pm Post subject: |
| Thankyou for the info guys as I have exactly the same problem with my EBII ( EB Fairmont cluster installed ). |
