ncguy24 Fordmods Oompa Loompa
Age:24 Posts: 21 Joined: 08 May 2008 Location: sunbury VIC, Australia
Posted: Sat May 10, 2008 2:46 am Post subject: eb gt wheel on nc ghia |
can anyone help . i want to put a eb gt steering wheel in my nc ghia is it a big job?? and do the cruise buttons conect the same way??  |
Steady ED Fordmods Addict
Age:22 Posts: 6627 Joined: 01 Jun 2005 Location: Melbourne VIC, Australia
Posted: Sat May 10, 2008 7:19 am Post subject: |
Nah not a big job.
Get the horn pad off, disconnect cruise and horn wires, taking note of where they went!!!, undo the big nut in the middle, yank the wheel off, new wheel on, connect wires to horn and cruise buttons, tighten bolt, horn pad back on and done
All connects the same way, as long the GT steering wheel has the boss on the back of it.
Is this a woodgrain one off ebay by any chance? |
lil_lincoln Fordmods Tyre Shredder
Age:17 Posts: 325 Joined: 10 May 2007 Location: Melbourne VIC, Australia
Posted: Sat May 10, 2008 10:19 am Post subject: |
| invest in some steering wheel pullers,it came off in 2 seconds rather then yanking on it. |
BuNtEr Technical Contributor
Age:41 Posts: 3228 Joined: 12 Feb 2007 Location: your mums NSW, Australia
Posted: Sat May 10, 2008 10:52 am Post subject: |
use a rubber hammer when you take the horn pad off undo the nut up to the top, put your knees under the wheel and put some presure on it hit with rubber hammer and it will pop off its that easy,
even if you use the end of a hammer the wooden handle to hit it and it will come off. |
xfman1986 Fordmods Stock as a Rock
Posts: 125 Joined: 02 Dec 2007 Location: bellbrook NSW, Australia
Posted: Sat May 10, 2008 11:58 am Post subject: |
| NOTE...LEAVE NUT ON TILL WHEEL COMES LOOSE...what i mean is half undo the nut bang the wheel to loosen it and then take the nut all the way off and remove wheel. |
Posted: Sat May 10, 2008 12:09 pm Post subject: |
cool. thanks guys. |
EBIIexpress Fordmods Oompa Loompa
Posts: 41 Joined: 01 Sep 2007 Location: Perth WA, Australia
Posted: Tue May 13, 2008 7:47 pm Post subject: |
| Make sure you line up any alignment marks on the inside of the steering wheel with the mark on the steering shaft. This will make sure that the indicators self cancel going around corners, something I found out when I replaced my EBII standard wheel recently with an aftermarket wheel. |
