falcon_3512003 Fordmods - Smokin em up
Age:36 Posts: 236 Joined: 28 Nov 2006 Location: se melbourne VIC, Australia
Posted: Mon Sep 03, 2007 7:12 am Post subject: |
| ok thanks for that |
EF-MattyB Fordmods - Smokin em up
Age:19 Posts: 227 Joined: 04 May 2007 Location: Noosa QLD, Australia
Posted: Mon Sep 03, 2007 9:31 am Post subject: dec 94 ef gli auto |
hey wil an ecu with the code 4BDG work with my car???? other info
94DA-12A650-BG
thanks guys |
Posted: Tue Sep 04, 2007 9:09 am Post subject: |
| can someone tell me what is a 4TFC its not on the list and i can get one but need to know what it is and will it go into my 94 gli auto need to know this one fast thanks in advance |
Posts: 2956 Joined: 08 May 2007 Location: Sunny QLD, Australia
Posted: Tue Sep 04, 2007 9:19 am Post subject: |
Looks like an EF Tickford auto ecu going by the other codes.
Not sure if it'll mess with the shift points in the auto |
Age:31 Posts: 944 Joined: 23 Dec 2004 Location: Mildura VIC, Australia
View User Gallery (25)
Posted: Tue Sep 04, 2007 8:19 pm Post subject: |
| falcon_3512003 wrote: | | can someone tell me what is a 4TFC its not on the list and i can get one but need to know what it is and will it go into my 94 gli auto need to know this one fast thanks in advance |
ef xr6 auto cob.. |
EFairmanual2088 Fordmods Parts Gopher
Age:21 Posts: 55 Joined: 17 Sep 2007 Location: Perth WA, Australia
Posted: Mon Sep 17, 2007 7:07 pm Post subject: |
| can somebody help me i have a 96 efII fairmont and am doing a manual conversion all i need is an ecu to match it needs to be smartlock compatible. can anyone tell me the catch code for the ecu that i need?.... cheers. |
Posted: Mon Sep 17, 2007 7:18 pm Post subject: |
| EFairmanual2088 wrote: | | can somebody help me i have a 96 efII fairmont and am doing a manual conversion all i need is an ecu to match it needs to be smartlock compatible. can anyone tell me the catch code for the ecu that i need?.... cheers. |
Basically any manual EF ecu. I have a EF Fairmont and am running a futura ecu without probs because all the Fairmont goodies are controlled by the BCM
The manual EF 6 cylinder ecu's will have the letter 'A' as the third digit. The Tickford versions will have the letter 'T' as the second digit also. The 4 at the start means its an EF....... 6 will mean its for an EL. Last digit is just a revision code
eg...... 4DAB..... ef manual
......4TAC......tickford manual |
Posted: Mon Sep 17, 2007 7:22 pm Post subject: |
| does it matter whether or not u put in a tickford ecu or a standard one |
Posted: Mon Sep 17, 2007 7:26 pm Post subject: |
I would say no........ as most of the tickford gains (inlcuding the odd couple kw ) came from the better breathing head, fuel regulator and better diff gearing, and different shift points in the auto's |
Posted: Mon Sep 17, 2007 7:28 pm Post subject: |
| thanks alot man appreciate it |
Posted: Mon Sep 17, 2007 7:30 pm Post subject: |
You can do without the manual ecu by following the tech doc on this site..... shows you how to solder in 2 resistors in the auto loom (for idle, reverse lights etc)
Then if your not happy, go spend the $$$ on the manual ecu..... they also fetch a fair bit too.... |
Posted: Mon Sep 17, 2007 11:22 pm Post subject: |
| awesome man cheers for the info i will certainly have a geez |
a1drake Fordmods - Getting Side Ways
Posts: 411 Joined: 06 Feb 2005 Location: in the middle of peak hour traffic SA, Australia
Posted: Sun Sep 30, 2007 1:09 am Post subject: ecu swap |
| great tread very well done, lots of info, whats the best ecu 4 eb2 falcon with bbm conversion 3.23 diff 5 speed twin thermos?????? cheers |
Posts: 1999 Joined: 06 Nov 2004 Location: Canberra - The Nations Capital ACT, Australia
Posted: Sun Sep 30, 2007 7:12 am Post subject: |
Can someone add the following catch code to the list:
WTLB AU XR6 3.45 Manual - June 99 - Feb 2000 WR2T-12A650-LB
I have this confirmed by Ford spares. |
Krytox Technical Contributor
Age:29 Posts: 2474 Joined: 20 Mar 2005 Location: Seaford State: VIC, Australia
Posted: Sun Sep 30, 2007 9:04 am Post subject: |
JA - XF Leaded, Auto
JM - XF Leaded, Manual
WA1- XF Uleaded, (unsure if auto or manual)
WA2- XF Uleaded, (unsure if auto or manual)
0DDA - 3.9 CFI EA
0DDC - Series 2 EA 4 Spd Auto
0DBF - EB Auto 3.9 MPI
12BD - AU2 6 Cyl Auto
12ED - AU Auto Police ECU
12MB - AU2 Ute 6 Cyl Manual
12?D - AU Series 3 XR6 Manual ECU
1DAC - XG/XH? Yoot without smartlock
1DCC - 4.0l 4 speed auto not sure id eb1 or 2
1DCD - EB 4Spd Auto
1DCE - 1993 EB II Auto, smartlock, 3.23 diff
1DDC - EB XR8 Manual, smartlock
1DEB - EB XR8
1DEC - ED XR8 Autos
1DGA - 1991 EB XR8, 4spd auto, no speed limit
1DHA - 91 NC Fairlane Ghia V8
1DKE - EBII, Smartlock
22CA - AU Series 2/3 XR8 200kw Manual
2DAD - ED XR6 Manual
2DCA - EBGT and/or Sprint
2DDA - EBGT and/or Sprint, Auto
3DAC - 1994 ED Falcon, manual,
3DAC - 1994 XG 4.0L Manual. with Smartlock
3DCA - ?
3DEA - Jul 1994 ED XR8, manual, 3.27 diff
3DBC - ED GLi/Fairmont Sedan
3DFA - ED XR8 Auto, Smartlock
3TBA - ED XR6 Auto
3TBB - XG XR6
4DAC - EF Falcon 94' 6cyl Manual
4DAD - EF Falcon 95' 6 cyl Manual Wagon
4DAF - EF Falcon 95' 6 cyl Manual
4DBC - Ford Falcon EF
4DBF - EF Auto
4DBG - Gli/Futura Sedan Auto
4DCC - 1994 EF Fairmont Ghia 4.0 Auto 3:23
4DCF - EF Fairmont 4.0L Auto
4DCG - EF Fairmont 4.0L 3.23 auto
4DED - Jan 1995 EF Futura, V8, Auto, 3.23
4DEG - 1995 EF V8 fairmont auto, 3.23
4DKF - 1996 EF ex-pursuit 5.0 Auto 3:08
4TAB - EF XR6 94' 6 cyl Manual
4TAC - EF XR6 96' 6 cyl Manual Sedan
4TAD - EF XR6 96' 6 cyl Manual
4TBD - EF Fairmont Ghia Tickford Auto 4.0L
4TDB - EF XR6 Auto.
4TED - EF GLI DUAL FUEL I6
4TFA - XR6 Auto
5DAA - 1996 XH ute, manual, smartlock. no central locking.
5DAC - EF Manual
5DBA - XH 4.0 Auto
5DBB - May 97 XH series 1 panel van with auto, smartlock and 3.23
5DBF - XH 4.0 Auto
5DCA - EF Series II Fairmont Ghia (Tickford I6HP - 4 Speed Auto - 3.45 LSD 15" Wheels
5TAC - EF XR6 Manual
5TCA - Police XR6 (No Speed Limit)
5TFA - EF XR6 Auto (01/03/96)
6DBB - 1997 EL Fairmont Auto.
6DBD - 1997 EL Auto 3.08 Diff
6DDB - EL Fairmont 6 cyl Auto.
6DFC - Jan 1997 EL XR8, manual, 3.23 diff.
6DFD - 1998 series1 XR8 (lo-po).
6DJA - 4.0 XR6, Auto, Fairmont Ghia
6DHD - 1997 EL XR8 Auto.
6DLE - 4.0L Auto (South african Export)
6DNB - EL Police 4.0L Auto
6TAD - EL XR6 Manual - Revision D
6TBB - Police Spec EL
6TBC - EL XR6
6TBD - EL XR6 Auto - Revision D
6TED - EL, Auto, Tickford with GAS (6 cyl)
6TGB - EL Falcon GLI - Tickford GAS ECU revision B, 1996 model
6TGE - EL Falcon GLI - Tickford GAS ECU revision E, 1998 model
7DAC - EA Wagon "S Pack" MPFI, Manual, 3.9
7DBC - EA 3.9 MPFI Auto
7DBD - EA 3spd Auto
7DCD - EA Manual
7DCE - 3.9l CFI 5 speed
7DDE - 1989 EA 3.9 CPI 3spd Auto
7DYA - XH 4.0 Auto
7DYB - XH 4.0 Auto
WABF - AU Dual Fuel Auto.
WANA - AU Auto
WTAB - AU XR6 Manual
WTLB - AU XR6 3.45 Manual - June 99 - Feb 2000
X2CA - AU1 TS50
Y3EC - AU1 XR8 Auto (Adaptive Shift) |
KiwiDazza Fordmods Stock as a Rock
Posts: 106 Joined: 04 Jun 2006 Location: Palmerston North Oustide Australia
Posted: Tue Oct 02, 2007 1:10 pm Post subject: |
Any idea what this one is.
Says 5.0L MPEFI with part number 94DA-9C485-BA |
Posted: Tue Oct 02, 2007 11:01 pm Post subject: |
| EF 4.0L falcon Auto |
jamesbakon Fordmods Parts Gopher
Age:45 Posts: 79 Joined: 28 May 2007 Location: melbourne/ brunswick VIC, Australia
Posted: Tue Oct 09, 2007 3:10 am Post subject: ecu |
| i still have many ecu s left from my collection to suit models ea to au , for automatics only |
racer Fordmods Parts Gopher
Age:38 Posts: 91 Joined: 16 Jul 2007 Location: sydney NSW, Australia
Posted: Sat Oct 27, 2007 11:23 pm Post subject: |
| HI. IS 6DJC A EL FAIRMONT GHIA ECU 4.OL TICKFORD ENGINE, AUTO ? |
Posted: Mon Oct 29, 2007 5:34 pm Post subject: |
| racer wrote: | | HI. IS 6DJC A EL FAIRMONT GHIA ECU 4.OL TICKFORD ENGINE, AUTO ? |
sure is.. |
[47 queries :: 0.05699 seconds ]
