ECU Catch codes!
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
alfy
PostPosted: Sat Mar 29, 2008 12:15 pm    Post subject: Reply with quote
frankieh
View User Gallery (18)
PostPosted: Sun Mar 30, 2008 6:46 pm    Post subject: Reply with quote
I know this is an old thread.. but it contains pertinant info and is related to what I am asking so I'm reviving it briefly.
I just got a 4TEG 94DT-12A650-EC ECU, and I'm guessing its from an EF II GAS, revision G..
What I wanted to know.. is do these things run petrol and gas or just gas?
Also, do they have any benefit being "tickford" I mean are they improved over the standard ECU like a Ghia/XR6 computer in an EL...
anyone know about these things?
many thanks
rgds
Frank
sexyr6
View User Gallery (25)
PostPosted: Sun Mar 30, 2008 6:52 pm    Post subject: Reply with quote
AFAIK they have the correct maps for running LPG and petrol it changes between the two when you change from LPG to fuel..
Krytox
PostPosted: Sun Mar 30, 2008 7:34 pm    Post subject: Reply with quote
^^^^ what he said.
ECU has dual maps.
Does not have Tickford (xr/ghia) spec Fuel maps.
Its pretty much a Standard Futura ECU with an additional spark map.
Altho... it does have the ever so wanted DT on it so.... it must be worth more :)
frankieh
PostPosted: Sun Mar 30, 2008 8:01 pm    Post subject: Reply with quote
bummer... shame they never made the hot tickford maps with Gas and petrol.. that would be the one to have for a dual fuel car.
oh well, will sell this on ebay for 30 bucks or something.
Nigel
PostPosted: Sat Apr 12, 2008 4:55 pm    Post subject: Reply with quote
1DCC is EB II Pre Smartlock auto (gearbox Control in, no smartlock) - great if you want to take Engine/Box to project car such as XD/E/F or so on.
sly
PostPosted: Thu May 01, 2008 11:18 am    Post subject: Reply with quote
The "factory" dual-fuel option was actually contracted out to Tickford. That's why it's a Tickford ECU. As others have said, it has the EFII petrol map as well as an LPG map.
frankieh
PostPosted: Thu May 01, 2008 11:33 am    Post subject: Reply with quote
Do you know how they switch between the two maps?
Does it auto detect via the sensors that its running gas or is there a trigger somewhere?
I'm wondering if later on, I shouldn't try to get a dual fuel EL ECU as well as the XR ecu I want.. then I could swap in the ECU for gas and the XR when I want to go fast.
Got this EF one for 20 bucks... no use to be because I don't have an EF.. but figured I'd know someone that'd want it.
sly
Very informative and helpful thread, but a bit patchy for info on AU ECU's.
FYI AU ECU's starting with W are Series 1. 12xx ECU's are Series 2 and 22xx are Series 3.
There is a further complication in Series 1 as Smartshield was introduced as a running change during Series 1, approx May 99. So there are Smartlock ECU's and Smartshield ones for the AU1.
The WANA listed, for example, is a Smartshield ECU as used in my Aug 99 wagon. The equivalent XR6 HP Auto ECU is WTMx, where 'x' can be A through D. That's a rainy day project, HP cam and ECU... it might happen if I don't drop a complete VCT engine in first. Or a Raptor. Or a VCT engine plus Raptor. But I digress...
Not 100% sure on these next 2, I dug them up from the parts database on AFF:
WTJA to WTJF: AU S1 Egas Smartlock
WTSA to WTSE: AU S1 Egas Smartshield.
twason
PostPosted: Thu May 01, 2008 5:25 pm    Post subject: Reply with quote
Can you confirm if this is smartlock or Smartshield?
WR2T-12A650-LB
I know its a XR6 AU Manual ECU but nw one seems to be able to tell me smartlock or shield.
impulse
PostPosted: Fri May 09, 2008 12:02 pm    Post subject: Reply with quote
Clarification...
"1DCC - 4.0l 4 speed auto not sure id eb1 or 2"
I am just about to replace my ECU which is shutting down the fuel pump after 5 mins driving, then won't turn on again for hours. (When hot wired the pump works for at least 30 mins)
The 1DCC definitely comes from:
Falcon 4.0L 4 speed auto
Build June 1992
EBII
I do not know if it works in the EB1
Nigel
PostPosted: Fri May 09, 2008 2:17 pm    Post subject: Reply with quote
1DCC is definetly NON smartlock, however it is EB II so it has the gearbox control code in it as well. This ECu is the bridge one from the Start of the EB Series II until the start of Smartlock (Aug 92 I think)
EB I ECU's still had the seperate TCM I think
Nigel
sly
PostPosted: Mon May 19, 2008 9:31 pm    Post subject: Reply with quote
WR2T-12A650-LB
I'd guess at Smartshield, it's for a HP, not VCT.
There is a listing for WR2T-12A650-AD also described as XR6 HP Manual, which I'd assume is Smartlock. All the Smartlock ECU's seem to be early in the alphabet, 12A650-Ax to around -Jx. From -Lx up seem to be Smartshield. Seems logical to me, dunno if I'm reading too much into it.
sly
PostPosted: Mon May 19, 2008 9:35 pm    Post subject: Reply with quote
At a guess it'd just take a voltage from the gas switch to a pin on the ECU. Aftermarket LPG systems switch the injectors on & off via a high or low voltage on the gas switch's blue wire.
frankieh
PostPosted: Mon May 19, 2008 10:29 pm    Post subject: Reply with quote
thanks sly.. that info will come in handy one day.
twason
PostPosted: Tue May 20, 2008 8:00 am    Post subject: Reply with quote
WR2T-12A650-LB
Thanks Sly, I knew it was non VCT but that did not concern me, I was however hopeing for smartlock.
Timmeh
PostPosted: Thu May 22, 2008 7:32 pm    Post subject: Reply with quote
EL 2 XR8 185kw manual catch code is 6DFD.
mynads
PostPosted: Sat May 24, 2008 9:55 pm    Post subject: Reply with quote
hey all,top thread!!my question i hope someone can answer for me asap is will the EEC-IV part# 86DA-12A650-AB go into my EB 4.ol auto sedan? i ask this because onthe other side of this EEC is a white sticker with ZL FAIRLANE written on it & also another sticker next to it showing 6AA.im assured this came out of a EB 4.ol auto though.Any thoughts??
racedirector
PostPosted: Sat May 24, 2008 9:59 pm    Post subject: Reply with quote
Nigel
My wife has an EB 1 S pack and that does not have the seperate trans ECU - nothing bolted to the pedal box. I don't know what the ECU code is but it isn't smartlock.
RD
TROYMAN
View User Gallery (30)
PostPosted: Sat May 24, 2008 10:19 pm    Post subject: Reply with quote
no. sorry it wont as that ecu is for xf efi or zl efi fairlane..
completely different engine..
Page 9 of 10
[47 queries :: 0.08006 seconds ]
