Posts: 2123 Joined: 27 Dec 2004 Location: melbourne, sunshine VIC, Australia
Posted: Sun Apr 29, 2007 8:23 pm Post subject: |
| just wondering if this list is the one as provided by for or is it gathered from various sources? |
Krytox Technical Contributor
Age:29 Posts: 2506 Joined: 20 Mar 2005 Location: Seaford State: VIC, Australia
Posted: Sun Apr 29, 2007 8:28 pm Post subject: |
I assume they're gathered by various people and their findings.
The ones I've added, I've taken note of what car they're from and its acc's |
Posted: Sun Apr 29, 2007 8:31 pm Post subject: |
JA - XF Leaded, Auto
JM - XF Leaded, Manual
WA1- XF Uleaded, (unsure if auto or manual)
WA2- XF Uleaded, (unsure if auto or manual)
0DDA - 3.9 CFI EA
0DDC - Series 2 EA 4 Spd Auto
0DBF - EB Auto 3.9 MPI
12BD - AU2 6 Cyl Auto
12ED - AU Auto Police ECU
12MB - AU2 Ute 6 Cyl Manual
12?D - AU Series 3 XR6 Manual ECU
1DAC - XG/XH? Yoot without smartlock
1DCC - 4.0l 4 speed auto not sure id eb1 or 2
1DCD - EB 4Spd Auto
1DCE - 1993 EB II Auto, smartlock, 3.23 diff
1DDC - EB XR8 Manual, smartlock
1DEB - EB XR8
1DEC - ED XR8 Autos
1DGA - 1991 EB XR8, 4spd auto, no speed limit
1DHA - 91 NC Fairlane Ghia V8
1DKE - EBII, Smartlock
22CA - AU Series 2/3 XR8 200kw Manual
2DAD - ED XR6 Manual
2DCA - EBGT and/or Sprint
2DDA - EBGT and/or Sprint, Auto
3DAC - 1994 ED Falcon, manual,
3DAC - 1994 XG 4.0L Manual. with Smartlock
3DCA - ?
3DEA - Jul 1994 ED XR8, manual, 3.27 diff
3DBC - ED GLi/Fairmont Sedan
3DFA - ED XR8 Auto, Smartlock
3TBA - ED XR6 Auto
3TBB - XG XR6
4DAF - 95 EF Falcon. 6 cyl Manual
4DBC - Ford Falcon EF
4DBF - EF Auto
4DBG - Gli/Futura Sedan Auto
4DCC - 1994 EF Fairmont Ghia 4.0 Auto 3:23
4DCF - EF Fairmont 4.0L Auto
4DCG - EF Fairmont 4.0L 3.23 auto
4DED - Jan 1995 EF Futura, V8, Auto, 3.23
4DEG - 1995 EF V8 fairmont auto, 3.23
4DKF - 1996 EF ex-pursuit 5.0 Auto 3:08
4TAD - 1994 EF XR6, Manual
4TBD - EF Fairmont Ghia Tickford Auto 4.0L
4TDB - EF XR6 Auto.
4TED - EF GLI DUAL FUEL I6
4TFA - XR6 Auto
5DAA - 1996 XH ute, manual, smartlock. no central locking.
5DAC - EF Manual
5DBA - XH 4.0 Auto
5DBB - May 97 XH series 1 panel van with auto, smartlock and 3.23
5DBF - XH 4.0 Auto
5DCA - EF Series II Fairmont Ghia (Tickford I6HP - 4 Speed Auto - 3.45 LSD 15" Wheels
5TAC - EF XR6 Manual
5TCA - Police XR6 (No Speed Limit)
5TFA - EF XR6 Auto (01/03/96)
6DBB - 1997 EL Fairmont Auto.
6DBD - 1997 EL Auto 3.08 Diff
6DDB - EL Fairmont 6 cyl Auto.
6DFC - Jan 1997 EL XR8, manual, 3.23 diff.
6DFD - 1998 series1 XR8 (lo-po).
6DJA - 4.0 XR6, Auto, Fairmont Ghia
6DHD - 1997 EL XR8 Auto.
6DLE - 4.0L Auto (South african Export)
6DNB - EL Police 4.0L Auto
6TAD - EL XR6 Manual - Revision D
6TBB - Police Spec EL
6TBC - EL XR6
6TBD - EL XR6 Auto - Revision D
6TED - EL, Auto, Tickford with GAS (6 cyl)
6TGB - EL Falcon GLI - Tickford GAS ECU revision B, 1996 model
6TGE - EL Falcon GLI - Tickford GAS ECU revision E, 1998 model
7DAC - EA Wagon "S Pack" MPFI, Manual, 3.9
7DBC - EA 3.9 MPFI Auto
7DBD - EA 3spd Auto
7DCD - EA Manual
7DCE - 3.9l CFI 5 speed
7DDE - 1989 EA 3.9 CPI 3spd Auto
7DYA - XH 4.0 Auto
7DYB - XH 4.0 Auto
WABF - AU Dual Fuel Auto.
WANA - AU Auto
WTAB - AU XR6 Manual
X2CA - AU1 TS50
Y3EC - AU1 XR8 Auto (Adaptive Shift) |
Age:31 Posts: 969 Joined: 23 Dec 2004 Location: Mildura VIC, Australia
View User Gallery (25)
Posted: Sun Apr 29, 2007 8:35 pm Post subject: |
| the list I posted is mostly from the one posted earlier buy P100 ute in the thread i've just cleaned it up and added some that i knew... |
Posted: Mon Apr 30, 2007 1:52 pm Post subject: |
I was a bit concerned about the ones with so many different titles:
IE: 4DAF - EF 4.0L Manual - Revision F - Gli, Futura, Fairmont.
Should read 96 EF 4.0 Manual Wagon 3.23:1 (as I pulled it from this car)
This was not a code for a fairmont. yet no manual was avaliable in the EF Fairmont Models.
I was tying to stick with the codes that go for model/engine/trans/diff
etc! |
XTT909 Fordmods Parts Gopher
Age:33 Posts: 59 Joined: 07 Feb 2007 Location: minchinbury/eastern creek NSW, Australia
Posted: Mon Apr 30, 2007 3:36 pm Post subject: |
6DGD 5.0l auto el
6DFD 5.0l man el
4DDE 5.0l man ef
1DDB 5.0L MAN EB
2DBD 4.0L ED AUTO XR6
3DAC ED XR6 MAN
2DDA ED sprint 5.0L auto
and if you need bin copies can email them to you  |
Posted: Mon Apr 30, 2007 9:22 pm Post subject: |
| Krytox wrote: | I was a bit concerned about the ones with so many different titles:
etc! |
ok fair enough, if there are things in the list that you think are incorrect then alter them, i was only trying to put in some sort of order..
the thing is that your example 4DAF was not only fitted to wagons it would have been aslo fitted to sedans, I have found buy looking into what each letter means i have found (worked out) that diff ratios are not relevent..and not nessacerally fitted to one perticular year (eg. 4DAF - 96). |
Posted: Mon Apr 30, 2007 9:40 pm Post subject: |
True, but we don't want to be missleading people..
Diff ratios can be relevant in autos but will obviously work either way.
a 6DBB isn't the best replacement for a 6DJA (ghia with SS steering)
Everything removed by myself I make note what was in the rest of the car.
depending of the type. I even take a photo of the compliance plate.
Unless I can obtain a ford breakdown of ecu's I'd like to have as much honest info as I can get! |
Posted: Mon Apr 30, 2007 9:55 pm Post subject: |
| Krytox wrote: |
a 6DBB isn't the best replacement for a 6DJA (ghia with SS steering) |
in the list i havent suggested that it does |
Posted: Mon Apr 30, 2007 9:59 pm Post subject: |
etc! |
100% agree that that is the best way to do it otherwise its too general
what other ecus have you discovered? |
Posted: Mon Apr 30, 2007 10:06 pm Post subject: |
| gogetta wrote: | | Krytox wrote: | I was a bit concerned about the ones with so many different titles:
etc! |
The idea is to generalise it, because each individual car does not just have its own catch code, thay are also fitted to other various models..(eg. 4DBG - EF 4.0L Auto - Revision G - will be fitted in Falcon Gli, Futura, Fairmonts - wagons and sedans) |
Posted: Mon Apr 30, 2007 10:19 pm Post subject: |
| sexyr6 wrote: | | gogetta wrote: | | Krytox wrote: | I was a bit concerned about the ones with so many different titles:
etc! |
Yeh No Probs,
However I'll continue to follow a more accurate description myself.
Would you ride a donkey instead of a horse cos its got an a**?
| i just got out my EA - ED w/shop manuel and found ECU MODULE IDENTIFICATION CODE list i will type it out and post it as soon as i have finished .. it includes EA series 1 through to ED v8 I6 and XR's... |
eagle performance Fordmods Stock as a Rock
Age:28 Posts: 170 Joined: 28 Mar 2007 Location: melbourne VIC, Australia
Posted: Mon Apr 30, 2007 10:44 pm Post subject: |
| dose any one have a full list of the codes for all ecu's |
Posted: Tue May 01, 2007 8:59 pm Post subject: |
ok so i've just put together the list of codes from the EA - ED genuine W/Shop Manual...
7DAX - 87DA 12A650AX (X can be eather A,B,C,D,E) - EA 3.9L MPEFI Manuel
7DBX - 87DA 12A650BX (X can be eather A,B,C,D,E) - EA 3.9L MPEFI Auto
7DCX - 87DA 12A650CX (X can be eather A,B,C,D,E) - EA 3.9L CPEFI Manuel
7DDX - 87DA 12A650DX (X can be eather A,B,C,D,E) - EA 3.9L CPEFI Auto
7DEX - 87DA 12A650EX (X can be eather A,B,C,D,E) - EA 3.2L CPEFI Manuel
7DFX - 87DA 12A650FX (X can be eather A,B,C,D,E) - EA 3.2L CPEFI Auto
0DAX - 90DA 12A650AX (X can be eather A,B,C,D,E) - EAII 3.9L MPEFI Manuel
0DBX - 90DA 12A650BX (X can be eather A,B,C,D,E) - EAII 3.9L MPEFI Auto
0DCX - 90DA 12A650CX (X can be eather A,B,C,D,E) - EAII 3.9L CPEFI Manuel
0DDX - 90DA 12A650DX (X can be eather A,B,C,D,E) - EAII 3.9L CPEFI Auto
0DEX - 90DA 12A650EX (X can be eather A,B,C,D,E) - EAII 3.2L CPEFI Manuel
0DFX - 90DA 12A650FX (X can be eather A,B,C,D,E) - EAII 3.2L CPEFI Auto
1DFX - 91DA 12A650FX (X can be eather A,B,C,D,E) - EB 5.0L SEFI Manuel
1DGX - 91DA 12A650GX (X can be eather A,B,C,D,E) - EB 5.0L SEFI Auto, Short Wheel Base
1DHX - 91DA 12A650HX (X can be eather A,B,C,D,E) - EB 5.0L SEFI Auto, Long Wheel Base
1DAX - 91DA 12A650AX (X can be eather A,B,C,D,E) - EB 4.0L MPEFI Manuel, Sedan
1DBX - 91DA 12A650BX (X can be eather A,B,C,D,E) - EB 4.0L MPEFI Auto, Short Wheel Base (2.92 Axil)
1DCX - 91DA 12A650CX (X can be eather A,B,C,D,E) - EB 4.0L MPEFI Auto, Short Wheel Base (3.27 Axil)
1DKX - 91DA 12A650KX (X can be eather A,B,C,D,E) - EB 4.0L MPEFT Auto, Long Wheel Base and Wagon
1DLX - 91DA 12A650LX (X can be eather A,B,C,D,E) - EB 4.0L MPEFI Manuel, Wagon
1DDX - 91DA 12A650DX (X can be eather A,B,C,D,E) - EB 5.0L SEFI Manuel
1DEX - 91DA 12A650EX (X can be eather A,B,C,D,E) - EB 5.0L SEFI Auto, Short Wheel Base
1DJX - 91DA 12A650JX (X can be eather A,B,C,D,E) - EB 5.0L SEFI Auto, Long Wheel Base
1DAX - 91DA 12A650AX (X can be eather A,B,C,D,E) - EBII 10/92 on Smartlock 4.0L MPEFI Manuel, Sedan
1DBX - 91DA 12A650BX (X can be eather A,B,C,D,E) - EBII 10/92 on Smartlock 4.0L MPEFI Auto, Short Wheel Base (2.92 Axil)
1DCX - 91DA 12A650CX (X can be eather A,B,C,D,E) - EBII 10/92 on Smartlock 4.0L MPEFI Auto, Short Wheel Base (3.27 Axil)
1DKX - 91DA 12A650KX (X can be eather A,B,C,D,E) - EBII 10/92 on Smartlock 4.0L MPEFT Auto, Long Wheel Base and Wagon
1DDX - 91DA 12A650DX (X can be eather A,B,C,D,E) - EBII 10/92 on Smartlock 5.0L SEFI Manuel SXR8
1DEX - 91DA 12A650EX (X can be eather A,B,C,D,E) - EBII 10/92 on Smartlock 5.0L SEFI Auto, SXR8, Short Wheel Base
1DJX - 91DA 12A650JX (X can be eather A,B,C,D,E) - EBII 10/92 on Smartlock 5.0L SEFI Auto, Long Wheel Base
EDTVE 12A650 A - EBII Tickford SS 4.0L MPEFI Manuel
2DAX - 92DT 12A650AX (X can be eather A,B,C,D,E) - EBII/ED 4.0L MPEFI Manuel Sedan, Tickrod XR6
2DBX - 92DT 12A650BX (X can be eather A,B,C,D,E) - EBII/ED 4.0L MPEFI Auto Sedan, Tickrod XR6
2DCX - 92DT 12A650CX (X can be eather A,B,C,D,E) - EBII GT/ED Sprint Maneul 200kw
2DDX - 92DT 12A650DX (X can be eather A,B,C,D,E) - EBII GT/ED Sprint Auto 200kw
3DAX - 93DT 12A650AX (X can be eather A,B,C,D,E) - ED - 4.0L MPEFI Manuel Wagon, Tickford XR6
3DBX - 93DT 12A650BX (X can be eather A,B,C,D,E) - ED - 4.0L MPEFI Auto Long Wheel Base and Wagon, Tickford XR6
3DCX - 93DA 12A650CX (X can be eather A,B,C,D,E) - XG - 4.0L MPEFI Auto
3DDX - 93DA 12A650DX (X can be eather A,B,C,D,E) - XG - 4.0L MPEFI Manual
3DEA - 93DA 12A650EX (X can be eather A,B,C,D,E) - XG - 5.0L manual - Gli, Futura, S, XR8.
3DFA - 93DA 12A650FX (X can be eather A,B,C,D,E) - XG - 5.0L Auto - Gli, Futura, S, XR8,
i hope this is helpfull..
jonathon Fordmods - Getting Side Ways Donating Member
Age:21 Posts: 1091 Joined: 14 Apr 2006 Location: Whyalla SA, Australia
Posted: Mon May 21, 2007 12:13 pm Post subject: |
thats right for mine |
Posted: Mon May 21, 2007 1:21 pm Post subject: |
whats the catch code for this
E9AF 14A624 AA |
Posts: 407 Joined: 30 Nov 2004 Location: Melbourne VIC, Australia
Posted: Mon May 21, 2007 7:35 pm Post subject: |
9AAA
would be the catch code |
P100 Ute Fordmods Stock as a Rock
Age:23 Posts: 136 Joined: 27 Nov 2004 Location: Perth WA, Australia
Posted: Mon May 21, 2007 8:20 pm Post subject: |
accually. that E9AF etc code is on the back of the ECU's in faint red writing and doesnt have any resemblance
youd be chasing the sticker on the front of the ECU
looks like this.
BOSS 4LTR Fordmods Stock as a Rock
Age:21 Posts: 195 Joined: 12 Apr 2005 Location: sydney NSW, Australia
Posted: Sun May 27, 2007 9:18 pm Post subject: |
| the ED SS has its own ecu code EDTVE- how rare is this ecu. |
[47 queries :: 0.08476 seconds ]
