ECU Catch codes!
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
jamesbakon
PostPosted: Tue Aug 14, 2007 1:30 am    Post subject: Reply with quote
I HAVE OVER 200 OF THESE ECU's SITTING IN MY GARAGE COLLECTED SINCE 1990. I THINK IT IS TIME TO LET GO OF THEM. CONTACT ME IF ANYONE IS INTERESTED,THANKS RODNEY 0422141196 OPTUS MELB
Krytox
PostPosted: Tue Aug 14, 2007 6:37 am    Post subject: Reply with quote
Im Very Interested!
TROYMAN
View User Gallery (30)
PostPosted: Tue Aug 14, 2007 10:27 am    Post subject: Reply with quote
hi
im also interested
jamesbakon
PostPosted: Wed Aug 15, 2007 2:42 am    Post subject: ECU MIXED Reply with quote
I HAVE JUST LISTED THE ECU's ON EBAY,
TROYMAN
PostPosted: Wed Aug 15, 2007 10:11 am    Post subject: Reply with quote
hi
a link would be helpfull
burdeaux95
PostPosted: Wed Aug 15, 2007 10:26 am    Post subject: EF/EL ecu catch codes Reply with quote
Hi jamesbacon
Ihave just sent you a message on ebay asking about the ecu's.
I have a ef fairmont on dual fuel (IMPCO) what I want to ask a expert whitch one of this catch codes will suit a ef fairmont: 4DGA-B-C, 4TED, 4TEF, 4TEG, 4TGA-B-C-D-E.
Thanks Chas.
jamesbakon
PostPosted: Wed Aug 15, 2007 11:37 am    Post subject: Reply with quote
I am no expert , yu would have to ask Mr Krytox, thanks
burdeaux95
PostPosted: Wed Aug 15, 2007 1:14 pm    Post subject: EF/EL catch codes Reply with quote
The second part of the question I was directing to who ever know the
codes for the ef fairmont.
If Krytox would answer my question I would much appreciate it.
Chas.
Krytox
PostPosted: Wed Aug 15, 2007 11:36 pm    Post subject: Reply with quote
you could use almost any 6cyl EF auto Ecu, however one of the correct ones May be 4DCF or 4DCG etc. of tickford enhanced 4TBD (im sure this is an XR ecu)
anyways,
I doubt you'll benefit with a Tickford Gas ECU as the impco setup doesn't run a separate spark map.
I am no ECU expert someone else could shed a light on this, I just note what I find in cars (all parts) and research the difference *not easy* !
I hope this helps.
RedRoo
PostPosted: Wed Aug 15, 2007 11:59 pm    Post subject: Reply with quote
my ex taxi has a 4TGC in it
burdeaux95
PostPosted: Thu Aug 16, 2007 10:43 am    Post subject: EF/EL catch codes Reply with quote
To Krytox
Would the switch over to gas turn only the injectors of and change over the ecu to gas ignition map? The factory gas I thought have it's own control unit like the aftermarket conversions. If I'm wrong some body can explane.
To RedRoo.
Is your ex taxi factory gas or aftermarket gas?
RedRoo
PostPosted: Thu Aug 16, 2007 11:43 am    Post subject: Re: EF/EL catch codes Reply with quote
burdeaux95 wrote:
To Krytox
To RedRoo.
Factory Tickford Gas mate
mista_lroy
PostPosted: Tue Aug 21, 2007 9:40 am    Post subject: Reply with quote
anyone heard of a 4TFC,,he says its for a I6,Auto Ef Fairmont Ghia ???i cant find that number anywhere in here
sexyr6
View User Gallery (25)
PostPosted: Tue Aug 21, 2007 10:20 am    Post subject: Reply with quote
i've got that listed as EF XR6 Auto...
mista_lroy
PostPosted: Tue Aug 21, 2007 10:32 am    Post subject: Reply with quote
sweet may be what i need when i put in my tickford headed engine to compliment it,cheers
FPV_GTp
PostPosted: Fri Aug 31, 2007 9:38 pm    Post subject: Reply with quote
woooooooooooooooooooo 200 ECU's i thought i had a collection
nice thread this one
falcon_3512003
PostPosted: Sat Sep 01, 2007 5:54 pm    Post subject: Reply with quote
will a 4TBD - EF 4.0L Tickford, Auto - Revision D - Ghia. go into my gli ok and do these have the non speed limit is this a xr6 ecu allso can get one for 150 is it worth it???
falcon_3512003
PostPosted: Sun Sep 02, 2007 10:19 am    Post subject: Reply with quote
bump
falcon_3512003
PostPosted: Sun Sep 02, 2007 1:07 pm    Post subject: Reply with quote
can someone anser this for me plz will a 4TBD - EF 4.0L Tickford, Auto - Revision D - Ghia. go into my gli ok and do these have the non speed limit is this a xr6 ecu allso can get one for 150 is it worth it??? what changes will this give my car
Krytox
PostPosted: Sun Sep 02, 2007 3:37 pm    Post subject: Reply with quote
It'll work fine in your GLi, shift pattern will be slightly different, should handle a slightly larger cam better.
Would certainly be a fantastic addition to a signature.
Page 5 of 10
[47 queries :: 0.04901 seconds ]
