ED manual
ED manual
kapul
PostPosted: Tue Mar 25, 2008 5:25 pm    Post subject: ED manual Reply with quote
Hey guys i cant remember if i have asked this or not, i cant find a post where i have so ill just ask now. I have an ED manual which has been sitting for a while, it used to run perfect but now when i start it it runs like absolute s**t! ive had a bit of trouble with blocked injectors and am thinking this is the case again. It doesnt sound like ive done any engine damage BUT the front pipe of the extractors is not hot... it sounds like its only running on a couple of cylinders. When you pump the accelerator it f@rt around and s**t itself and stutters and doesnt raise in RPM... any help for some diagnosis?
smiley235
PostPosted: Tue Mar 25, 2008 5:28 pm    Post subject: Reply with quote
fun some fuel cleaner through the tank, see if it helps first.
cjh
PostPosted: Tue Mar 25, 2008 6:40 pm    Post subject: Reply with quote
Put some injector cleaner in it and take it for a long drive, about 100 or so K's.
MRE-50L
View User Gallery (53)
PostPosted: Tue Mar 25, 2008 6:49 pm    Post subject: Reply with quote
try putting in another set of plugs in it if have a spare set ,
kapul
PostPosted: Tue Mar 25, 2008 9:57 pm    Post subject: Reply with quote
cant take for a drive as it is unregistered, im trying to get it ready to be registered. i have put new leads and sparkplugs in. i have a whole other 4liter sitting there if i get stuck but do u think it could hurt if i change the injector rails and injectors around?
AU99
PostPosted: Tue Mar 25, 2008 10:15 pm    Post subject: Reply with quote
could be the fuel has gone off, how long has it been sitting for???? try some fresh juice in it
kapul
PostPosted: Wed Mar 26, 2008 10:06 am    Post subject: Reply with quote
nah had fresh fuel put in it...
fezagero
PostPosted: Wed Mar 26, 2008 3:07 pm    Post subject: Reply with quote
check the hose going to the map sensor on the firewall
kapul
PostPosted: Fri Mar 28, 2008 12:12 am    Post subject: Reply with quote
where is the map sensor? what am i looking for?
a1drake
Location: in the middle of peak hour traffic SA, Australia
PostPosted: Fri Mar 28, 2008 12:16 am    Post subject: Re: ED manual Reply with quote
what about the fuel pump they can go to s**t if left sitting
kapul
PostPosted: Fri Mar 28, 2008 6:11 pm    Post subject: Reply with quote
brand new fuel pump
Redford
Donating Member
PostPosted: Fri Mar 28, 2008 6:18 pm    Post subject: Reply with quote
i cant take a pic so, its a black plastic box on the passenger side of the firewall, 70x50mm with a 3 pin plug and a vacuum hose that runs to the inlet manifold.
basicly, any leaks in the hose or inlet manifold will make the engine run like s**t.
sexyr6
View User Gallery (25)
PostPosted: Fri Mar 28, 2008 6:29 pm    Post subject: Reply with quote
Post new topic   Reply to topic    Forum Index -> 6 Cylinder Workshop All times are GMT + 10 Hours
[34 queries :: 0.69597 seconds ]
