EF 2 Tickford LPG 'starving' after start-up
spvd02
PostPosted: Wed Sep 26, 2007 10:51 pm    Post subject: EF 2 Tickford LPG 'starving' after start-up Reply with quote
I have recently had my tickford LPG system serviced and alerted the mechanic to the problem my car has every time (!) (given 1-2 min) after it has started and run for 10-20 seconds. It starts perfectly fine, but after 10-20 seconds it sounds as if the gas system is beginning to 'starve' the engine, and it stutters and carries on, eventually getting over it by itself if left alone.
I got the car back, and it runs well, but still has the same problem, just as bad as it ever was.
Normally I start the car, reverse it out the drive-way and when I take off onto the road it will 'starve', losing all acceleration. In this case I need to take my foot off the accelerator, then re-apply throttle, after which it will accelerate normally again. It usually 'starves' 2-3 times while taking off, then operates perfectly normal for the rest of the trip, until I need to start the car again. Whether it is hot or cold makes no difference.
Does anyone with tickford LPG have the same problem. Has anyone found a way to overcome it? It is very annoying, and it would be great (!) if this problem were eliminated. If it was only during cold starts I would be ok with it, but not every single time!
mcspence
PostPosted: Wed Sep 26, 2007 11:09 pm    Post subject: LPG Starvation Reply with quote
I had the same problem on my EF. I have an after market condenser now, having replaced the tickford unit. I was suffering a searching idle with stalling, and starvation, until the engine warmed up. The answer was that the problem was caused by a low coolant level.
The coolant delivers heat to the condenser, which takes the lpg from the tank and then delivers it to the intake system. ( I am not too technical, so forgive the basic explanations). With a low coolant level, not enough heat was getting to the condenser, and so as the LPG flowed through it, it was freezing up, and only letting a fraction of the usual amount of gas through to the intake. When the car had been running for a while and had warmed, the problem ceased.
Check it out. It may be a coolant flow problem or something similar.
AU99
PostPosted: Thu Sep 27, 2007 1:32 am    Post subject: Reply with quote
alot of the problems associated with coolant flow on LPG convertors is the 2 stage thermostat. They shut of flow from the radiator (1st stage) and the heater (2nd stage) and what does the LPG convertor usually run off?? the heater side. So easy fix is to run an XG-H thermostat or cut section out of the 2nd stage (bottom section) of the standard thermostate to allow flow to the convertor when cold.
another thing it could be is the O2 sensor starting to go and not generating the right signal for the stepper motor that controls the gas flow when cold. Easy enough to check if oxy sensor is working ok if you have digital multi meter.
spvd02
PostPosted: Thu Sep 27, 2007 11:01 am    Post subject: it's possible... Reply with quote
Whilst it could certainly be the lack of coolant flow, it still doesn't seem to make complete sense, as the car will do it when it is hot and left for 2 minutes or more. Not only that, but if I chose to depress the accelerator while it was doing it, it'd get over it straight away. I was thinking it may be computer related, but am not sure. I do think, however, that I will look at replacing the thermostat (XG one? Why not the standard tickford LPG one?)
One other thing I haven't mentioned is that when it 'starves', the air intake (presumably where the gas comes in at the mixer) makes a rather loud 'hissing' sound. [/u]
AU99
PostPosted: Thu Sep 27, 2007 11:09 am    Post subject: Reply with quote
sounds more like O2 sensor proplem to me, I would get that checked first. LPG is more sensitive to O2 sensor proplems than petrol (or appears that way).
I had a similar thing. Would hesitate when putting the foot down and then right itself, would be cruising along and it would just slow down but would be fine on petrol. I tested the O2 sensor and it seemed ok but got one from a wrecker to try and it fixed the problem.
AU99
PostPosted: Thu Sep 27, 2007 11:26 am    Post subject: Re: it's possible... Reply with quote
you can get a standard tickford LPG thermostat?? thought they only came in the normal 2 stage one for the EF?
XG-H are like a normal type thermostat but the better option (like most LPG installers) is to cut a small section out of the bottom second stage of the normal 2 stage thermostat
spvd02
PostPosted: Thu Sep 27, 2007 11:46 am    Post subject: you're right Reply with quote
My O2 sensor has already been replaced a few months ago, which did not get rid of the problem. You must take into account the starvation occurs consistently about 10-20 seconds after start-up. If left alone, it will stutter and carry on (at idle), but if I give it a rev, the problem seems to disappear. That's at idle.
If I start driving it before it's gotten to that stuttering phase (which I usually do), then, while accelerating to speed (60km/h) for the FIRST TIME ONLY, it will almost completely cut out; backing off the throttle and re-applying it overcomes the problem immediately, though it pretty much always will do the same thing once or twice more during the same acceleration stint.
So I need to accelerate, back-off (when acceleration is lost), accelerate, back-off, and once more accelerate, back-off, and then the car will drive like a dream. But it takes about 15 seconds to go from 0-60km/h, and it's a Falcon!
So if not the O2 sensor, not the balance line (taped up all the holes in that), and nit the stepper motor or converter (both been replaced) it could be the thermostat (you're right, there's no such thing as a tickford one icon_confused.gif ), or what else could it possibly be? Solenoids? Computer? Is there anything I missed?
spvd02
PostPosted: Thu Sep 27, 2007 3:13 pm    Post subject: 2-stage thermostat Reply with quote
Please clarify where the second stage on the thermostat is. I have noticed there are 2 springs, and that one is putting tension on a plate at the bottom (when installed) of the thermostat. Is this the second stage?
AU99
PostPosted: Thu Sep 27, 2007 4:12 pm    Post subject: Reply with quote
here it is. red arrow points to the second stage
spvd02
PostPosted: Thu Sep 27, 2007 6:38 pm    Post subject: Where? Reply with quote
Where?
spvd02
PostPosted: Thu Sep 27, 2007 6:39 pm    Post subject: Sorry Reply with quote
Sorry, yep, I see it now; didn't show up initially for some reason. Maybe because I wasn't signed in
spvd02
PostPosted: Thu Sep 27, 2007 7:37 pm    Post subject: Modified thermostat Reply with quote
I drilled a 3mm hole in the plate for the second stage, and removed the bleeder valve on the first stage (also in a 3mm hole). Theoretically there should now be some flow through the thermostat.
However, disappointingly, the same problem still persists, and to the same extent as before. I think I can conclude it is the ECU or the gas computer causing hassles and, as far as that goes, I will just have to live with it, because it runs like a dream once it gets over that initial phase after start-up. IT only does it on gas, not on petrol, so it is something with the gas system.
Thank you guys for your input, as it helped point me in some direction. Even though the problem is not solved, you did your best to help anyway. Thanks once again.
AU99
PostPosted: Thu Sep 27, 2007 8:36 pm    Post subject: Reply with quote
3mm hole wouldnt be big enough. most installers cut a section across with tinsnips
AU99
PostPosted: Thu Sep 27, 2007 8:39 pm    Post subject: Reply with quote
dont know why pic is not showing up but if you left click on it and save it you will get what I mean. that is done to the second stage only
spvd02
PostPosted: Fri Sep 28, 2007 10:37 am    Post subject: ALright then Reply with quote
So you only cut a section off stage two then? I thought I would have to cut the same size of stage one, but I know this would not be good as I may as well take the thermostat out then. So where is the flow coming from if I only cut a section out of the second stage?
I will give it a go, but I'm not sure it will fix my problem.
scattered65
PostPosted: Fri Sep 28, 2007 11:14 am    Post subject: Reply with quote
Take it to a place that handles gas... like a taxi joint or something like that... Spoke to a mate of mine who works on a tonne of cabs... laughed at me when I told him what people thought the problem was (no offence people, just saying it as it is) but then the smug prick would'nt say what the problem really was... icon_evil.gif
spvd02
PostPosted: Fri Sep 28, 2007 1:09 pm    Post subject: thermostat modified Reply with quote
I modified the second stage of the thermostat as AU99 described. However, the car still has the same problem. I think it might not be such a bad idea to take it to a gas mechanic.
I will leave the thermostat as it is now though, because that seems to be a good way to go with LPG (rather than just a standard thermostat). The car does seem to run a bit better on gas when it's cold, so maybe there has been a positive outcome.
If I want to solve the problem, I will take your advice and take it to a gas mechanic to look specifically at that problem. Thanks again..
scattered65
PostPosted: Fri Sep 28, 2007 2:24 pm    Post subject: Reply with quote
sorry I couldn't be of much help telling what it is.... As for the gas mechanic, go somewhere that has and does deal with a lot of taxi's, they know their s**t
spvd02
PostPosted: Fri Sep 28, 2007 3:41 pm    Post subject: OK Reply with quote
Will keep that in mind... thankyou
TickFordEFXR6
PostPosted: Sat Jan 05, 2008 5:51 pm    Post subject: Reply with quote
please dont shoot me and i may have not read everrything in detail and i may waste ur time
but all this talk about coolant levels and thermostats not make sence
these tickford gas system problems happen at start up
so i would think the coolant system would not even be in use until the thermo stat opens releasing coolant around the motor then onto the gas mixer then onto the heater core
and i more question dont the tickford gas systems start of fuel for the 30sec after start up then auto switch over to gas
[47 queries :: 0.1387 seconds ]
