Ef airbag
daniel000
PostPosted: Mon Mar 31, 2008 5:05 pm    Post subject: Ef airbag Reply with quote
hey everyone im sure this has been asked but i couldnt find the answer
i have a ef fairmont and the same problem happens with my parents ef falcon
the problem is the airbag light stays on constantly and doesnt go off
how can you fix this
thanks
daniel000
PostPosted: Mon Mar 31, 2008 6:40 pm    Post subject: Reply with quote
can someone direct me to the tech section of this cuz it says u need to be a mod to view it
Timmeh
PostPosted: Mon Mar 31, 2008 7:19 pm    Post subject: Reply with quote
http://www.fordmods.com/forums/doc_menu.php?menu=Falcon/Fairmont/Fairlane&type=EF/EL
If you can't access this let me know.
daniel000
PostPosted: Mon Mar 31, 2008 7:35 pm    Post subject: Reply with quote
thanks
to get the code. is it jus the number a times it flashes?
daniel000
PostPosted: Mon Mar 31, 2008 7:50 pm    Post subject: Reply with quote
or is it somethin else
thanks
daniel
jack11
PostPosted: Sat May 24, 2008 12:23 am    Post subject: Reply with quote
its a hard fault you need scanner off some sort to get the code out 2 most common faults are drivers side air bag and clock spring
ghia97
Donating Member
PostPosted: Sat May 24, 2008 1:58 am    Post subject: airbag Reply with quote
If horn works its unlikely to be clock spring. Check if works could be fuse or needing reset.Good luck with it.
[34 queries :: 0.02598 seconds ]
