Age:23 Posts: 2339 Joined: 07 Nov 2004 Location: Perth WA, Australia
Posted: Sun Aug 12, 2007 12:58 am Post subject: EF/L Cluster swap question |
just a quick one
if i install a high series BEM at the same time as the cluster, will i still need to add that diode/resister so the lcd's illuminate? |
Posts: 2047 Joined: 06 Nov 2004 Location: Canberra - The Nations Capital ACT, Australia
Posted: Sun Aug 12, 2007 9:20 am Post subject: |
| No but you will need to change the headlamp switch and maybe the wiper stalk depending on your model - your profile suggest a futura so the stalk will be OK. |
Krytox Technical Contributor
Age:29 Posts: 2557 Joined: 20 Mar 2005 Location: Seaford State: VIC, Australia
Posted: Sun Aug 12, 2007 10:54 am Post subject: |
as he said, however you add the resistor when adding a fairmont cluster to a gli/futura/xr.
remove when going low spec cluster to higher series dash loom. |
Age:44 Posts: 2956 Joined: 13 Jan 2005 Location: South Coast NSW, Australia
Posted: Sun Aug 12, 2007 9:08 pm Post subject: |
| twason wrote: | | No but you will need to change the headlamp switch | Any E series equivalent fairmont/ghia/LTD/Fairlane headlamp switch will suit for the replacement. Check for the green connector on the back of the switch body - gli/futura ones are a beige colour.
Also the wiring from the switch to the BEM needs to be modified, or changed. |
Posted: Tue Sep 04, 2007 10:21 pm Post subject: |
| is a high series bem a straight swap to gain things such as fade in and out on interior lamps? |
Commando Fordmods Stock as a Rock
Posts: 179 Joined: 05 Mar 2007 Location: Midland WA, Australia
Posted: Tue Sep 04, 2007 10:37 pm Post subject: |
| Fade should happen with the Futura BEM |
Posted: Tue Sep 04, 2007 10:39 pm Post subject: |
| xpression wrote: | | is a high series bem a straight swap to gain things such as fade in and out on interior lamps? |
High series requires wire mods and a fair bit of stuffing around,
A Mid series gives you Light fade, intermittent wipers, also time delay on window circuit. and is a direct plug in (ef-ef or el-el)
http://www.fordmods.com/forums/documents.php?doc=49 |
Posted: Tue Sep 04, 2007 11:57 pm Post subject: |
maybe it does, i havent actually checked, altho i do have intermitant wipers and also time delay on power windows.
Does any EL bem make the lights come on when key is turned off? |
the_scotsman Fordmods - Getting Side Ways
Age:28 Posts: 1245 Joined: 06 Nov 2004 Location: Nowra NSW, Australia
Posted: Thu Sep 13, 2007 9:15 pm Post subject: |
lights on when key is turned off...no E-series does this as far as I'm aware.
I upgraded my BEM in the XR6 with a high series one doing the climate control conversion. It was easier to just replace the dash loom with a high series one, then everything is just plug and play. |
Posted: Fri Sep 14, 2007 8:43 pm Post subject: |
| not so important now, i just got a promotion with a company car |
