EF LED blinkers flash fast
teveo
View User Gallery (23)
PostPosted: Tue Apr 15, 2008 6:39 pm    Post subject: EF LED blinkers flash fast Reply with quote
Hey boys i put led globes in front,side and back.. and they flash too fast like a globe is blown with the standard globes... Is there a LED flasher unit for them to stop the fast flashing? If so what brand, i checked out Bosch, they dont make one..
And the Led tail lights are dimmer than the standard, can they be made brighter?
twr7cx
PostPosted: Tue Apr 15, 2008 6:44 pm    Post subject: Reply with quote
Need a replacement flasher relay as the LED's draw less current. Dunno where you get them but. Perhaps JayCar or someone sells a universal one that you can replace the genuine one with.
Brightness of the LED's is based on what LED is used (assuming it's getting the right voltage). So different brand might be brighter.
teveo
PostPosted: Tue Apr 15, 2008 6:46 pm    Post subject: Reply with quote
thanks dude..
teveo
PostPosted: Tue Apr 15, 2008 8:28 pm    Post subject: Reply with quote
Krytox
PostPosted: Tue Apr 15, 2008 8:56 pm    Post subject: Reply with quote
should be able to purchase a Bosch electronic flasher, these are not fed by load. and are worth about $20
Private9
PostPosted: Wed Apr 16, 2008 9:27 pm    Post subject: Reply with quote
data_mine should be able to help with this - his EL had LED tail lights.
teveo
PostPosted: Sat Apr 19, 2008 4:22 pm    Post subject: Reply with quote
Bosch dont make a LED one, Trident do, but they sent the wrong one... So see what happens next week
Thumpdaddy
PostPosted: Sun Apr 27, 2008 5:42 pm    Post subject: Reply with quote
the LED lights are dull because they are directional and the light doesnt reflect back into the chrome reflector in the tail light. I had the same problem trying to put LED's in my AU II taxi cause I was spending more time and money changing tail light globes instead of picking up customers icon_sad.gif
 Description:
 Filesize:  32.34 KB
 Viewed:  14 Time(s)
Krytox
PostPosted: Sun Apr 27, 2008 6:33 pm    Post subject: Reply with quote
Thumpdaddy wrote:
the LED lights are dull because they are directional and the light doesnt reflect back into the chrome reflector in the tail light. I had the same problem trying to put LED's in my AU II taxi cause I was spending more time and money changing tail light globes instead of picking up customers :(
If the pic refers to your tails lights, I wouldn't get in your taxi either.
The Bosch electronic flash unit may not have 'LED' specified on it, however it has its own timing circuit and should work 100% with ANY load of upto around 7amps.
But if you need it to have a large price tag and LED written on it, be my guest. I've got one in my cortina and it worked fine, as long as you have an incandescent globe in the cluster so it can have 'some' type of earth.
grab one from the wreckers, hunt around escorts, sigma's, gemini's etc they've all got these 2 pin flashers.
Thumpdaddy
PostPosted: Sun Apr 27, 2008 7:21 pm    Post subject: Reply with quote
HUH!!!!!!! I dont get it........... what drugs are you on LOL
teveo
PostPosted: Sun Apr 27, 2008 10:15 pm    Post subject: Reply with quote
i got one off ebay.. $4.95.. see what happens
data_mine
PostPosted: Sun Apr 27, 2008 10:55 pm    Post subject: Reply with quote
Narva sell a LED flasher unit, you can order them from most auto shops (they're not normally stocked).
Part # 68246
teveo
PostPosted: Wed Jun 18, 2008 7:01 pm    Post subject: Reply with quote
I put all the standard globes back in, it was a huge waste of time and money!! My advice.. DONT BOTHER WITH IT!!
[42 queries :: 0.07233 seconds ]
