Ef Manual Pedal box
nvk-351
PostPosted: Sun Jun 29, 2008 2:19 pm    Post subject: Ef Manual Pedal box Reply with quote
hey,
Just about to fit a manual pedal box to my ef.. Do you guys have any tips or is there a step by step procedure to do it..
Thanks
xavier
PostPosted: Sun Jun 29, 2008 2:40 pm    Post subject: Reply with quote
yea, be paitent when your doing it, i got realy frustrated doing mine. u have to remove your whole dash, i think kickpannels to manouver your dash around, then undo all the bolts from steering colum brake booster ect, remove the pedals n then try and manouver it out, i didnt completly remove my dash from the car i just left it hanging loose which was why i found it difficult ro remove and replace n is why i got so frustrated, if you can be bothered completly removing the dash from the car it will make the job a whole lot easier
nvk-351
PostPosted: Sun Jun 29, 2008 4:34 pm    Post subject: Reply with quote
so when you say remove the whole das you do mean just the instrument cluster yeah? also do ihave to change the computer?
FairmontXR6
PostPosted: Sun Jun 29, 2008 4:50 pm    Post subject: Reply with quote
I've heard alot of people on here (when doing manual conversions) talk about strengthing the clutch hole on the firewall.
PIMP_LTD
PostPosted: Sun Jun 29, 2008 5:17 pm    Post subject: Reply with quote
Yes i recently had to do this, although mine is a factory manual.
While your doing the conversion, it'd pay for you to do it now.
Andrew.
rushed
PostPosted: Sun Jun 29, 2008 8:12 pm    Post subject: Reply with quote
what xavier said, i did the same, centre console out, whole dash unbolted steering column unbolted, lift dash off mountings, and get the bolts free, rip the pedal box out, then reverse.
in the tech docs section there is a guide written by phongus i think that went into enough detail to get the job done, its a b**ch to do, but stick at it.
twr7cx
PostPosted: Sun Jun 29, 2008 8:21 pm    Post subject: Reply with quote
any reason to change the pedal box over instead of just going the mal wood pin route?
nightstalker
PostPosted: Mon Jun 30, 2008 2:01 pm    Post subject: Reply with quote
From what Ive read I would suggest going the mal wood pin, it would be far more quicker and easier, I think the dash out is the old way..
chops1
PostPosted: Sat Jul 12, 2008 5:14 pm    Post subject: Reply with quote
I just did what Froudey done i used an 5/8th bolt with some washers and acouple of nuts.I also got myself apeice of steel plate drilled acouple of holes in it and attached that aswell to strengthen the the pedal box.This way works exactly the same as the Mal Wood Pin and it only cost me about $10.If you go this route just make sure you get hitensile bolts&nuts
94efdabomb
PostPosted: Sat Jul 26, 2008 8:10 pm    Post subject: i did this way Reply with quote
but after 12 mnths it dosnt last it shears away and you r left stranded untill you put another clutch box in i learnt the hard way $200 for a tow truck then $450 for the clutch box and labour
[37 queries :: 0.05248 seconds ]
