BuNtEr Technical Contributor
Age:41 Posts: 3228 Joined: 12 Feb 2007 Location: your mums NSW, Australia
Posted: Sat Sep 15, 2007 5:32 pm Post subject: EL/EF twin Fans into EB Mont V8 |
i went up to super cheap today like a little boy with a dollar to spend on lollys at the shop,
I bought a Davies Craig Thermo Switch kit, that came with thermal switch , screws, relay wiring harness rubber chok,
i will show some picks of the install of the thermal switch and relays.
Only problem i have i don’t have a 36mm open end spanner to take that F%#ken clutch fan off.
i will wire up the electrics of it tomorrow and search about seeing if i can find a person with the right size spanner and mug them for it.
I bought extra a relay and 2 spools of 15 amp wire red and black, and a packet of heat shrink all up cost me $107
You can but the Davies Craig thermal switch on its own for $49 but the kit I bought was $79
in the next post will be the photos, have to stuff around with photo show to reduce them. |
iam death Fordmods - Getting Side Ways
Posts: 1603 Joined: 07 Nov 2004 Location: kempsey NSW, Australia
Posted: Sat Sep 15, 2007 5:48 pm Post subject: |
| sweet as man..this is the next thing im doing to my new toy.the v8 nc,and being the dummy iam a good how to oco would be sweet..big pics and small words please lol.. |
Posted: Sat Sep 15, 2007 6:16 pm Post subject: |
ok here are the photos
This is the air box removed on the v8 EB
If you look close enough you will see the 2 small holes i drilled for the bracket that holds the davies Craig thermo switch
Braket in place
Here we have were i put the first relay that has the wring harness
@nd relay that will be used to conect the 2nd fan to the aircon
Air box back in place and you can see how neat the relays are beside it and you can still have easy access to take of the lid of the air box
Shot of the Thermo switch mounted in it place with the air box in place and you can get easy acces to the contol of the switch
Tope shot of the relays beside the air box
You can see how the copper sencer goes into the top hose, you must be careful with the copper piping as you cant afford to kink it or split it, if you do that one f**k thermo switch and you will have to spend another $49 top replace it.
be care full when you put this bugger in you use the little piece of rubber that came in the kit that has a small grove down the centre of it (make sure when you put the rubber wedge in you put it grove side up on the inlet of the radiator dont put the rubber wedge past the hump on the inlet of the radiator pipe) as thats were you lay the copper pipe, you best slide the hose off then move the hose clamp way up the hose out of the way, feed it into the hose and put the thin part of the copper pipe in the grove in the rubber wedge, hold it in place and slide the hose back on
now be careful keep the hose clamp away from the end of the hose as you slide it back on the radiator and hold the copper pipe on the rubber wedge and make sure the pipe don’t slide back as you fit the hose back on, once you have it back on slide the hose clamp back down on the end and tighten, when you tighten the hose clamp the grove in the rubber wedge will close over the copper pipe and seal it from leaking.
now replace your coolant remove all your tools out of the engine bay then start the car, look around the hose to see if it is leaking, let the car warm up and build up preacher and see then if you have any leaks.
i will be doing the wiring tomorrow if all goes well and i will show how i did it with more photos.
enjoy if you can lol |
Posted: Sat Sep 15, 2007 6:27 pm Post subject: |
the kit comes with 2 scotch locks PLEASE DONT USE THEM TOSS THEM IN THE BIN.
as they cut your wires when you use them. |
Age:23 Posts: 663 Joined: 10 Sep 2006 Location: Brisbane QLD, Australia
Posted: Sat Sep 15, 2007 6:30 pm Post subject: |
| Is 15amp wire enough?? The fuse in my EL says 60AMP (next to battery) |
Posted: Sat Sep 15, 2007 6:33 pm Post subject: |
im using the 15 amp for the trigger wire not the main wire, i will be using 30 amp wire, i have seen people use 10amp wire and never have a problem. the wiring harness that comes with the kit is 15 amp wire.
This is the size i am going to use in read ans black
here is the wiring instructions of the davies Craig thermal switch
Posted: Sat Sep 15, 2007 6:36 pm Post subject: |
i just had a better look at the wiring harness and its 10 amp wire not 15amp, it will handle it easy.
In the instructions i will be using diagram 5 and will only use one relay and not hook it back into the thermal switch as it will only come on when the aircon is turned on |
MRE-50L Fordmods - Getting Side Ways
Posts: 2192 Joined: 05 Nov 2004 Location: West Ryde - Sydney NSW, Australia
View User Gallery (53)
Posted: Sun Sep 16, 2007 1:05 pm Post subject: |
well BunTer you should have them thermo's wired up by now  |
Posted: Sun Sep 16, 2007 1:20 pm Post subject: |
almost been taking my time and thanks again for helping me get that s**t full cluch fan off.
i have notice the car starts quicker and it reves more, what i mean more touchy on the rev. |
Posted: Sun Sep 16, 2007 1:22 pm Post subject: |
| no probs , i did say it was easy with correct tools |
Posted: Sun Sep 16, 2007 1:26 pm Post subject: |
| well yer too easy didnt have to hold the water pump pully it cam off first hit. |
Posted: Sun Sep 16, 2007 1:50 pm Post subject: |
ok here are some photos of what it looks like ith the fans bolted on and the cluch fan gone.
You can see i kept the snorcle just had to be carful to drill 2 small holes in the top of the plastic of the fans.
before you try this mod on your EA,EB,ED make sure you have the radiator that will allow this mod, as it will need the 2 hols on the top on each corner to allow the nut and bolt to affix the wting fans to. |
TROYMAN Technical Contributor
Age:34 Posts: 2501 Joined: 07 Nov 2004 Location: South Western Sydney NSW, Australia
View User Gallery (30)
Posted: Sun Sep 16, 2007 2:00 pm Post subject: |
hi
good stuff.. you should notice a small difference in responce.
dont forget to wire your fans via a relay to your aircon so when you turn your air con on the fans will come on..
otherwise you will cook your air con pump |
Posted: Sun Sep 16, 2007 2:04 pm Post subject: |
| yep all taken care of got the aircon pump thanks, and small difference, big diffrance before took a few turns of the starter motor to start the car now its almost instant, and now you put your boot into it its lights the back weels up a s**t load easyer than before. |
Posted: Sun Sep 16, 2007 2:28 pm Post subject: |
i did that mod to my old xr8 and i was rapped with the difference..
and have since done it to my ea .
another good thing is no more crazy fan noise every time you rev it. |
Age:18 Posts: 3827 Joined: 02 Mar 2006 Location: Port Lincoln SA, Australia
Posted: Sun Sep 16, 2007 2:47 pm Post subject: |
hmmm maybe thats why my EA goes so hard.... the clutch fan's viscous hub is f**k and teh fan dosent turn at all...  |
Posted: Sun Sep 16, 2007 5:24 pm Post subject: |
| TROYMAN wrote: | i did that mod to my old xr8 and i was rapped with the difference..
yer its like b4 with the cluch fan all sound and no go, as the cluch fan made all the noise. |
Ben_Daui Fordmods - Getting Side Ways
Age:29 Posts: 1648 Joined: 10 Nov 2004 Location: THE DRUITT NSW, Australia
View User Gallery (29)
Posted: Sun Sep 16, 2007 6:58 pm Post subject: |
Whats the power gauge like with your headlights on & fans running?
In my EB the power gauge does drop about 3 bars. |
Posted: Sun Sep 16, 2007 7:36 pm Post subject: |
with the amp Stereo lights and high beam and aircon on yes about 2 bars when idle.
its nice now the only sound i hear when the Stereo isnt on is the great sound of the V8 out the zorst.
Posted: Sun Sep 16, 2007 9:00 pm Post subject: |
ok i made a how to do it doc on this subject, i know there is already one here on the forum and it is a good one but it dont have any photos so thats why i made this one, i hope it come in handy and i hope it helps.
i have updated the doc so it will show how to install for the 2nd fan and how to connect it to the aircon, and a over ride switch, and fixed a few typos
