Bozz Fordmods - Getting Side Ways
Posts: 615 Joined: 06 Nov 2004 Location: Brackistan VIC, Australia
Posted: Fri Dec 31, 2004 1:42 pm Post subject: EL Fairmont manual conversion done need help with some probs |
4.9 EF Futura Moderator
Posted: Fri Dec 31, 2004 2:11 pm Post subject: |
1) Just wondering what would happen if you told EEC the selector was in D? Theory suggests it would increase idle slightly.
2) I think there's an airbag diagnostic test in the tech docos on this site, clearing codes usually related to this process so may be worth a look.
3) Yeah that's the Trans Temp Link doing that. ECU is actually under the impression that trans is overheating - so it decides to cool the engine. Cough. lol. Seriously though, have a look thru some recent threads here as i posted a link to FF.com where someone had sorted all this out for the V8 ecu. You seem like you know your stuff so shouldnt be too hard to adapt for 6 cyl eec.
4) Good luck with that one
So, happy now you've gotten rid of the slushomatic? |
Posted: Fri Dec 31, 2004 3:37 pm Post subject: |
Posted: Fri Dec 31, 2004 4:50 pm Post subject: |
I've also got an issue with the 5spd gearbox, its a little sticky and wont go into gears often.
It will pass the synchro but will not engage the ratio, ie it goes halfway in but wont engage. If you release the clutch it grinds/crunches.
I notice the book states you should add some lubrizol or similar additive to the automatic transmission fluid(wtf!!!!) in the manual gearbox. I used dexron III, is this right or is the book confused..?
I fixed the thermofans running on full, it was the temp sensor so thank you very much 4.9 EF Futura, you saved me hours of tracing through the circuits... While I was under there I decided its also a wise idea to connect the reverse lights, I forgot them too ....
Just for reference, I used a 1.2K ohm resistor for the autotrans thermostat and a 7kohm resistor for the N position. |
Posted: Fri Dec 31, 2004 4:51 pm Post subject: |
Still need help with the airbag please  |
Posted: Fri Dec 31, 2004 9:25 pm Post subject: |
| Bozz wrote: | | I notice the book states you should add some lubrizol or similar additive to the automatic transmission fluid(wtf!!!!) in the manual gearbox. I used dexron III, is this right or is the book confused..? |
You put "auto trans" fluid in your power steering system too
It's just an oil like any other. The auto and power steering use it for hydraulic power assistance while the manual I presume uses it for lubrication within the gearbox. |
Age:23 Posts: 2339 Joined: 07 Nov 2004 Location: Perth WA, Australia
Posted: Sat Jan 01, 2005 7:30 am Post subject: |
depending on the model the power steering is Mobil 424 stuff...
Also, if EA-ED power steering shudders alot, converting from dexron to mobil 424 will solve the problem |
Posted: Sat Jan 01, 2005 12:18 pm Post subject: |
I know of ATF in power steering systems, most cars use that.
I've just never come across a car that asks for ATF in a manual gearbox...
Still need help with the airbag.. I'll make another topic about it and hopefully someone will see it that hasn't read this thread |
tikfud Fordmods Oompa Loompa
Posts: 23 Joined: 29 Dec 2004 Location: minchinbury NSW, Australia
Posted: Sat Jan 01, 2005 12:29 pm Post subject: |
i f**king hope you don't mean you put dexon III oil in your manual gear box i |
Age:25 Posts: 3563 Joined: 11 Nov 2004 Location: townsville QLD, Australia
Posted: Sat Jan 01, 2005 12:40 pm Post subject: |
| tikfud wrote: | i f**king hope you don't mean you put dexon III oil in your manual gear box i |
what the hell are you on about. you are ment to put ATF in the falcon T5 with 200ml of lubrizol
try knowing what your talking about
| bozz wrote: | | I've just never come across a car that asks for ATF in a manual gearbox... |
there are alot of cars that 'ask' for ATF in the manual gear box.
mostly front drive cars. but the T5 in falcons and commodores also take dextron 3 with an additive called lubrizol. |
Posted: Sat Jan 01, 2005 12:52 pm Post subject: |
well i do know what i'm talking about and if you put 75w 90 trans oil and and additive in your box it may just last longer any one worth their salt stop using dexron oil in T5's deacades ago |
DeNMaN Fordmods Oompa Loompa
Posts: 28 Joined: 10 Nov 2004 Location: Melbourne VIC, Australia
Posted: Sat Jan 01, 2005 1:03 pm Post subject: |
Hey everyone, im in a simular pradicument, i'v converted my EL XR6 to manual, well my machanic did, the 2 problems i have are
1. the fans are on full blast all the time
2. when starting the car, it jumps up to 2000rpm, then eses back to 1200rpm, then finally back to 1000rpm...
I'v heard that using a 1650ohm risister between the trans temp sencer and somthing else will fix the fans and should drop the RPM but i have no idea on how to do this.. does anyone have a diagram on what wires are what...
The manual i got was out of a EF XR6 and all i can say is it's dam awsome compaired to the auto it once had. much more go in it now.. |
Posted: Sat Jan 01, 2005 3:48 pm Post subject: |
| tikfud wrote: | well i do know what i'm talking about and if you put 75w 90 trans oil and and additive in your box it may just last longer any one worth their salt stop using dexron oil in T5's deacades ago |
if you put 75w 90 in them they get really bad gear bulk when changing gears and basicly become pigs of thing to use.
and the 200 000km my T5 has done with dex3 and lubrizol kind of shows that they last a lhell of a long time.
any one worth there salt as you so put it, would use what the maker of the box says to use. |
Nicko Moderator
Posts: 10987 Joined: 05 Nov 2004 Location: SE Melb VIC, Australia
Posted: Mon Jan 03, 2005 9:15 pm Post subject: |
| hey bozz did youc onnect the resistor to the trans temp line wire at teh ecu end or under the car? |
Age:36 Posts: 3118 Joined: 05 Nov 2004 Location: Singleton NSW, Australia
Posted: Mon Jan 03, 2005 9:58 pm Post subject: |
T5's become pig boxes when you use 75W oil, been there done that, upset customers.
A lot of 4WD's also use tranny fluid in transfer cases and I am not talking about toy type 4WD's i.e. Subaru, Rav4 etc. |
Posted: Tue Jan 04, 2005 9:49 am Post subject: |
tikfud; you're a comedian.
DeNMaN - you've just posted everything I've already posted, try reading the earlier posts.
Neo_nick - I did it under the car then cable tied the rest of the auto loom to the side of the T5.
Cheers for all the help everyone else  |
Posted: Wed Jan 05, 2005 11:56 am Post subject: |
Some good work there Bozz.
Yeah bit tough trying to find the airbag diagnostics without a pic of that damned white plug.
I used to have a rip-snorter of a link, site called Auto EMF and this had a bloody huge picture of the diagnostic connector. Site appears to be down, lol.
Maybe someone here knows off the top of their head? |
Waggin Site Admin
Age:25 Posts: 6735 Joined: 18 Dec 2002 Location: Sydney NSW, Australia
Posted: Wed Jan 05, 2005 12:41 pm Post subject: |
| 4th pin from the left, on the top row |
Posted: Wed Jan 05, 2005 1:17 pm Post subject: |
| Waggin wrote: | | 4th pin from the left, on the top row |
Lol, did i say "someone"? I meant brad  |
View User Gallery (17)
Posted: Wed Jan 05, 2005 1:26 pm Post subject: |
| 4.9 EF Futura wrote: | | Waggin wrote: | | 4th pin from the left, on the top row |
thought you were dead, my bad
LOL  |
