EL Fairmont shiftkit
SQUEAK
PostPosted: Tue Jan 11, 2005 9:38 pm    Post subject: EL Fairmont shiftkit Reply with quote
Hey all im going to be fitting a shift kit to my fairmont some time this week. My question is, How would you go about wiring it up if you didnt want an on/off switch?
Cause I dont want a switch, I want it on all the time!
Also are the resistor values the same for an el/ef?
Rapier
View User Gallery (33)
PostPosted: Tue Jan 11, 2005 9:44 pm    Post subject: Reply with quote
why would u want it on all the time it produces quite violent shifts, will put ure car sideways in the wet
Ugly Igley
PostPosted: Wed Jan 12, 2005 2:15 am    Post subject: Reply with quote
plus it begins to hurt your back after a while.....
One Drone
PostPosted: Wed Jan 12, 2005 3:04 am    Post subject: Reply with quote
Only if you floor it.. Don't listen to these somewhat miserable old men! icon_razz.gif
cougar30
PostPosted: Wed Jan 12, 2005 4:52 am    Post subject: Re: EL Fairmont shiftkit Reply with quote
I have just done my EL Fairmont the only thing i had a problem with was the wires you need to use are not 71 & 81 as most diagrams show they are 57 & 38 on the EL Fairmont
And you need to be able to switch it off in the wet .... it dose get sidways
Ace
PostPosted: Wed Jan 12, 2005 7:49 am    Post subject: Reply with quote
Sideways sounds interesting .... Tell me more about this shift kit icon_biggrin.gif
SQUEAK
PostPosted: Wed Jan 12, 2005 3:01 pm    Post subject: Reply with quote
nothing wrong with a car that goes sideways in the wet!!!
Just wanted to know if it can be done without the switch?
cougar30
PostPosted: Wed Jan 12, 2005 3:10 pm    Post subject: Reply with quote
yes it can .... just conect the two wires together that normaly go to the switch
PostPosted: Wed Jan 12, 2005 3:11 pm    Post subject: Reply with quote
Should be pretty easy.... just dont rig up the switch!! lol
Sign up at mechanicalforums.com and look at the EB-ED shift kit. This is wired up as a non-switchable kit - i.e. always on. Substitute pin # and resistance values for the EL and bob shall be your uncle.
SQUEAK
PostPosted: Wed Jan 12, 2005 3:31 pm    Post subject: Reply with quote
so basicly just connect wire 4 ( the one coming out of the 18ohm resistor)
to wire 6 that comes out of the 5.6ohm resistor. is that correct?
PostPosted: Wed Jan 12, 2005 3:42 pm    Post subject: Reply with quote
Im a bit rusty on it but the 5.6ohm goes to the S5, yeah? And the 18ohm is for the 'check' line on the ECU? If this is the case then that sounds about right.
*4.9 EF futura does not take responsibility for any advice given on the forums*
slycruza
PostPosted: Wed Jan 12, 2005 3:52 pm    Post subject: Reply with quote
or a little different u could but the adjustable solinoid thing in the gerbox...
tnats what i did in my old car worked awsome!
Disco Frank
PostPosted: Wed Jan 12, 2005 9:08 pm    Post subject: Reply with quote
mm but there is 3 wires LOL
Disco Frank
PostPosted: Wed Jan 12, 2005 9:09 pm    Post subject: Re: EL Fairmont shiftkit Reply with quote
ef au use pins 71/81 el uses 57 and 38 icon_smile.gif
cougar30
PostPosted: Thu Jan 13, 2005 4:48 am    Post subject: Re: EL Fairmont shiftkit Reply with quote
Yes that what i said ....he has a EL Fairmont so he uses 57 & 38
SQUEAK
PostPosted: Fri Jan 14, 2005 9:00 pm    Post subject: Reply with quote
was just about to install my shift kit......But cause I wasnt going to use a switch, I got a little confused with the wiring!
Can anyone help?
Im just trying to work out where the wires go if im not going to use a switch!
Waggin
Site Admin
PostPosted: Fri Jan 14, 2005 11:07 pm    Post subject: Reply with quote
Well, I havent seen the diagram, but wherever the 2 wires go into the switch, rather than connecting them to the switch, connect them to each other icon_smile.gif
SQUEAK
PostPosted: Sat Jan 15, 2005 9:36 am    Post subject: Reply with quote
but there is 3 wires???
SQUEAK
PostPosted: Sun Jan 16, 2005 11:45 am    Post subject: Reply with quote
Worked it all out peoples!
Shift kit is in and operational without a switch!
Its awsum! what a differance! Im loving it!
It chirps 2nd even with the locked diff!
Anyway motor comes apart this arvo......Doing a few things before the drags on wednesday! icon_twisted.gif
Happy
PostPosted: Sun Jan 16, 2005 12:08 pm    Post subject: Reply with quote
[47 queries :: 0.05395 seconds ]
