dcjacko Fordmods Oompa Loompa
Age:33 Posts: 24 Joined: 14 May 2007 Location: quakers hill NSW, Australia
Posted: Mon Jun 16, 2008 7:46 pm Post subject: el xr8 auto to manual???? |
| hi all, im looking at changing my auto to a manual, i know i need the man ecu, but what happens to the the little computer that runs the auto trans, do you just disconnect or do i have to change the whole wirring system to the manual wirring |
Krytox Technical Contributor
Age:29 Posts: 2504 Joined: 20 Mar 2005 Location: Seaford State: VIC, Australia
Posted: Mon Jun 16, 2008 8:27 pm Post subject: |
There is no little box that controls auto.
In EL's the ECU controls the Engine, Auto,Thermos, AC etc.
You will have to acquire a V8 Manual Box, or a CRS/Dellow conversion kit. |
nannas_ed Fordmods - Getting Side Ways
Age:23 Posts: 2083 Joined: 14 Jan 2005 Location: Melbourne VIC, Australia
Posted: Mon Jun 16, 2008 8:57 pm Post subject: |
| Krytox wrote: | There is no little box that controls auto.
thats definatly true in 6cyl but don't the v8's run a separate auto trans computer |
Posted: Mon Jun 16, 2008 9:59 pm Post subject: |
| yes my v8 has a seperate atuo trans computer, i was wondering if i disconnect that and put in a manual ecu if it would be ok when the converson is done, or do you think ill have to change the whole wiring |
Posted: Mon Jun 16, 2008 10:05 pm Post subject: |
| where is this computer located? |
phantom Fordmods Oompa Loompa
Age:30 Posts: 45 Joined: 05 Apr 2006 Location: adelaide SA, Australia
Posted: Mon Jun 16, 2008 10:23 pm Post subject: |
| It's mounted to a bracket on the left hand side of the pedal box. |
XR9UTE EFI Guru
Age:43 Posts: 1418 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Tue Jun 17, 2008 12:16 am Post subject: |
All V8's from EB-EL use a separate trans controller. Only from AU did V8's have trans control by the EEC(which is why I'm using an AU EECV to run both in my van).
Generally speaking you'll need to setup your neutral gear switch for the manual by using some of the wiring to your auto trans and attaching it to the neutral gear switch on your T5. |
Age:22 Posts: 1993 Joined: 05 Nov 2004 Location: Penrith NSW, Australia
Posted: Tue Jun 17, 2008 4:37 am Post subject: |
| That will get the car to start as it will think it is in neutral, but without the TCM connected to the ECU, the thermos will run full blast as it thinks the auto box is overheating. |
