payaya Fordmods Oompa Loompa
Posts: 25 Joined: 28 Nov 2004 Location: melbourne VIC, Australia
Posted: Thu Jan 27, 2005 9:23 pm Post subject: Engine Fuse Blown |
| Hey all had the head gasket done on the EL I6 and is overheating. I found out the engine fuse was blown would thi sbe responsible for the thermos or anything? |
Disco Frank Fordmods Junkie
Age:29 Posts: 13761 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Thu Jan 27, 2005 9:43 pm Post subject: |
umm what engine fuse?
there are several
was it the fuse inside the car in the fuse holder or was it one of the ones in the engine bay? |
Posted: Thu Jan 27, 2005 11:07 pm Post subject: |
| engine fuse next to the battery in the engine bay. |
Age:22 Posts: 3848 Joined: 15 Nov 2004 Location: Perth WA, Australia
Posted: Fri Jan 28, 2005 12:15 am Post subject: |
depends what fuse was blown?
look under the lid, it should have labeled what each one is |
creeture3 Fordmods Tyre Shredder
Posts: 358 Joined: 15 Nov 2004 Location: melbourne VIC, Australia
Posted: Fri Jan 28, 2005 8:54 pm Post subject: |
| my engine fuse blew when the A/C pump s#%t itself and locked up. |
Age:55 Posts: 2556 Joined: 07 Nov 2004 Location: Penrith NSW, Australia
Posted: Fri Jan 28, 2005 9:06 pm Post subject: |
Umm ? There are all relay and circuit breakers around battery..??
Isn't there ??? |
ndroo Fordmods - Smokin em up
Age:22 Posts: 204 Joined: 06 Nov 2004 Location: Kurri Kurri NSW, Australia
Posted: Fri Jan 28, 2005 10:33 pm Post subject: |
| i thought they were only relays...controling various things, the cooling fans are controlled by relays under there. You really only need 1 cooling fan...i ran on 1 for about 6 months until i ran the diag and noticed the relay for it was blown. |
Posted: Fri Jan 28, 2005 11:01 pm Post subject: |
| I have blown a couple of those,100amp, wouldnt think it would have to do with over heating, are your fan relays fine? |
Posted: Sat Jan 29, 2005 5:38 am Post subject: |
its the fuses next to the battery in the rectangler box to clear on confusion. The fused mark ENG i think was blown. I'm not sure it was blown after taking a closer look at it just the element was brown and was thinner than it was suppose to be. I changed the fuse around with the HEGO fuse which had the same rating fuse.
So what does a distorted fuse element mean? Any ill effects? |
comhelp Fordmods Tyre Shredder
Age:25 Posts: 391 Joined: 06 Nov 2004 Location: Melbourne VIC, Australia
Posted: Sat Jan 29, 2005 12:11 pm Post subject: |
did it happen while you were driving or stationary? i had this on my car, my atm has LPG (but not for long) and it was found that the main injector cable was pinched hence why the fuse had blown  |
Posted: Sat Jan 29, 2005 1:00 pm Post subject: |
| no i stumbled accross it when going over the engine bay. The fuse isnt blown it looks discoloured and is thinner than its meant to be. Sort of like almost going to blow. |
Vic Cruise Moderator
Posts: 5613 Joined: 05 Nov 2004 Location: Melbourne VIC, Australia
Posted: Sat Jan 29, 2005 2:15 pm Post subject: |
| So put a multimeter across it and see if it's intact. |
Posted: Sun Jan 30, 2005 6:28 pm Post subject: |
| no that is just the type it is (i.e. old type) |
Posted: Sun Jan 30, 2005 6:54 pm Post subject: |
| Vic wrote: | | So put a multimeter across it and see if it's intact. |
I repeat. |
