daquilina Fordmods Oompa Loompa
Posts: 27 Joined: 10 Dec 2007 Location: Melbourne VIC, Australia
Posted: Thu Jun 05, 2008 12:02 am Post subject: Factory 6'' rear speaker grilles be seperated from speaker? |
Can factory 6'' rear speaker grilles be seperated from speaker, ef-el?
thanks |
OZBMX Fordmods Tyre Shredder
Age:18 Posts: 329 Joined: 31 Dec 2007 Location: Munruben QLD, Australia
Posted: Thu Jun 05, 2008 5:40 am Post subject: |
| Yes, take out the speakers and you've just got to try and pop them of, without cracking them if possible, not the end of the world if they do but still. |
outlawxr6 Fordmods - Getting Side Ways
Age:36 Posts: 481 Joined: 20 Nov 2004 Location: Brisbane QLD, Australia
Posted: Thu Jun 05, 2008 9:28 am Post subject: |
They sure can, once they are removed you will find small reccesses in the grille to allow the use of a screwdriver to pry the grilles off, do it carefully as they are brittle.
Why do you want to remove them for? If you want to put them on aftermarket speakers they most likely won't fit as they are 6", most aftermarket speakers are 6.5"..... |
Posted: Thu Jun 05, 2008 3:53 pm Post subject: |
| Thanks, yeeh are brittle started to crack a bit, got to give another go, going to put aftermarket ones in pioneer 6'' 16 cms they say, also 17cm compatible. |
Posted: Thu Jun 05, 2008 4:50 pm Post subject: |
| daquilina wrote: | | Thanks, yeeh are brittle started to crack a bit, got to give another go, going to put aftermarket ones in pioneer 6'' 16 cms they say, also 17cm compatible. |
They are not 6" they are 6.5"... 6" is 15cm...... |
Posted: Fri Jun 06, 2008 3:48 am Post subject: |
| Ah ok, if most after market speakers are 6.5", how do you make them fit? |
Posted: Fri Jun 06, 2008 5:18 pm Post subject: |
get 6's
I've got a set of pioneer dual cone with them on myself cost me like 5 bucks down the wreckers, hehe. |
Posted: Fri Jun 06, 2008 7:28 pm Post subject: |
| Use either 6" speakers or use the grilles that come with the new speakers.... |
Posted: Fri Jun 06, 2008 7:33 pm Post subject: |
| Yeh ill just use the grilles that come with new speakers........just got to find a way to install the 6.5'' inch speakers........ |
Posted: Fri Jun 06, 2008 7:41 pm Post subject: |
| Legally you need to use spacers as you aren't allowed to cut the shelf.... |
Posted: Fri Jun 06, 2008 7:47 pm Post subject: |
| Yeh i know......maybe i can use some MDF wood under the carpet, with it being 5-10 mm in height then mount it to the parcel shelf. Then drill holes for speaker screws in wood, then cover it with the carpet again....... |
Posted: Fri Jun 06, 2008 8:19 pm Post subject: |
| That would work... |
Posted: Fri Jun 06, 2008 9:37 pm Post subject: |
| Try and test fit them first, some 6.5s fit in the 6" holes, just depends on how they take there measurements etc, like I have a set of jvc 6.5s in the doors, that just bolted straight in. |
Posted: Sat Jun 07, 2008 4:25 am Post subject: |
| OZBMX wrote: | | Try and test fit them first, some 6.5s fit in the 6" holes, just depends on how they take there measurements etc, like I have a set of jvc 6.5s in the doors, that just bolted straight in. |
Yeh going to try them out when i get them, bcoz different brands measure differently, incase they dont fit, ill try the MDF, let use know how it turns out  |
Posted: Wed Jun 11, 2008 9:46 pm Post subject: |
| ey guys, i installed the speakers in the rear, what i did is that i mounted them in factory position and just screwed self-tape screws into the carpet,made sure the screws were short so they wouldnt pearce out the other side of carpet. It works great and now there is less rattling noises from boot,bcoz speakers are mounted on the carpet:) |
Posted: Sun Jun 15, 2008 12:09 am Post subject: |
| daquilina wrote: | | ey guys, i installed the speakers in the rear, what i did is that i mounted them in factory position and just screwed self-tape screws into the carpet,made sure the screws were short so they wouldnt pearce out the other side of carpet. It works great and now there is less rattling noises from boot,bcoz speakers are mounted on the carpet:) |
Let me get this right, you have your speakers held in your car attached only to the carpet??????
Don't you think it would be better to screw them in properly, like into the metal shelf???? |
Posted: Sun Jun 15, 2008 3:05 am Post subject: |
yeh there screwed into the carpet, its a perfect fit it dosnt even need to be screwed in because they dont move at all,(unless the car was turned upside down) but i just screwed them in.
Yeh i was going to put them under the carpet, and attach to metal, but they wouldnt fit in the factory hole, theres to much width in the speaker. |
Age:21 Posts: 2467 Joined: 08 Nov 2004 Location: Townsville/Cairns QLD, Australia
Posted: Sun Jun 15, 2008 9:47 pm Post subject: |
what this guy said. i had kenwood 6" speakers in the door of my EF and they fit perfectly, followed by 6.5" alpine splits. fit perfectly expect for the magnet being too deep!
so yes, sometimes they measure differently |
[45 queries :: 0.05027 seconds ]
