Factory premo sound- EF
PIMP_LTD
PostPosted: Wed May 28, 2008 5:38 pm    Post subject: Factory premo sound- EF Reply with quote
Hey guys.
I have an EF Fairmont of which i am about to put literally everything of into my EB.
My Question is, the factory stacker is shagged in the Fairmont, is there still replacements available that go straight in?
If not, is there a stacker i can buy that can be wired into- or use a converter plug to wire it in?
Thanks,
Andrew.
FairmontXR6
PostPosted: Wed May 28, 2008 5:51 pm    Post subject: Reply with quote
Go to Northfield at Moorooka, you can get a MP3 stacker that fits the premo head unit (i have looked into this...) all you need is the stacker and a different conector. Although I have not verified this. But have heard of it done.
PIMP_LTD
PostPosted: Wed May 28, 2008 6:06 pm    Post subject: Reply with quote
Oh cool, thanks mate.
I will ring them tomorrow.
Andrew.
PIMP_LTD
PostPosted: Wed May 28, 2008 6:59 pm    Post subject: Reply with quote
Also, did the EF fairmonts have the factory amp standard, or was it optional?
If i don't have the amp, can i wire in my current aftermarket amp to drive my aftermarket sub?
FairmontXR6
PostPosted: Wed May 28, 2008 7:01 pm    Post subject: Reply with quote
If it has the premo sound (double din display) then yep it has the amp, which did the rear speakers and sub. I have my aftermarket amp and sub pluged into it, works perfectly.
PIMP_LTD
PostPosted: Wed May 28, 2008 7:04 pm    Post subject: Reply with quote
oh ok, i must have the mid series then, its a single din.
Can i still wire in my kenwood amp to it? I plan on just running the other speaker off the factory HU and wiring, but need the sub hooked up somehow.
FairmontXR6
PostPosted: Wed May 28, 2008 7:51 pm    Post subject: Reply with quote
Did u check to see if the amp was fitted anyway?
Its in the boot on the drivers side behind the carpet panels.
PIMP_LTD
PostPosted: Wed May 28, 2008 8:05 pm    Post subject: Reply with quote
No i haven't been able to, the car is sitting at my dads place. I'll have to check on the weekend.
Alternativly i could unhook the rear speakers, and use thier feeds as a high input for the amp if i don't have the factory one?
Thanks
Andrew.
outlawxr6
PostPosted: Thu May 29, 2008 12:38 pm    Post subject: Reply with quote
If it is a single din unit it is the mid series and won't have an amp and you won't be able to connect an amp to it properly.
Yes a mp3 stacker is available and does work, this has been discussed on here loads of times as to what you need to make it work....
PIMP_LTD
PostPosted: Thu May 29, 2008 4:47 pm    Post subject: Reply with quote
Yep, i rang northfield today and can get a stacker and the required cable.
Can i use the rear speaker outputs from the headunit as i high input into the amp? I can't see why that would be a problem. I never sit in the back, so the rear speakers can blow me.
outlawxr6
PostPosted: Fri May 30, 2008 2:48 pm    Post subject: Reply with quote
Yes that will work, but it is a poor option really as the headunit's built in amp is realively high in the distortion factor and then your new amp will then amplify this distortion.... but it will work...
PIMP_LTD
PostPosted: Sat May 31, 2008 4:30 pm    Post subject: Reply with quote
Cool cool, that'll do the EB fine.
The other car has the good sounds, and i have a great home stereo anyway, so this will be suffiecent.
Thanks for the help guys.
Andrew.
[39 queries :: 0.03448 seconds ]
