Factory speaker wires?? Which colour pos and neg?
PIMP_LTD
PostPosted: Wed Jun 11, 2008 6:33 pm    Post subject: Factory speaker wires?? Which colour pos and neg? Reply with quote
Hey guys.
After my EB EF conversion, i'm currently fitting the factory premo headunit, and i am about to wire in my amp to the rear channels, and my new door speakers to the front channels.
The LF speaker wire colours are orange/light green and orange black
The RF speaker is grey/green and grey black
The LR is pink/green and pink/black
And the RR is blue/red and blue/black.
My question is, which is positve and which is negative???
I can't find it anywhere, not even in the factory manuals!
Thanks guys.
Andrew.
knowsfords
PostPosted: Wed Jun 11, 2008 7:38 pm    Post subject: Reply with quote
Simple, black is almost always earth/negative.
PIMP_LTD
PostPosted: Wed Jun 11, 2008 7:40 pm    Post subject: Reply with quote
Cool, thats what i was hoping.
Thanks mate.
Andrew.
duderat
PostPosted: Thu Jun 12, 2008 11:02 pm    Post subject: Reply with quote
ive just wired in my 6x9's in the el and i joined the black striped cable from the pioneer wire to the black striped factory wire. i just thought that they matched. the pioneer wire with the black stripe goes to the positive on the speaker. i thought that if you wired the positives to the negatives that you wouldnt get any bass because it would be cancelled out or something but my speakers have bass... whats the go
PIMP_LTD
PostPosted: Fri Jun 13, 2008 8:20 am    Post subject: Reply with quote
Yeah i'm still a little confused.
The old stereo in it (installed by previous owner) was using the black stripe in the cars wiring as the positive, and it sounded fine.
Yet every other stereo on the planet uses the black stripe as neg. I also put my multimeter on the wires while the swtereo was playing, and it said the black stripe in the car was positve when running off the factory headunit. ???
outlawxr6
PostPosted: Sun Jun 15, 2008 12:14 am    Post subject: Reply with quote
That only applies if 1 speaker is wired out of phase, if they are all wired the same then you won't get cancellation.
The easy way to confirm the orientation of the black stripe is to simply use a AA battery (no bigger) and attach it to the speaker wiring in question and the wire attached to the + terminal is the positive wire if the cone moves out, if the cone moves in then the wire attached to the + terminal on the battery then that is the - wire.
Easy.....
PIMP_LTD
PostPosted: Sun Jun 15, 2008 9:27 am    Post subject: Reply with quote
Thanks outlaw,
i performed this, and turns out ford indeed used the black stripe as positive wire, why the f**K they did that i'll never know.
Confirmation also came from when i look at the dash tweeter wiring, the ford black stripe wire goes the the positive terminal on the pioneer tweeters.
So anyway, the factory unit is now wired into my new front speakers, and the rear channels are now driving my sub amp and sub, and it sounds good enough for a pretty much factory system.
Thanks guys.
muncher2002
PostPosted: Sat Aug 09, 2008 9:34 am    Post subject: Reply with quote
Hello
I am kind of new to ford mods I have owned a ford for a week now, I am having problem wiring up the radio properly
This is my question my car is a ef Fairmont the original plug was removed and the wires joined there are a couple of wires not connected
Dose any one know that all the wires on the ef radio harness do?
Tom
muncher2002
PostPosted: Sat Aug 09, 2008 9:50 am    Post subject: Reply with quote
The body is negative earth so if you wire them up properly it saves problems i.e. Popping noise when you adjust the volume (that is why I had to redo my radio the colours and positions were all wrong)
When crossing over speaker wires use +left rear and +right rear it kind of combines the sound when using a sub and an amp. Amps are wired up for that inside and will not (should not) blow. Doing this to a head unit might not be a good idea. Sub are normally isolated from the car using foam, plastic bracket or a sub box so there is no earthing
dude rat wrote:
I’ve just wired in my 6x9's in the el and I joined the black striped cable from the pioneer wire to the black striped factory wire. I just thought that they matched. The pioneer wire with the black stripe goes to the positive on the speaker. I thought that if you wired the positives to the negatives that you wouldn’t get any bass because it would be cancelled out or something but my speakers have bass... what’s the go
TickFordEFXR6
PostPosted: Sat Aug 09, 2008 12:14 pm    Post subject: Reply with quote
based on ef 94 and up
i found this for u guys it might help
Wiring for Low and Mid Series Decks
Main Wiring Plug - 12 Pins
Pin 1 Grey / Dark Green Positive (+) Speaker Line for the Right hand side Front speakers (Drivers Side)
Pin 2 Blue / Light Green Positive (+) Speaker Line for the Left hand side Front speakers (Passenger Side)
Pin 3 Brown Button Backlighting (Park Lamps power)
Pin 4 Dark Green / Yellow Constant Battery Voltage (+ Positive power)
Pin 5 Dark Blue / White Accessories Power (As taken from the Ignition switch)
Pin 6 Light Green Telephone Mute (Factory Telephone System)
Pin 7 Red / Dark Blue Power Antenna Output (Positive Trigger) Used to extend the power antenna
Pin 8 Dark Blue / Red Instrument Cluster LCD Backlight and Dimming Signal (Negative)
Pin 9 < !-space-> < !-space->
Pin 10 < !-space-> < !-space->
Pin 11 Blue / Black Negative (-) Speaker line for the right hand side Front speaker
Pin 12 Grey / Black Negative (-) Speaker line for the Left hand side Front Speaker
Secondary Wiring Plug - 8 Pins (Rear Speakers)
Pin 1 < !-space->
Pin 2 < !-space-> < !-space->
Pin 3 Pink / Dark Green Positive (+) Speaker Output for the Rear Left Hand (Passenger) Side Speaker
Pin 4 Pink / Black Negative (-) Speaker Output for the Rear Left Hand (Passenger) Side Speaker
Pin 5 < !-space-> < !-space->
Pin 6 Dark Blue / Red Positive (+) Speaker Output for the Rear Right Hand (Drivers) Side Speaker
Pin 7 Dark Blue / Black Negative (-) Speaker Output for the Rear Right Hand (Drivers) Side Speaker
Pin 8 < !-space-> < !-space->
Wiring for High Series (Premium) Decks (FAIRMONT GHIA, FAIRLANE series EF / EL / NF / NL / DF / DL
muncher2002
PostPosted: Sat Aug 09, 2008 3:25 pm    Post subject: Reply with quote
thanks for your reply will have a look tommrrow make sure it is rite
TickFordEFXR6
PostPosted: Sun Aug 10, 2008 10:59 pm    Post subject: Reply with quote
so how did ya go ?????????
muncher2002
PostPosted: Sun Aug 10, 2008 11:07 pm    Post subject: Reply with quote
i wired it up rite but i have 3 extra wires left
i will take a picture everything sounds rite but it is these extra wires and it i strongly belive there speaker wires not the phone wire or power ant it is strange i will take a picture
picture is worth 1000 words and then try and see if i can post it here
muncher2002
PostPosted: Sun Aug 10, 2008 11:52 pm    Post subject: Reply with quote
i dont know why they just didnt get the addapter wires from strathfield or jb
 Description:
 Filesize:  57.83 KB
 Viewed:  311 Time(s)
 Description:
 Filesize:  40.92 KB
 Viewed:  313 Time(s)
muncher2002
PostPosted: Mon Aug 11, 2008 10:24 am    Post subject: Reply with quote
still having problem as the colours of my loom don't match the ones listed above
my car is a 94 ef could it be posible that i have ed loom for the radio???
this is what i have and what is connected
Grey / green = (+) right hand front
Grey/ black = (-) right hand front
Blue / red (1 silver dot) = (+) right hand rear
Blue / black = (-) right hand rear
Orange / green= (+) left hand front
Orange / black = (-) left hand front
Pink / green = (+) Left hand rear
Pink / black = (-) Left hand rear
Red / blue = unknown (connected to power ant I think)
The next 3 wires are thicker then the rest
Green / yellow = Power
Blue / white = Power
Black (2 silver dots) = power
Brown (1 silver dot) = unknown
Light green (2 silver dots) = unknown
Blue / red (2 silver dots) = unknown
There is a 8 pin plug near it too I think it might go to the back there all thin wires like the speaker wire
1 = brown
2 = green / yellow
3 = grey / black
4 = not connected
5 = blue / red
6 = blue / black
7 = red
8 = orange / green
everything appears to be connected but i still nave no dash speakers
muncher2002
PostPosted: Mon Aug 25, 2008 1:27 pm    Post subject: Reply with quote
now that i have the wires all hooked up and the radio adjusted corectly the speakers on the dash work it was just in the adjustment
so it turns out i did it right the first time just not adjusted rite
but the strange thing is the incorrect collours on hthe factory loom but as i have listed them i hope it will help someone else
thankyou to eveyone who replayed to my questions
[47 queries :: 0.08698 seconds ]
