Fat a*** tyre's!!!
FLASH
PostPosted: Wed May 14, 2008 1:02 pm    Post subject: Fat a*** tyre's!!! Reply with quote
Hi Guys, ive got a set of 15" x 8" and 15"x4" drag rims and i want to run fats on the back. My question is what is the largest tyre some one has run on an E series? im looking at a 275 but their about 11" across and the guard has about 12" clearance. i am running airshocks so i can pump it right up but i would prefer not to. any help would be great.
alfy
PostPosted: Wed May 14, 2008 1:03 pm    Post subject: Reply with quote
i think cjh said he had a set of 295's fitted to 15's on his mates ute?
FLASH
PostPosted: Wed May 14, 2008 2:15 pm    Post subject: Reply with quote
Wow thats pretty fat. what model ute was it?
Tocchi
PostPosted: Wed May 14, 2008 4:08 pm    Post subject: Reply with quote
ive got 295/50/R15s on my EF
they fit easily, rolling guards is recommended.
note: stock tickford height
FLASH
PostPosted: Wed May 14, 2008 4:32 pm    Post subject: Reply with quote
FK.... Thats looks tuff from the a*** aye! they slicks or semi's? is that a XR5 to the right?---------------------^^^
how does that go?
sorry to many questions (excited about 295's!)
EFFalcon
PostPosted: Wed May 14, 2008 4:54 pm    Post subject: Reply with quote
i got 265's on the back of my EF, but its pretty low and needed some work on the guards.
also on 18" wheels.
Tocchi
PostPosted: Wed May 14, 2008 9:43 pm    Post subject: Reply with quote
how does that go?
yes thats a XR5T. it goes alright, pity its FWD.
but its chopped a VY (series 2) Monaro and a VY Senator Signature icon_smile.gif
FLASH
PostPosted: Wed May 14, 2008 10:26 pm    Post subject: Reply with quote
sweet s**t! ive seen the episode on top gear with the xr5 and when they where lifting the back wheel off the ground on a wet track taking corners i was impressed. speaking of back wheels (back on topic) what brand are you running, i think i may need something sticky. ive got some M/T slicks 11.5 x 26 but i think i may run some street tyre's giving her that pro street look. skinny front big back, but i dont want to pay a fortune for them.
alfy
PostPosted: Wed May 14, 2008 10:30 pm    Post subject: Reply with quote
XF IIRC
Tocchi
PostPosted: Wed May 14, 2008 10:39 pm    Post subject: Reply with quote
Coopers i think. a guy can get them wholesale for me for $300 a side.
FLASH
PostPosted: Wed May 14, 2008 11:03 pm    Post subject: Reply with quote
Your spec sheet looks good whats your rwk? do you still manage to smoke the fats when putting the power down. i really want traction rather than a burnout car.
Tocchi
PostPosted: Wed May 14, 2008 11:53 pm    Post subject: Reply with quote
the car is getting a tune 2moro, either 10 or 11psi, depending on what the tuner feels comfortable with.. (mick @ ovaboost)
the car cant do skids
http://img404.imageshack.us/img404/2623/0405081101sj1.jpg
better specs
EMS 8860, GReddy Profec B electronic boost controller, Autometer 'Cobalt Series' boost gauge
Wade 1636 cam, ACL Race Series bearings, ACL piston rings, MSL 3 layer metal head gasket, 1 piece rubber sump gasket.
Shiftkit, 3.73 diff gears, Lokka
Garret T04e (front A/R 0.70, rear 1.15, front wheel 84mm, rear 75mm), custom exhaust manifold (ceramic coated), Tial 44mm wastegate, 1.75" screamer pipe (ceramic coated), 3" stainless intake piping, 600x300x76 intercooler, K&N pod filter, 4" intake off the turbo to pod, XR6T BOV, braided stainless/telfon oil lines, braided stainless/teflon turbo to wastegate vacuum line, braided stainless/teflon catch can breather lines, stainless catch can with K&N breather filter, Sonic turbo bag, ACL heat shielding, 3.5" dump pipe, 3" exhaust with 2 hotdogs
Bosch 040 fuel pump, 52Lb injectors
schnoods
PostPosted: Thu May 15, 2008 12:06 am    Post subject: Reply with quote
FLASH
PostPosted: Fri May 16, 2008 12:24 pm    Post subject: Reply with quote
Thats a great spec sheet, im running.
fully rebuild engine with:
jp racing H/V oil pump
k&n pod
holset turbo 1.04 a/r
braided feed line, steel drain with h/t silicon flex joins
snort stg 4 stainless tuned lenght manifold
44mm wastegate 1" screamer, ajustable BOV
autogauge smoked series boost gauge/air fuel ratio gauge
led shift light with digital tach
port polished head (i think its el) with new valves (std size) crow H/D double valve springs
camtech stg 1 regrind cam (stage 2 cms on the way with venier cam gear)
el manifold with bbm reconfigued to open under boost.
no intercooler i have a Cryo 2 cold air intake system insted (yummm no lag icon_smile.gif
Zex 55 hp nitrous shot
full msd 6al ingnition system
walbro 255L fuel pump
malpassi fuel reg
std injectors (i tryed to run 44lb but they just flooded the motor)
ed xr6 ecu with capa chip (i have a haltech ecu but dont have time to hook it up at the moment)
t5 and 3.7 gears & lsd tightened to 160nm
s**t i think thats its???
FLASH
PostPosted: Sun May 18, 2008 4:19 pm    Post subject: Reply with quote
Got M/T slicks on her now!!!!
nice and tuff.
i don't think ill break traction on these babys!!!
 Description:
 Filesize:  419.26 KB
 Viewed:  11 Time(s)
 Description:
 Filesize:  317.75 KB
 Viewed:  7 Time(s)
 Description:
 Filesize:  221.17 KB
 Viewed:  7 Time(s)
dilberto
PostPosted: Sun May 18, 2008 7:00 pm    Post subject: Reply with quote
f**k they stick out far
FLASH
PostPosted: Sun May 18, 2008 7:19 pm    Post subject: Reply with quote
Yeah, thank fk for air shocks!
fordfreak ef
View User Gallery (28)
PostPosted: Sun May 18, 2008 10:15 pm    Post subject: Reply with quote
FLASH
PostPosted: Mon May 19, 2008 1:20 am    Post subject: Reply with quote
i think i may need to request deisel put on the burnout part of the drag strip instead of water otherwise she wont spin icon_lol.gif ,
jaymeister
PostPosted: Mon May 19, 2008 11:13 am    Post subject: Reply with quote
got and XD ute with 295's on 14x8 rims lol
[49 queries :: 0.06665 seconds ]
