brenjabu Fordmods Newbie
Age:55 Posts: 3 Joined: 22 Dec 2006 Location: cairns QLD, Australia
Posted: Fri Dec 29, 2006 10:16 pm Post subject: Faulty Smartlock - EL Fairmont |
| Hi Guys, when I lock up with the remote, the doors open again on their own & horn beeps! I have to lock with the key sometimes. This seems to only happen when the car has been in the sun too long, sounds funny but true!! I hope someone can help! ....Regards, brenjabu.[/b] |
Mitch_ Cruise Moderator
Age:20 Posts: 5891 Joined: 05 Nov 2004 Location: Streets of Brisvegas QLD, Australia
Posted: Fri Dec 29, 2006 10:17 pm Post subject: |
not smartlock, but the central locking actuators...how good are you with electronics
you can retrofit the jaycar central locking, and its trouble free then i got it in my car! |
Posted: Fri Dec 29, 2006 10:39 pm Post subject: |
| Hi Mitch, thanks for your response! Can I get any "instruction doc" on how to do this??!! ..brenjabu. |
Posted: Fri Dec 29, 2006 10:59 pm Post subject: |
| Thanks again Mitch! I'll let you know how I go! Regards, brejabu. |
richard williams Fordmods - Getting Side Ways
Age:38 Posts: 535 Joined: 22 Sep 2005 Location: melbourne VIC, Australia
Posted: Fri Jun 08, 2007 4:27 pm Post subject: |
| The smartlock system is pretty good and the actuators are common and easy to service. I have repaired mine before easily. |
Age:31 Posts: 988 Joined: 23 Dec 2004 Location: Mildura VIC, Australia
View User Gallery (25)
Posted: Fri Jun 08, 2007 4:41 pm Post subject: |
what happens is the grese in the door mechanisims drys out, and makes it hard for the acuators to move them into the lock position, i have found if you spray them with a dry lube like dry glide, comes in a green airesole basicly its graphite in a tin... the same stuff you spray in the window guides to help the windows to go up n down easily..
ghia97 Fordmods Tyre Shredder
Posts: 397 Joined: 31 Aug 2007 Location: Melbourne VIC, Australia
Posted: Sun Sep 30, 2007 12:23 am Post subject: |
| dry glide worked for me. Efs were prone to playing up in hot weather even when new. Hadnt heard it with el`s though. |
Ragvaror Fordmods Stock as a Rock
Age:22 Posts: 173 Joined: 07 Sep 2006 Location: Hobart TAS, Australia
Posted: Sat Aug 30, 2008 12:33 pm Post subject: |
My ef smartlock is playing up also. Driver door actuator doesnt seem to work at all, so when i try to lock the car with the fob, the other doors try to lock, it detects that the drivers side hasnt moved, so they all pop back up and my horn goes off. It only started happening after my batter went flat...
I might just pull the door apart and blast it with some silicone lube or something. |
