Age:31 Posts: 914 Joined: 23 Dec 2004 Location: Mildura VIC, Australia
View User Gallery (25)
Posted: Wed Jan 16, 2008 8:42 am Post subject: fitting ECU with Smartlock into non smartlock car???? |
before you tell me "search is yor friend" dont bother, i have already done so, and did not find what i was after..
i have read i will require a smartlock bypass.. where can i get one of these from, or diagram to make??
Cheers. |
Posted: Sun Jan 27, 2008 7:07 pm Post subject: Re: Smartlock bypass |
thanks for the link but $96.70 is a bit much.
I'd rather make my own.. if any one can supply some wiring scrmatics that would be much appreciated.. |
Age:29 Posts: 710 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Mon Jan 28, 2008 7:22 am Post subject: Re: Smartlock bypass |
| Quote: |
Mate, if the amount is too much for you maybe you should do all the research and development yourself instead of asking for schematics and wiring diagrams? |
banarcus Fordmods Tyre Shredder
Age:33 Posts: 331 Joined: 29 Nov 2004 Location: Kurri Kurri NSW, Australia
Posted: Mon Jan 28, 2008 9:54 am Post subject: |
| OFF TOPIC and please forgive me all. 66 coupe, can you send me a PM regarding a EF/EL TCM eliminator for a manual tranny equipped car should one exist? I think a simple 555 ic could do the trick? |
Posted: Mon Jan 28, 2008 10:05 am Post subject: Re: Smartlock bypass |
| 66 coupe wrote: | | Quote: |
no need to be a prick about it.. i come to this site to learn how to do things buy my self and not fill your pockets with $$$.. |
Posted: Mon Jan 28, 2008 10:11 am Post subject: |
im not the ebay seller selling that item so dont worry about filling my pockets with $$$ if you buy that module on ebay.
.... and im not being a prick about it, im just stating the obvious.
if you do want to learn how to do things then by all means go out and buy the right tools and research it all and make your own device, but in all honesty, your much better off paying the $ for a module where the hard works already done for you |
ray185 Fordmods Newbie
Posts: 8 Joined: 11 Jan 2008 Location: Brisbane QLD, Australia
Posted: Wed Feb 27, 2008 6:11 pm Post subject: |
I've bought one off 66 coupe and it works great, as opposed to the one I bought off ebay....
Thanks for the great service 66 coupe  |
Posted: Wed Feb 27, 2008 6:33 pm Post subject: |
| no dramas, i got mine from Muzza, its on its way.. and for alot less than $96.70... |
gnasher Fordmods Newbie
Posts: 3 Joined: 09 Oct 2007 Location: Perth WA, Australia
Posted: Wed May 07, 2008 11:59 am Post subject: |
sexyr6 - how much did you pay for the bypass
I could do with one too but have no idea about wiring etc, does it come with instructions? and where can I get one from, my ef is giving me the *!X?'s
thanks in advance
gnasher |
Posts: 2857 Joined: 31 Oct 2005 Location: . QLD, Australia
View User Gallery (28)
Posted: Wed May 07, 2008 12:39 pm Post subject: |
why would you want one for your EF? its all setup with smartlock, no need to get rid of it, just makes it easier to steal the car...
im in need of one if someone has one for sale cheap |
Posted: Wed May 07, 2008 1:34 pm Post subject: |
| because the module is playing up, car has an intermittent start problem, cured by banging on the dash at about knee level, figured if I can bypass it I'll be able to start the thing, garage has quoted $400 for a new BEM module. |
Posted: Wed May 07, 2008 1:47 pm Post subject: |
| check out ebay, i saw a few BEM's go on ebay for under 20 bucks. just make sure you get the right one for your model |
Posted: Wed May 07, 2008 9:38 pm Post subject: |
| gnasher wrote: | | because the module is playing up, car has an intermittent start problem, cured by banging on the dash at about knee level, figured if I can bypass it I'll be able to start the thing, garage has quoted $400 for a new BEM module. |
most likley nothing wrong with your BEM just the connection, remve it and clean the terminals and replace.. |
Posted: Wed May 07, 2008 9:40 pm Post subject: |
| huggiebear wrote: | | im in need of one if someone has one for sale cheap |
contact muzza he's a member on here, he will fix you up with a bypass module.. |
Posted: Wed May 07, 2008 9:41 pm Post subject: |
| repco sell a circuit board spray cleaner. i used it on my old altenator when it was dieing. basically remove the unit, spray and let dry, replace and hey presto. and only like 4 bucks a can |
Posted: Thu May 08, 2008 5:10 pm Post subject: |
| thanks - I'll try cleaning it first as suggested, it's been starting fine the last couple of days |
L1STED Fordmods Oompa Loompa
Age:20 Posts: 33 Joined: 01 Dec 2006 Location: melbourn VIC, Australia
Posted: Sun May 11, 2008 6:03 pm Post subject: |
| hi guys i hav the same thing but i got my smart lock overide from jim mock the wiring is easy u wire it up to the ECU not at the bem |
garsiph Fordmods - Smokin em up
Age:27 Posts: 209 Joined: 14 May 2005 Location: Perth WA, Australia
Posted: Sun May 11, 2008 6:48 pm Post subject: |
I have two BEM modules for GLI EL's not EF's
The units are diffrent. If anyone needs a EL one pm me. |
