[b]FMX HELP, NOt pumping oil[/b]
steiphen
PostPosted: Tue Jan 04, 2005 1:31 pm    Post subject: [b]FMX HELP, NOt pumping oil[/b] Reply with quote
Can someone please help me, i just put another FMX in, with a new torque convertor, new lines, and a new cooler, after the last box, filled with water on a flooded road.
Everything is put back as it come off..... 10 litres of oil, tail shaft fitted, gear lever connected to transmission.
If i pull the hose off the oil cooler, oil hasnt travelled in there at all.!!
I also put a new filter on.
HELP PLEASE [u][/u]
EBXR8380
PostPosted: Tue Jan 04, 2005 1:47 pm    Post subject: Reply with quote
I have to ask but you did bolt the converter up ???
Sorry I don't mean to belittle you, but it has happened...
steiphen
PostPosted: Tue Jan 04, 2005 1:50 pm    Post subject: Reply with quote
Yeah, its ok, convertor bolted up!!!! I think it might be stuffed, its not a new one like i said, its second hand, my old one was ok, but its been in the weather, got water in it.
EBXR8380
PostPosted: Tue Jan 04, 2005 1:56 pm    Post subject: Reply with quote
Umm ?? I'm no FMX or auto expert but it MAY just be the converter? Wash/ clean the old one ??? Did you fill converter with atf before installing ?
steiphen
PostPosted: Tue Jan 04, 2005 1:59 pm    Post subject: Reply with quote
I drained the old oil out of it,b ut didnt refill it, shouldnt it pump itself
steiphen
PostPosted: Tue Jan 04, 2005 2:02 pm    Post subject: Reply with quote
if i take the starter motor off, and remove the cover to turn the convertor i can fill it that way? through the drain hole????
steiphen
PostPosted: Tue Jan 04, 2005 2:15 pm    Post subject: Reply with quote
what if i jack the back of the car up, would the oil run into the convertor?
EBXR8380
PostPosted: Tue Jan 04, 2005 2:21 pm    Post subject: Reply with quote
Don't think so??
There is a plug on converter ? Check ??
steiphen
PostPosted: Tue Jan 04, 2005 2:29 pm    Post subject: Reply with quote
yeeah there is, but its against the fly wheel,
EBXR8380
PostPosted: Tue Jan 04, 2005 2:33 pm    Post subject: Reply with quote
Undo the four bolts that hold it to flex plate, slide converter back and try...???
steiphen
PostPosted: Tue Jan 04, 2005 2:45 pm    Post subject: Reply with quote
ok, ill see how i go
steiphen
PostPosted: Tue Jan 04, 2005 2:52 pm    Post subject: Reply with quote
ok, it is possible to fill up when connected to the fly wheel, the fly has a hole in it for the draid plug to slot through. I touched the convertor, it was very hot, as its been running for a while... which tells me there is hot oil in it, but its not pumping in to the lines? hmmmmmm
steiphen
PostPosted: Tue Jan 04, 2005 2:53 pm    Post subject: Reply with quote
i got the back wheels off the ground.... when i rev it hard, the wheels spin slowly!!!! what does tha mean?
Interceptor
PostPosted: Tue Jan 04, 2005 7:16 pm    Post subject: Reply with quote
have you checked the fluid level after running it?if the converter was dry, it might've taken all the fluid in the pan to fill the converter
Macca
PostPosted: Tue Jan 04, 2005 9:09 pm    Post subject: Reply with quote
If none of the ideas posted works for you so far, pull the FMX back out, spin the torque converter, does it feel like it is turning something and located right into the bell housing, sometimes if the torque converter was not located properly before trying to refit the auto, you can break the pump. (not trying to scare you)
And you don't need to refill the torque converter, the drain plug is just that, a drain plug, if the transmission is full of oil the pump will pump oil into it.
steiphen
PostPosted: Sat Jan 08, 2005 8:13 am    Post subject: Reply with quote
The latest.... I drained the oil out of the convertor........... BROWN s**t came out,,,, so then i took th pan off to check the oil i put in it, still red, the filter is fine? The oil isnt going into the convertor. So i putoil in the convertor with a hand pump.. Wheel spin about a inch a minute...
The cooler lines now have a few small drops in it..
Could it be a blockage?
steiphen
PostPosted: Sun Jan 09, 2005 3:15 pm    Post subject: HHEEELLLLPPPPP PLEASE FMX STILL NOT PUMPING Reply with quote
ive tried everything, and nothing is working!!!!!
steiphen
PostPosted: Sun Jan 09, 2005 3:18 pm    Post subject: HHEEELLLLPPPPP PLEASE FMX STILL NOT PUMPING Reply with quote
steiphen
PostPosted: Thu Jan 13, 2005 5:32 pm    Post subject: PROBLEM FOUND Reply with quote
well, we droped the box out..... i read a fmx book with my mate ken, who i meet on this site.... he figured out it was the low pressure pump, which is bolted in the bell housing...,,, The large cog was cracked!!!!! not sure how, but it has something to do with me forceing the bell housing bolts in because it wasnt lined up properly!!! so next time a dowel wont line up... dont force it!!!!
[46 queries :: 0.70979 seconds ]
