zl_brettlez Fordmods Oompa Loompa
Age:27 Posts: 29 Joined: 05 Nov 2004 Location: Sydney NSW, Australia
Posted: Mon Dec 27, 2004 8:19 pm Post subject: Footwell and Courtesy lights |
hey guys,
how easy is it to place footwell and courtesy lights on the roof in a standard EA? (wagon) and also a fairmont interior light..... is it a matter of more wires or allot more than that?
cheers |
Low EL Fordmods Tyre Shredder
Age:28 Posts: 311 Joined: 05 Nov 2004 Location: Cairns, Far North Queensland QLD, Australia
Posted: Mon Dec 27, 2004 8:36 pm Post subject: |
| For the footwell lights, you just need the globes and some extra wire (thin stuff will do). The globes/holders are the same as the one under the shifter, and the holes will already be there for them, just twist them in, and solder up the wire under the dash. As for the roof light, i think from memory, you need to add an extra wire or two, but not certain. For the light itself, it should screw straight in. |
Posted: Mon Dec 27, 2004 10:41 pm Post subject: |
What about for a EF sedan then it is the same?
Is there one of Xyphoids docos on it at all? |
Age:21 Posts: 2414 Joined: 05 Nov 2004 Location: Manjimup WA, Australia
Posted: Mon Dec 27, 2004 10:48 pm Post subject: |
| Low Na wrote: | | For the footwell lights, you just need the globes and some extra wire (thin stuff will do). The globes/holders are the same as the one under the shifter, and the holes will already be there for them, just twist them in, and solder up the wire under the dash. As for the roof light, i think from memory, you need to add an extra wire or two, but not certain. For the light itself, it should screw straight in. |
For the courtesy lights, you need a constant power, constant earth, and a switching earth for it to come on only when the doors are open. Theres already a constant power, but the light only comes on when the door switches are shorted to earth. The switch on the dash works in the same way, just shorting to earth. So we have a switched earth, and a constant power, but no constant earth. So just stick a wire straight to bare metal up in the light itself, using one of the mounting screws, and you should be fine. I think it bolts up the same, and should do you fine. Have fun
Oh and by the way, the courtesy/reading lights in the rear are expensive. I replaced both lenses and globe holder parts as the clips were broken off and theyd just hang. They cost me something like 36 dollars each. next time try bluetack  |
Posted: Wed Dec 29, 2004 6:39 pm Post subject: |
ahahaha! dang... i payed nothing for mne! n they were from a wreckers....
n thnkz 4 the info |
[32 queries :: 0.05907 seconds ]
