FORD 5.0LT REVVING PROBLEMS
EACRUISER
View User Gallery (20)
PostPosted: Sun May 11, 2008 6:14 pm    Post subject: FORD 5.0LT REVVING PROBLEMS Reply with quote
HELP PLEASE....
EB XR8 motor and ecu.
Hoping this has happened to someone on the forums, car revs but starts to cut out and sputter over 3,000rpm.
Accelerates but not that well, sputters and coughs above 3,000.
like its hitting a revlimiter or something similar.
any ideas,
Just adjusted the TPS as it was showing 1.4v at idle.
Any ideas with what i should check
DARTHVADER
Donating Member
PostPosted: Sun May 11, 2008 6:32 pm    Post subject: Reply with quote
fuel filter maybe!!!
hans hartman
PostPosted: Sun May 11, 2008 6:46 pm    Post subject: Reply with quote
and the pump,pressure \volume,pressure relief valve
TerroristGHIA
PostPosted: Sun May 11, 2008 6:50 pm    Post subject: Reply with quote
Filter, pump, and TFI module, they would be my first point of call
Brett
Scaffy
PostPosted: Sun May 11, 2008 6:53 pm    Post subject: Reply with quote
Also add plugs and leads to the checklist...
Timmeh
PostPosted: Sun May 11, 2008 7:06 pm    Post subject: Reply with quote
TPS voltage at idle should be .98v
EACRUISER
PostPosted: Sun May 11, 2008 8:25 pm    Post subject: Reply with quote
OK WILL TRY THOSE,
Thanks Timmeh, adjusted it to that. with the guide to tuning the 5.0 in the forums. Hoped that would fix it but still doign it.
Will check the filter etc...
Still able to drive just have to keep the revs low and only a lil bit of throttle. can't go full throttle as it just doesnt want to go anywhere.
do you think it could be a stuffed maf, checked it and the wires look clean & good so yeah?????
TerroristGHIA
PostPosted: Sun May 11, 2008 8:54 pm    Post subject: Reply with quote
Unplug MAF, see if there is any difference. Without MAF it will be a slug down low, due to little if any timing advance
Brett
Alex_01
PostPosted: Tue May 13, 2008 12:35 pm    Post subject: Reply with quote
Mine cuts out at about 3000rpm aswell, but doesnt splatter as you said, it just accelerates a lot slower, and then it will kick back in again..
[36 queries :: 0.03552 seconds ]
