sly Fordmods - Smokin em up
Age:45 Posts: 267 Joined: 09 Feb 2006 Location: Newcastle NSW, Australia
Posted: Sat May 03, 2008 10:26 pm Post subject: |
| It'll be good for tweaking up the tune a bit for the higher octane of LPG. |
Age:40 Posts: 280 Joined: 03 Aug 2007 Location: Mackay QLD, Australia
Posted: Sun May 04, 2008 1:29 pm Post subject: Tuners |
| The flash units on offer for the AU range from Raptor |
Posted: Sat May 10, 2008 7:04 pm Post subject: Raptor ProStreet AU kit |
Now most of the testing is complete here it is
Raptor ProStreet - Suit AU Falcon 6 - all series
Power - 260rwhp and will be marketed as a 260kw kit
Gives around 500Nm of torque on stock engine
Boost will be 8 - 9 psi
Flash tuner box or Flash tuner 2 are offered
Quality generic tune
Fitting instructions
3 hrs or thereabouts to fit it
Only very basic tools needed except for circlip pliers to remove the circlip that retains the fuel pressure reg
New 36lb injectors supplied
MAP sensor cheater supplied
High strength steel bracket for excellent alignment rigidity |
Posted: Sun May 11, 2008 1:28 pm Post subject: Kit Pricing |
Have worked out a price for introductry special, see website for closing date http://www.raptorsc.com.au/kits.php?id=36
Buy now and save (where have you heard that before )
AU intech 4.0 ProStreet is $4700 with flash tuner
AU intech 4.0 ProStreet is $4200 no flash tuner (load tune into your flash)
AU VCT $5000 with flash tuner
AU VCT $4500 no flash tuner (load tune into your flash)
IF YOU WANT A LIVEWIRE FLASH UNIT (rather than flash box or Flash 2) then you can have it for ADDITIONAL $600
Freight for most east coast destinations is between $60 - $100 by NQX Road Express
* please note that maybe not in every case will the Flash 2 be supplied, will depend on stock levels, will of course otherwise be Flash box. First in best dressed
Posted: Tue May 13, 2008 9:23 pm Post subject: LIVEWIRE TUNER |
Is there anyone who is wanting the LIVEWIRE flash unit, had some enquiry's today about that.
Will let you all know what the additional cost of this will be soon as I know |
sikford Fordmods Tyre Shredder
Age:21 Posts: 378 Joined: 27 Jan 2007 Location: Melbourne, Carrum Downs VIC, Australia
Posted: Wed May 14, 2008 10:02 am Post subject: |
what has been some of the best results you guys have had with the charger kits on the VCT motor, also i see these kits are rated to a certain power, what would u recommend for doing a big power/torque setup?
cheers |
Bomber Fordmods - Getting Side Ways
Age:24 Posts: 622 Joined: 06 Nov 2004 Location: Rosebud VIC, Australia
Posted: Wed May 14, 2008 7:47 pm Post subject: |
| sikford wrote: | what has been some of the best results you guys have had with the charger kits on the VCT motor, also i see these kits are rated to a certain power, what would u recommend for doing a big power/torque setup?
cheers |
Trust you to stick your nose in here
What PSI are they chargers capable of is 9psi the limit of if yo have the engine and engine managment can you push them further????
Mark |
Posted: Thu May 15, 2008 8:59 am Post subject: |
| Bomber wrote: | | sikford wrote: | what has been some of the best results you guys have had with the charger kits on the VCT motor, also i see these kits are rated to a certain power, what would u recommend for doing a big power/torque setup?
cheers |
Mark |
lol, smartass...havnt been on here for ages man, just thought i'd actually make a post,haha |
Posted: Thu May 15, 2008 10:47 am Post subject: |
Thanks Sly think ill stick with my whipple plans but still interested in the tuning side of things. |
badcooky Fordmods - Smokin em up
Posts: 264 Joined: 27 Jan 2007 Location: Toowoomba QLD, Australia
Posted: Thu May 15, 2008 6:03 pm Post subject: |
| Tim old bean, i service NQX trucks and trailers and i'm tellin' ya get another carrier. |
Posted: Fri May 16, 2008 7:27 am Post subject: Drive by shooting |
Well not quite as the title suggests, went out this morning for the drive by vid captures ......... got all set up .......... camera on tripod ....... go to turn it on ........ DEAD lol. Cooler than normal this morning and the batteries never perform well when cool.
Anyhow they on the charger (not the supercharger lol) and will be charged nice for tomorrow's little effort  |
Posted: Fri May 16, 2008 7:32 am Post subject: |
Bomber
I can supply you a tuning package if you like that includes our MAP cheater and whatever flash unit you like. That way you bolt your stuff on etc then just tun er up like we do. |
Posted: Fri May 16, 2008 12:52 pm Post subject: |
| Raptorsc wrote: | Bomber
I was thinking about that option, How hard is it to up the boost for the tune. Im looking at initially running 6 to 7psi and then on a built engine around 16psi is the map cheater capable of achieving this??
Mark |
Posted: Fri May 16, 2008 4:00 pm Post subject: Re: Drive by shooting |
| Raptorsc wrote: | | Well not quite as the title suggests, went out this morning for the drive by vid captures ......... got all set up .......... camera on tripod ....... go to turn it on ........ DEAD lol. |
Thankfully my camera experience went more smoothly than that. It's all good and all go! |
Posted: Sat May 17, 2008 7:21 am Post subject: Today's update |
Last night the ute was put in at tuner for final adjustments to the shift quality on the auto gearbox.
We also made some changes to the drive belt and some more dyno runs will be performed this morning.
Should be pretty much at its final state by this afternoon.
Stay tuned  |
Posted: Sat May 17, 2008 12:50 pm Post subject: New dyno results |
Here are two new charts, one is metric one is imperial, take your pick.
What you are seeing is the tune which the kit will go out with - the 193rwkw and the hotter tune which will require octane booster for safe operation, good for dyno days or drag. The 2nd tune is optional at time of purchase.
We didn't sort the auto to my satisfaction yet, another attempt will be made this next week, its only under full power that I would like it to shift more decisively/firmly, otherwise it drives perfect.
Enjoy |
Posted: Sat May 17, 2008 1:01 pm Post subject: Larger version |
Realising some might want to be able to make a closer inspection
Here is a large file size
Enjoy the constant torque, makes a car nice to drive. Just on 1000 lbs of tractive effort there for over 1000rpm of the power band and then not much less for rest of it which .......... I like a lot
Not too sure about the exactness of the rpm measurement, the ute goes to 5700rpm yet this chart shows 5200rpm. Dyno Dynamics unit and its brand new, anyhow it will have to do
Posted: Sat May 17, 2008 1:31 pm Post subject: |
| what sort of 1/4 would you expect to achive with the power its creating atm?..not too bad a result.what sort of boost is it on? |
Posted: Sat May 17, 2008 2:14 pm Post subject: Boost and times |
There is enough torque and power there to run a 13 of some sort, anyone else got an opinion on that?
The boost is just on 8psi, curve shape has changed since we changed to a shorter drive belt now, so no more problems there at all. I had asked for a no intake pipe run but the tuner forgot, will do that next week. I know it makes more boost then as well. |
[47 queries :: 0.06022 seconds ]
