opto Fordmods - Getting Side Ways
Age:44 Posts: 712 Joined: 11 Nov 2004 Location: Adelaide SA, Australia
Posted: Sat Jan 08, 2005 4:18 pm Post subject: |
| I disagree with allthat BS I recon an 88 Degree thermostat and a 3 core radiator, the cooler the better, Its heat in the engine which does mor damage, especially if you get a hot spell you put teh air con on and watch your temp increase. (37 degree and more), the radiator hoses pop engine cooks or head gasket blows. |
pepsimax Fordmods - Getting Side Ways
Age:39 Posts: 400 Joined: 05 Nov 2004 Location: kirra QLD, Australia
Posted: Sat Jan 08, 2005 11:06 pm Post subject: |
another thing is the thermostat will open and close according to the coolant temp.
the more air passing throught rediator will cool it down,,then the thermostat will close a little to raise the temp of the coolant,,and visa versa,,the warmer the coolant the more the thermostat will open. |
Posted: Sun Jan 09, 2005 8:19 am Post subject: |
| Mine sits between M and A, in 40 plus heat, doing 140km/h, loaded up witht the wife, 2 kids and a boot full, dont worry about the temp, its fine as it is now. |
Posted: Sun Jan 09, 2005 8:35 am Post subject: |
| bowsaw wrote: | | Mine sits between M and A, in 40 plus heat, doing 140km/h, loaded up witht the wife, 2 kids and a boot full, dont worry about the temp, its fine as it is now. |
Yeah same thing goes for my EL, except only with 1 kid in the car.... a 14 year old. |
voids Fordmods - Getting Side Ways
Age:24 Posts: 982 Joined: 10 Nov 2004 Location: middlemount QLD, Australia
Posted: Sun Jan 09, 2005 2:14 pm Post subject: |
| ir remember when the EF first come out they done a experiment hooked a falcon on a dyno in a special room to simulate it sitting on 110KM/h towing a 1000kg load in 45degree heat, it ran for over 24hours without a problem. if your original cooling system is maintained properly you should'nt have dramas with overheating. |
Reddevil Fordmods Stock as a Rock
Age:25 Posts: 119 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Tue Jan 11, 2005 8:59 pm Post subject: |
Funnily enough I just had a cooling system service done on my car today.. ~$690 later ouch.
My radiator was running around the O and R on most days (say 30 degrees). Rad was 30-40% clogged according to my mechanic who showed me the old top tank.. had about 3-4" of solid (read cement-like) sediment in the top right corner opposite the inlet.
Shagged water pump. (corroded inlet)
Shagged (buldging+split) bottom rad hose.
Shagged top radiator hose (wasnt sealing).
Shagged top tank. (corroded plastic and full of sediment)
New thermostat housing and gasket
I'd hate to think what my core looked like before the radiator was cleaned out today
On the way home the temp never went above half way A, hovered mostly on L but it also was a fairly cool day too so... |
[33 queries :: 0.04162 seconds ]
