Ford EF - EL 4.0 SOHC Supercharger systems
Goto page Previous  1, 2, 3, ... 13, 14, 15  Next
markr154
PostPosted: Thu Apr 03, 2008 9:10 pm    Post subject: Reply with quote
Ok, I'll take a look at mine shortly ...also see if I can get pics.
I'll also take a squizz at the manual regarding the compressor.
mr_sperm1
PostPosted: Thu Apr 03, 2008 9:11 pm    Post subject: Reply with quote
i believe they are...
MadMatt
View User Gallery (25)
PostPosted: Thu Apr 03, 2008 9:31 pm    Post subject: Reply with quote
Contact
Quote:
hellbent_ef
he sells them.
markr154
PostPosted: Thu Apr 03, 2008 9:37 pm    Post subject: Reply with quote
OK ...Compressor is a Sanden TRV 105 from my EF / EL manual.
There is one AC hose that comes out forward heading towards the radiator, almost perpendicular to the drive belt / pulley direction ...the other hose heads off in the opposite direction into the bay.
I believe this is different to the AU set-up, and is the same for both EF / EL.
So yeah, the bracket will have to clear this front hose.
I've also taken a pic of the page in my manual, that clearly shows the arrangement ...will post it shortly.
markr154
PostPosted: Thu Apr 03, 2008 10:04 pm    Post subject: Reply with quote
THE MANUAL
and MINE
Big Black thing in the close up pulley shots is the SNORKEL.
Raptorsc
PostPosted: Fri Apr 04, 2008 7:25 am    Post subject: AC answer Reply with quote
Mark
Thanks heaps for that, yours is also identical to the one I will be working on, should be fine!
limited
PostPosted: Sat Apr 05, 2008 10:26 am    Post subject: Reply with quote
how well do your kits work with L.P.G?
DJ_Brown
PostPosted: Sun Apr 06, 2008 9:21 am    Post subject: Reply with quote
i beleive that first pic from the manual is an EA with center-point injection..
im fact, im 100% sure having owned one..lol
phongus
PostPosted: Sun Apr 06, 2008 2:30 pm    Post subject: Reply with quote
I think it isn't an EA CPI. Mainly because in that image, there is a serpentine belt set up and no clutch fan.
phong =P~
markr154
PostPosted: Sun Apr 06, 2008 5:06 pm    Post subject: Reply with quote
phong =P~
That pic came straight out of an Ellery's FALCON / FAIRLANE EF / EL 94-98 Manual ...so I doubt it's an EA CPI.
cooki_monsta
PostPosted: Sun Apr 06, 2008 6:06 pm    Post subject: Reply with quote
i 2nd the serpentine belt setup theory to blow that out of the water icon_biggrin.gif , want to do a supercharger for a nissan patrol? icon_biggrin.gificon_biggrin.gif
Dansedgli
PostPosted: Sun Apr 06, 2008 8:54 pm    Post subject: Reply with quote
Raptorsc
PostPosted: Sun Apr 06, 2008 9:31 pm    Post subject: Reply with quote
Nissan Patrol 4.2 Petrol? Could be done, dunno how many people want one tho
markr154
PostPosted: Mon Apr 07, 2008 12:27 am    Post subject: Reply with quote
Thanks Tim!
I have elaborated with further questions in your general Raptor Supercharger thread http://www.fordmods.com/forums/viewtopic.php?t=63055&start=20 just to keep this EF / EL thread tidy!
Cheers.
Dansedgli
PostPosted: Mon Apr 07, 2008 1:46 pm    Post subject: Reply with quote
Yep, 4.2 litre petrol.
The brackets would be the only thing needed in the kit then the fueling side and piping can be sorted out by the owner.
DJ_Brown
PostPosted: Mon Apr 07, 2008 4:53 pm    Post subject: Reply with quote
notice the hose arangement?? the EA a/c compressors have 2 separate bolts, and 2 separate hoses, EFs have the one bolt through the center of the black block. Ea's also have a multi-rib belt, a 5pk-915, and in the pic, there is an absence of self tensioner...
There are also no elec fans either and no BBM manifold.. look at the metal pipe out of the thermostat housing, it goes straight into the manifold, the EA-onwards MPFI goes to a rubber hose off a bracket..
DJ_Brown
PostPosted: Mon Apr 07, 2008 4:56 pm    Post subject: Reply with quote
also, check out the placement of the dip-stick tube. all the EF-ELs i know have it come though the middle of the manifold. that one clearly comes though on the end of the manifold, near that metal water pipe from the thermostat housing,
BenJ
PostPosted: Mon Apr 07, 2008 5:13 pm    Post subject: Reply with quote
The Ellery's Manual I have on PDF seems to reuse a few older pictures from previous models, and I suggest this is the case here as well.
BenJ
markr154
PostPosted: Mon Apr 07, 2008 5:41 pm    Post subject: Reply with quote
Picky bastards, the pics of my compressor show the same AC hose set-up ...that manual pic was only a guide anyway.
smokin ef
lets keep this thread about blowers boys!! so what are the typical power output on one of these, say running at 7-10psi with standard internals?? and will the internals need to be changed or could a stockish falcon cope with it??
Page 2 of 15
[47 queries :: 0.05765 seconds ]
