Age:23 Posts: 1438 Joined: 08 Nov 2004 Location: Bunbury WA, Australia
Posted: Sat Feb 16, 2008 2:56 am Post subject: |
Yeah i'm a bit lazy, i couldn't be bothered ripping the sump off the engine to have it modified haha.
As for an engineers report, i really dont think it would pass. But i dont drive in a manner to attract the attention from the authorities. |
wicksy Fordmods - Getting Side Ways
Age:23 Posts: 2759 Joined: 14 Apr 2005 Location: mackay QLD, Australia
Posted: Sat Feb 16, 2008 3:05 am Post subject: |
| if it is welded by a workshop couldnt they supply a report to say yes it can handle this and that and so forth? |
Age:40 Posts: 5398 Joined: 18 Apr 2005 Location: Hobart TAS, Australia
Posted: Sat Feb 16, 2008 7:05 pm Post subject: |
| fordman351 wrote: |
As for an engineers report, i really dont think it would pass. But i dont drive in a manner to attract the attention from the authorities. | just remember one day you'll be in a prang. would you wanna risk the likelihood of injuring or killing a love one? one look by the authority and they'll ban everything to do with modifications all together or make it tougher for the next bloke who wise do mod the same as well.
get the K-frame reinforced, weld & close that opening you cut out of it. better to be safe & sure then sorry. |
DA22LE Fordmods - Smokin em up
Age:42 Posts: 297 Joined: 06 Aug 2007 Location: Kellyville NSW, Australia
Posted: Sat Feb 16, 2008 8:06 pm Post subject: |
I, personally, would've gone with the modded sump, looks like they can be easily welded, as some aluminium castings can be riddled with silicon or manganese, which doesnt help weldability.
I would like to see the look on your face when you cant drive this car as it hasnt been engineered, due to the structural changes.
You probably would only have to reinforce the front and bottom of the frame to bring it back to the original strength, which would be a piece of cake, and cost f**k-all.
Good luck with it all
Daz  |
revhead_88 Fordmods Parts Gopher
Age:20 Posts: 85 Joined: 15 Mar 2006 Location: Canberra ACT, Australia
Posted: Sat Feb 16, 2008 8:10 pm Post subject: |
you cant modify the sump on the ba engines as you can with the au engines. On the ba engine the oil pump is driven staright off the crankshaft on the front of the motor, you just cant get enough clearance out of the ba sump without modding the subframe.
What i would be doing is putting an ea-ed subframe in the car and modifying it. its different in design and allot easier to modify.
Trust me ive done it |
Posted: Sat Feb 16, 2008 8:54 pm Post subject: |
| revhead_88 wrote: | | you cant modify the sump on the ba engines as you can with AU |
Fair enough, had another look at the the front of the sump, where the bulge is near the harmonic balancer, no doubt that where the housing for the pump is......I would radius the corners of the cuts, and box it back in, and that should be ok, get some pics so the engineer can see that you made a decent effort to strengthen it, and not some half-a*** hack job gone bad. Not trying to insult you, just would be a shame to spend time and money, only to be denied the enjoyment of it all for a simple fix.....
Daz  |
Posted: Sat Feb 16, 2008 9:20 pm Post subject: |
Jeez guys give me a break, the photos i showed you before were just of an engine test fit to check clearances. I wasn't installing the engine without closing up and strengthening the crossmember. Anyway, it's all been done so there's no turning back!
Got the car back this morning, bolted up the torque converter and gearbox and basically threw it all in haha. Installed new transmission lines radiator and transmission cooler. All i have to do now is to sort out the wiring, weld a new [BA] flange onto my extractors and have the power steering hose i had made, shortened doh!
Oh and sorry about all the pictures, just thought people might be interested.
The crossmemeber, reinforced with 4mm plate high tensile steel.
The vertical part of the reinforcement has been welded to the bottom of the inside of the crossmember for added rigidity.
The horizontal part of the reinforcement has been welded onto the vertical part and onto the edge of the crossmember.
Engine in, plenty of clearance.
From beneath.
Reused EL engine mounts, they're alot more compact than the BA ones.
Torque converter on, thanks to those that pointed out the access port underneath the engine hahahaha!
Gearbox on.
Re used the EL starter motor.
Engine and gearbox just about to be dropped in.
Engine and gearbox bolted in, it aint going anywhere.
Like everything in Texas, the head is hooooooge!
Braided transmission lines.
Routing lines to front.
Trans cooler and new radiator.
And last but not least, the engine bay as i leave it after a hard days work.
TwistedEL Fordmods - Getting Side Ways
Posts: 1073 Joined: 18 Sep 2005 Location: Belmont WA, Australia
Posted: Sat Feb 16, 2008 10:26 pm Post subject: |
| Looks good! Must say I'm pretty impressed at how fast you're doing this. Now comes the really tricky part (the wiring) |
cjh Fordmods - Getting Side Ways
Age:40 Posts: 3040 Joined: 18 Dec 2006 Location: rockhampton QLD, Australia
Posted: Sat Feb 16, 2008 10:42 pm Post subject: |
| Will a bonnet bulge be nessecary to fit the head under the bonnet??? |
Posted: Sat Feb 16, 2008 10:48 pm Post subject: |
| cjh wrote: | | Will a bonnet bulge be nessecary to fit the head under the bonnet??? |
Already sorted , check my gallery. I knew it would come in handy one day heehee.
Thank's for the encouragement TwistedEL, i'm quite surprised myself at how quickly it has gone together.
Just a few questions though, has anyone seen on other BA conversions hw people attached the cruise control and throttle cables? I've hit a wall on this and have no idea how im going to attach them .
Also, does anyone know if the cam phasing is two position (as in on -off) or infinitely variable (as in pulsed)? If it's a simple on-off thing, then im in luck. Fingers crossed.... |
RSWEPN Fordmods Parts Gopher
Age:23 Posts: 61 Joined: 06 Jul 2006 Location: Sydney NSW, Australia
Posted: Sat Feb 16, 2008 11:25 pm Post subject: |
| fordman351 wrote: | | cjh wrote: | | Will a bonnet bulge be nessecary to fit the head under the bonnet??? |
im pretty sure if your using the standard ecu and throttle body running fly by wire throttle, you have to run the standard BA pedel box. |
Age:23 Posts: 2367 Joined: 07 Nov 2004 Location: Perth WA, Australia
Posted: Sat Feb 16, 2008 11:37 pm Post subject: |
Variable, through a range of (i think) 40 degrees |
Posted: Sun Feb 17, 2008 1:53 am Post subject: |
| sweet as looking good fordman, coming along nice and quick |
Age:22 Posts: 3848 Joined: 15 Nov 2004 Location: Perth WA, Australia
Posted: Sun Feb 17, 2008 2:03 am Post subject: |
| possible to swap the BA TB with the EL TB? |
Posted: Sun Feb 17, 2008 2:11 am Post subject: |
| Gaz wrote: | | possible to swap the BA TB with the EL TB? |
That's what i have done, i'm using the EL throttle. Unfortunately the intake tube on the throttle gets in the way of the cables, there's not alot of room to move there. |
Posted: Sun Feb 17, 2008 7:56 am Post subject: |
I must say, I'm very impressed of the outcome. keep up the good work mate!
Not many people would venture that far into that kind of modification.  |
Disco Frank Fordmods Junkie
Age:29 Posts: 13767 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Sun Feb 17, 2008 5:54 pm Post subject: |
nice work dude
for the cables
get a custom intake tube made to allow room for the cables? |
Posted: Tue Feb 19, 2008 7:52 pm Post subject: |
Wooo! Fairmont owners rejoice!! Because of the way the bonnets are shaped (the raised section in the middle), only a small section of the bracing underneath needs to be cut for the engine to clear. No need to cut gaping holes into the bonnet!
Posted: Tue Feb 19, 2008 8:08 pm Post subject: |
Engine bay is starting to look more complete every day.
New power seering hose connected. Alternator connects up just like the old one.
If you cut the fuel hoses right at the base of the threaded fittings the hoses will slip straight onto the fuel rail connections. The BA's just use hoseclamps to hold them on!
cboz Fordmods Tyre Shredder
Age:24 Posts: 378 Joined: 17 May 2007 Location: Mt.Martha VIC, Australia
Posted: Wed Feb 20, 2008 4:37 pm Post subject: |
| Bloody rippa, I own a mont and have always thought with the different bonnet there was a chance a BA engine might sqeeze in there. |
[47 queries :: 0.07946 seconds ]
