Age:23 Posts: 1172 Joined: 08 Nov 2004 Location: Bunbury WA, Australia
Posted: Mon Jan 14, 2008 9:51 pm Post subject: fordman351's Twincam Conversion: NOW RUNNING! Finish Soon! |
Hey crew,
This has been in the planning for quite some time now, but i have only just run into some spare cash to actually do this.
I have just purchased the engine a couple of days ago, the donor car was a 2004 BA Falcon XT and had only done 22,000 km's! I snapped that up for $1500 but the catch was that it did not have the power steering pump and alternator. But that's all sorted, i have new genuine units on the way, they should be here in the next couple of days. The engine did come complete though with wiring harness, electronic throttle and all associated sensors etc.
As for running the show, i'm in the final processes of researching EMS ECU's and have found them to be quite cost effective and have some great features like VCT phasing and high mapping resolutions.
Coupling the engine to the gearbox has been taken care of by using an AU bellhousing, i should still be able to run my EL starter motor as well. I'm also wondering if my air conditioning compressor will bolt up to the BA block, but thats not hugely important at the moment. Engine mounts look to be exactly the same.
As for getting the engine to fit in the engine bay, i'm tossing up wheather to modify the front crossmember, or hack the front of the sump off the engine. I'm leaning to modifying the sump as i don't want the front of the car to become structually unsound (or more illegal than it will be when i get this engine in haha).
But as for all that, that's about as far i have gotten untill i get everything i need together to get this engine bolted in. I'm going to give Hyperdrive in Perth a bell to see if they can sort me out with wiring and ECU side of things.
So....let the games begin! Wish me luck, i might need it haha.
Here's a couple of pictures of my new engine:
cjh Fordmods - Getting Side Ways
Age:40 Posts: 2767 Joined: 18 Dec 2006 Location: rockhampton QLD, Australia
Posted: Mon Jan 14, 2008 10:17 pm Post subject: |
| Looks like you do a bit of woodworking...............lol |
Disco Frank Fordmods Junkie
Age:29 Posts: 12787 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Mon Jan 14, 2008 10:20 pm Post subject: |
| mate she's missing the huffer on the side! |
Posted: Mon Jan 14, 2008 10:22 pm Post subject: |
Haha, nah that's the old mans toys. I'm restricted to the area between the router and the front of my car lol.
As for the turbski's, that will happen a short while down the line. |
Posted: Mon Jan 14, 2008 10:25 pm Post subject: |
| Just hope you don't get any wood dust in your donk & stuff..........lol |
Posted: Mon Jan 14, 2008 10:28 pm Post subject: |
| Nah, it's not dusty considering, plus everything is covered up when i finish working. |
Age:24 Posts: 2082 Joined: 07 Feb 2005 Location: melbourne VIC, Australia
Posted: Tue Jan 15, 2008 7:02 am Post subject: |
Try and get the stock ECU running. That would be good to see.
Mine is at home now and it starts and runs but Ive got electrical issues holding it back now. Im in the middle of changing all of my factory looms to fix it.
It needs more tuning once the electrics are good again. |
Posted: Tue Jan 15, 2008 11:28 am Post subject: |
Nah, there's no way i'm going to try and get the stock ECU to run the engine, plus the engine in my car at the moment runs a distributor, the twincam has coil on plug, i'd imagine that would be one major headache to get to work properly and safely. i want to utilise the VCT feature as well.
Not too later down the line i'll have installed a turbo, so having the EMS will be ideal for me. |
Tocchi Cruise Moderator
Age:21 Posts: 752 Joined: 22 Aug 2006 Location: Perth WA, Australia
Posted: Tue Jan 15, 2008 11:34 am Post subject: |
hey matt, you are a lucky f**k.. cos you dont have to worry about bonent clearance issues.. cos you can cut the hole in the bonnet, and the bulge will already hide it  |
Posted: Tue Jan 15, 2008 12:21 pm Post subject: |
| I wasnt suggesting to use the EL computer. Try and use the standard BA one. |
dave0 Fordmods Stock as a Rock
Posts: 113 Joined: 09 Jan 2008 Location: syd NSW, Australia
Posted: Tue Jan 15, 2008 12:25 pm Post subject: |
| ill be watching this build mate good luck with it all |
TickFordEFXR6 Fordmods - Smokin em up Donating Member
Age:24 Posts: 281 Joined: 04 Mar 2007 Location: Blackburn VIC, Australia
Posted: Tue Jan 15, 2008 7:29 pm Post subject: |
| yea im watching too gunna learn alot from this |
Posted: Tue Jan 15, 2008 9:14 pm Post subject: |
No worries guys, i'll try and get in as much detail as possible, but if there's anything you want to know, just ask.
So basically, to fit the engine up into an EF-EL you need to do three things. 1) Cut a hole in the bonnet, 2) Fit an AU or BA bellhousing, 3) Modify the crossmember or sump. Everything else will literally bolt up. Engine mounts are in the same position, transmission mounts are the same regardless.
The only other things you will need are a BA alternator and power steering pump, but if you're getting a complete engine, obviously, you won't have any hassles there.
And i'll confirm one thing that gets raised a fair bit, the BA manifolds ARE DIFFERENT to the SOHC engines. The ports on the BA head are an oval shape, not round like the SOHC.
Which brings to mind, i'll have to cut the flange off my extractors and have a BA flange welded on in it's place... |
Aranthi Fordmods Stock as a Rock
Posts: 170 Joined: 11 Mar 2005 Location: Melbourne VIC, Australia
Posted: Wed Jan 16, 2008 12:59 am Post subject: |
| very intresting mate, im lookin at doing this into a XF, only thing thats gonan give me a headache will be the ECU, post up which one you pick if you wouldn't mind |
EFfalconsrule Fordmods - Getting Side Ways
Age:28 Posts: 744 Joined: 26 Nov 2004 Location: Cairns QLD, Australia
Posted: Wed Jan 16, 2008 11:14 am Post subject: |
| What saught of time frame are you looking at? Like a week or ongoing? |
Posted: Wed Jan 16, 2008 1:51 pm Post subject: |
Aranthi, i'm in contact with EMS to see if the 6806 will suit the project, i'm pretty keen on that one, so if EMS say it will work with my combination, i'll be going with that.
As for a time when this is going to be finished, i want the car off the road as little as possible, so i'm just gathering bits together now so i can throw it all in at once. Also will be depending on when i sell my bike. Could be next week, could be next month. |
Posted: Wed Jan 16, 2008 2:59 pm Post subject: |
Any ECU that will work with the 36-1 crank sensor will work. The only thing that would hold an ECU back is if you wanted cam control.
Atomic are releasing verneir cam gears next month if you didnt want to pursue the DVCT route. If you do then I was quoted $6500 for a motec install. The autronic needs you to remove 3 of the cam teeth to work with the sensors which isnt that much of a drama.
Early last year Autronic was going to release a version of their ECU which would work with the stock sensors but I dont think it ever got done. |
Posted: Wed Jan 16, 2008 4:33 pm Post subject: |
| What bike are you selling????? |
revhead_88 Fordmods Parts Gopher
Age:19 Posts: 71 Joined: 15 Mar 2006 Location: Canberra ACT, Australia
Posted: Wed Jan 16, 2008 5:27 pm Post subject: |
hey buddy nice project i see happening here... im also currently doing the conversion. see my thread on boosted falcon in my sig
heres a few tips and things that i can think of
see if an EA-ED subframe will fit on the chassis as the el subframe is different to the eb one, and the eb one is alot easier to modify. you cant cut out too much of the sump because the oil pump is right at the front on the ba engine.
ill post pics up later on 2nite of the subframe
im using my eb engine mounts.
as for computers im running an ems 8860. as dan said before there is no cheapish ecu that can control the dvct. im in contact with ems and at ford hq trying to get some info on the cams so i can send it to ems and see if they can get it too work.
whats your plans on transmission. the el trans wont hold up for too long if your going to be running some serious power im running the tremec 5 speeds out of the ba mk2 turbos. just gotta sort out the hydrolic clutch.
umm and now i forgot what i was going to say...
so anyway ill put some pics up 2night and show you what i mean with subframes etc.
wow theres going to be a few dohc eseries soon... now i dont feel as special. im still cooler than you losers with your sohc haha lulz |
Posted: Wed Jan 16, 2008 5:50 pm Post subject: |
also thought of a few other things
ditch the drive by wire throttle body, and get a standard cable type. dan and i are both using an xf throttle body's and brackets and an ea-ed cable.
and with the aircon. im going to try and use an el compressor bolted onto the ba engine, but if worse comes to worse just use the ba one and get some lines made up. not really that hard
pics of my eb subframe
this pic shows how far the k frame was moved forward for sump clearance
i also had some spacer plates made up, hopefully to try and eliminate bonnet clearance issues
the plates fitted to the frame
[47 queries :: 0.0654 seconds ]
