FORUM OPEN FOR POSTING
Goto page Previous  1, 2, 3 ... 14, 15, 16 ... 19, 20, 21  Next
Post new topic   Reply to topic    Forum Index -> Wade Cams
3x-puursui7
PostPosted: Thu Feb 21, 2008 3:22 pm    Post subject: Reply with quote
hey mate just wondering wat cam u would recommend for a series 1 AU forte V8 auto, will be doing some head work and putting roller rockers in the same time as the cam, and new exhaust+extractors. looking for a semi rough idle but more low to mid range torque for the street.
cheers in advance
Wade Cams
Commercial Sponsor
PostPosted: Mon Feb 25, 2008 1:47 pm    Post subject: Reply with quote
cheers in advance
We'd be inclined to suggest the same cam profile for you as we did for the previous post. Profile no. 992A <112.
The specifications are:-
Lift at lobe EX. & IN. 0.295"
Valve lift EX. & IN. 0.472"
Advertised duration EX. & IN. 276 degrees
Duration @ 0.050" EX. & IN. 214 degrees
Phase angle 112 degrees
The idle is probably not as rough as you might like, but, a cam with a semi-rough idle will not perform as well.
3x-puursui7
PostPosted: Mon Feb 25, 2008 5:20 pm    Post subject: Reply with quote
haha cheers mate didnt think it was on here i had asked?!
wizzgums
PostPosted: Tue Mar 04, 2008 7:45 pm    Post subject: Reply with quote
hey what is a 1004 grind for ... auto or manual??? and what are the stats on that grind ?
thanx in advance
Wade Cams
Commercial Sponsor
PostPosted: Wed Mar 05, 2008 7:44 am    Post subject: Reply with quote
thanx in advance
Originally, it was intended for both auto and manual. We ground it at 112 phase angle for a manual and 114 for an auto.
We then found that, at 114 for an auto, it was still, in some instances, "hunting" somewhat. That's why we then developed the 1636, to provide a more stable idle.
The specs for the 1004 < 112 are;
Cam lift IN. & EX. 0.240"
Valve lift IN. & EX. 0.480"
Advertised duration IN. & EX. 264 degrees
Duration @ 0.050" IN. & EX. 204 degrees
Lift @ TDC No. 1 IN. 0.046"
twr7cx
PostPosted: Mon Mar 10, 2008 10:36 pm    Post subject: Reply with quote
I've got an EF I6 with a Powerdyne supercharger. I've got Crow double valve springs fitted and plan to shortly install a 3,000rpm high stall torque converter for the automatic transmision.
-GAS-MAN purchased a similiar vehicle with the same suprcharger and high stall torque converter. It is fitted with a camshaft from you guys, but he doesn't know the model code or anything.
Do you guys have a grind for such a setup or could you make a custom grind for me that would suit?
Currently I'lve still got my old 1636 in there and it is no longer suitable.
Wade Cams
Commercial Sponsor
PostPosted: Wed Mar 12, 2008 7:27 am    Post subject: Reply with quote
Sorry for the delay in responding. I had intended to respond yesterday but was sidetracked at every attempt. I believe our Technical Manager, Keith, has already replied to your email. If you have any more questions, feel free to ask away.
Dansedgli
PostPosted: Wed Mar 12, 2008 7:52 am    Post subject: Reply with quote
I have an auto EF 6 cylinder with the non comp pacies and a 2.5 inch exhaust. I cant adjust the timing and I dont want to run a high stall convertor. Is there any benefit in fitting one of your cams? Which would you recommend and what gains could be had?
Thanks.
FordFairmont
PostPosted: Wed Mar 12, 2008 8:17 am    Post subject: Reply with quote
usual answer to those mods would be 1636, best all round cam cant go wrong.
the next step up, 1673 works higher up in the rev range and would be suited to shorter diff gears or high stall
RedRoo
PostPosted: Wed Mar 12, 2008 8:39 am    Post subject: Reply with quote
Ok this is what I have to work with Chris,
A 300K EB Series 1 Cpfi Auto on LPG and Stock Exhuast System.
I am looking at freshening up the motor later down the track, but as the saying goes if it aint broke dont touch it.
I am thinking of putting a better cam in to give it a bit more umph but unsure what would you suggest.
Cheers Paul
Wade Cams
Commercial Sponsor
PostPosted: Wed Mar 12, 2008 8:42 am    Post subject: Reply with quote
Thank you sir, correct answer.
Wade Cams
Commercial Sponsor
PostPosted: Wed Mar 12, 2008 8:44 am    Post subject: Reply with quote
Cheers Paul
G'day Paul
The 1636 , as "FordFairmont" has indicated, is the best allround cam, particularly for a basically standard motor with an auto trans.
Chris
Dansedgli
PostPosted: Wed Mar 12, 2008 7:43 pm    Post subject: Reply with quote
Thanks for the reply.
Any ideas of dyno figures / experience over a standard cam with the 1636? Is the change noticeable?
Im hesitant to change anything much from factory because I like my fuel economy atm.
RedRoo
PostPosted: Wed Mar 12, 2008 8:11 pm    Post subject: Reply with quote
Thanks for that Chris,
I just have to twist the wifes arm abit by telling her the car really needs it for better economy.
tx5_reaper
PostPosted: Wed Mar 12, 2008 8:43 pm    Post subject: Reply with quote
hi whats the best cams for a 1993 ford telstar tx5 ax 2;tr 5spd manual and how much
Wade Cams
Commercial Sponsor
PostPosted: Thu Mar 13, 2008 6:23 am    Post subject: Reply with quote
There's no best cam as such. It depends on what you're looking for. Is it a daily drive? Bearing in mind that you can't have more "ooomph" right through the rev range.....what is you're preference? Low end torque, more mid range, top end?
Also, what engine mods do you have or are planning to do?
tx5_reaper
PostPosted: Tue Mar 25, 2008 6:31 pm    Post subject: Reply with quote
sorry for the long delay in reply it is a daily driver and with (Low end torque, more mid range, top end) i have no idea what that means and with the engine mods im planning on cold air intake etc etc nothing to big
phongus
PostPosted: Tue Mar 25, 2008 6:47 pm    Post subject: Reply with quote
Low end, mid or top end torque means when the torque kicks in when driving.
There are cams which have low end torque, which means that you can feel the car pull harder at lower RPMs. Where as mid range is somewhere in between low and top end where the car starts to pull harder. At top end, torque kicks in later but pulls harder at the higher rev ranges. For everyday driving I'd say low and mid range is fine cause you want it to kick in earlier rather then later.
Though if you want low end, you will lose power top end and also vice versa. Mid range being in the middle you basically even out I believe.
phong =P~
tx5_reaper
PostPosted: Tue Mar 25, 2008 7:13 pm    Post subject: Reply with quote
ok thanx phongus so how much for the mid for my beasty car
justin21349
PostPosted: Tue Mar 25, 2008 7:49 pm    Post subject: Reply with quote
hey guys, i got a EF 5 spd wit a 3.23 diff and extractors. tis a daily driver would like some low midrange torque.. any suggestions???
thanks in advance.
Page 15 of 21
[47 queries :: 0.06668 seconds ]
