FORUM OPEN FOR POSTING
Goto page Previous  1, 2, 3 ... 17, 18, 19 ... 21, 22, 23  Next
Post new topic   Reply to topic    Forum Index -> Wade Cams
Riding_The_Lightning
PostPosted: Mon May 26, 2008 8:18 pm    Post subject: Re: 1636 GOOD Reply with quote
sam0812 wrote:
Thanks Wade. Just fitted a 1636 to my ebii fairmont which already had tickford head and pacemaker 4480;s. It now goes REALLY WELL....Pulls like a train from 2500rpm up icon_biggrin.gif Only down side is aircon stalls motor at idle but I can live with that until I fix it. Again Good Product icon_biggrin.gif
just need to bump up your idle a bit there mate and you should have problems, its a pretty common thing to have to do after fitting a bigger cam
FordFairmont
PostPosted: Mon May 26, 2008 8:25 pm    Post subject: Reply with quote
Just reset the battery overnight...... will take up to a week of driving before your car decides to idle properly, all depending how much driving you do.
I wouldnt adjust anything until you give the ecu a chance to re-learn
Wade Cams
Commercial Sponsor
PostPosted: Tue May 27, 2008 12:30 pm    Post subject: Reply with quote
tx5_reaper wrote:
mid range cams for a 1993 ford telstar tx5 ax 2litre dohc 16valve 5speed manual
Please confirm, are the cams actuated by hydraulic buckets?
Assuming they are, it is very difficult to modify the cams sufficiently to achieve any sort of decent performance improvement.
You either have the option of doing billet cams, assuming they are procurable, or, welding the existing cams ( 16 lobes ), which, at $1,292.00 for the pair, is generally not a consideration.
Wade Cams
Commercial Sponsor
PostPosted: Tue May 27, 2008 12:33 pm    Post subject: Reply with quote
The MaDDeSTMaN wrote:
What cam would you recommend for my planned setup:
Iron head 250 crossflow, with the iron head removed and replaced with a worked alloy head (just a clean up of the ports and upgraded springs) and weber carb from an XF (most likely a C1 head), extractors, 2.5" exhaust, auto, LPG, in an XD stationwagon which will occasionally tow and is the family runabout.
Looking for something that will give improved performance while still being usable with the auto and capable of towing, while still having some manners around town.
The cam grind that l would recommend is our profile no. 1166A10. It will be suitable for the auto, and for towing and be suitable for a daily drive situation.
If you'd care to PM me with an alternative email address, l can send you the specifications as an attachment.
Chris
The MaDDeSTMaN
PostPosted: Tue May 27, 2008 1:11 pm    Post subject: Reply with quote
Chris
Cheers for the prompt response mate, it may be the family runabout wagon, but I don't see why I shouldn't do it up a bit still, and with that combo it should go much better then it does now without it running like a pig or costing an arm and a leg to run.
Any idea what sort of a power boost I could expect with a setup like that with that cam?
Also PM sent.
Thanks again!
ef_ridin_low
PostPosted: Tue May 27, 2008 1:31 pm    Post subject: Reply with quote
is it worth runnin a 977b in my ef, its a 5 speed wit a crow cam, i have been told by a mate that because i cant adjust the timing it would be of no use to me?
FordFairmont
PostPosted: Tue May 27, 2008 1:40 pm    Post subject: Reply with quote
i run a slightly altered 977b in my EF, and have run a normal 977b previously as well.
The first 977b, which kizzer has now, netted me 150kw at the wheels with a custom tune and ran hard even without the tune.
very happy with the cam, pm me if you want anymore feedback
ef_ridin_low
PostPosted: Tue May 27, 2008 2:25 pm    Post subject: Reply with quote
how much did you pay for you 977b, defintly wanna replace my crow cam with one
ef_ridin_low
PostPosted: Tue May 27, 2008 6:09 pm    Post subject: Reply with quote
is there a suplier in perth for wade?
braden_mal
PostPosted: Tue May 27, 2008 9:39 pm    Post subject: Reply with quote
what cam would you suggest for my 1995 EF sdn, pacemaker extractors, hi flow cat, 2.5 inch exhaust system, bigmouth air in take system? majority of driving to and from work, ive heard of the 1636?? as said in myprevious post. i dont knw much so some explanation would help haha. cheers
Wade Cams
Commercial Sponsor
PostPosted: Wed May 28, 2008 1:54 pm    Post subject: Reply with quote
Manual or auto?
Wade Cams
Commercial Sponsor
PostPosted: Wed May 28, 2008 1:55 pm    Post subject: Reply with quote
We don't have a network of suppliers as such. You can deal direct.
Wade Cams
Commercial Sponsor
PostPosted: Wed May 28, 2008 1:56 pm    Post subject: Reply with quote
I'm guessing this question is directed at "FordFairmont"?
ef_ridin_low
PostPosted: Wed May 28, 2008 2:02 pm    Post subject: Reply with quote
yes it was but i rufff price would awsome.
Wade Cams
Commercial Sponsor
PostPosted: Wed May 28, 2008 3:51 pm    Post subject: Reply with quote
The price to Fordmods members to grind an E series cam is $135.00. Freight is extra. If we supply an exchange cam, we charge a refundable deposit of $100.00 for the core.
Chris
braden_mal
PostPosted: Wed May 28, 2008 7:24 pm    Post subject: Reply with quote
Manual or auto?
its auto...
Wade Cams
Commercial Sponsor
PostPosted: Thu May 29, 2008 7:25 am    Post subject: Reply with quote
braden_mal wrote:
Manual or auto?
its auto...
OK. With an auto transmission, the 1636 profile would be your best choice.
A practical cam that gives a worthwile improvement in performance whilst still retaining reasonable idle etc.
FordFairmont
PostPosted: Thu May 29, 2008 7:37 am    Post subject: Reply with quote
Questions about the 1521a, btw im running a manual.
What exactly is the reason for aftermarket ecu required? I ask because the 977b says ecu mods preferred, but im getting great performance, fuel economy and idle on stock ecu?
Also what is the basic rev range for the 1521a, is rev limiter removal required to sufficiently run this cam? If it does scream past the stock rev limit, then can the cam be ordered with lower duration to bring the rev range in earlier?
Finally how much for the billet 1521a?
stoj79
PostPosted: Thu May 29, 2008 11:52 pm    Post subject: Reply with quote
also curious about this cam ps ford fairmont what sort of money did it set u bakc for your chip torque chip
Wade Cams
Commercial Sponsor
PostPosted: Fri May 30, 2008 9:09 am    Post subject: Reply with quote
PM sent.
Page 18 of 23
[47 queries :: 0.06815 seconds ]
