Age:20 Posts: 811 Joined: 19 Feb 2007 Location: Lilydale VIC, Australia
Posted: Fri May 30, 2008 11:47 am Post subject: |
what would be the best cam to get for an EL Hybrid with an auto. I dont really care how it idles as long as is dosn't stall all the time
cheers |
Posted: Fri May 30, 2008 11:53 am Post subject: |
| sorry about double post, but can you do a billet cam aswell? |
braden_mal Fordmods Newbie
Posts: 8 Joined: 29 Jan 2008 Location: Perth WA, Australia
Posted: Sat May 31, 2008 12:07 am Post subject: |
braden_mal wrote:
braden_mal wrote:
what cam would you suggest for my 1995 EF sdn, pacemaker extractors, hi flow cat, 2.5 inch exhaust system, bigmouth air in take system? majority of driving to and from work, ive heard of the 1636?? as said in myprevious post. i dont knw much so some explanation would help haha. cheers
Manual or auto?
its auto...
"OK. With an auto transmission, the 1636 profile would be your best choice.
A practical cam that gives a worthwile improvement in performance whilst still retaining reasonable idle etc."
Ok cheers and how much will that cost? |
1965tbird Fordmods Stock as a Rock
Age:21 Posts: 123 Joined: 20 Jul 2007 Location: Melbourne VIC, Australia
Posted: Mon Jun 02, 2008 12:42 am Post subject: |
Hey mate i have a EF XR it has extractors and a 2 1/2 inch cat back, also has higher comp due to shaved head. Would a 1636 be a good choice? its my daily and auto. if so how much to have it fitted aswell?
Cheers |
Wade Cams
Age:55 Posts: 262 Joined: 08 Nov 2004 Location: Melbourne VIC, Australia
Posted: Tue Jun 03, 2008 8:51 am Post subject: |
| GeZza200 wrote: | what would be the best cam to get for an EL Hybrid with an auto. I dont really care how it idles as long as is dosn't stall all the time
cheers |
The AU equiv. to our 1636 profile, which works well with an auto is our profile no. AU1502. This is what we would recommend. The cost to grind your cam is $135.00. An exchange cam will incur an additional $100.00 deposit. Freight charges, if applicable, are extra.
ATM billets for the AU are not available. They've been unavailable for the better part of 6 months. We're told they might arrive early July. Don't hold your breath.
Chris |
Wade Cams
Posted: Tue Jun 03, 2008 8:57 am Post subject: |
| 1965tbird wrote: | Hey mate i have a EF XR it has extractors and a 2 1/2 inch cat back, also has higher comp due to shaved head. Would a 1636 be a good choice? its my daily and auto. if so how much to have it fitted aswell?
Cheers |
In a word......YES. Particularly with an auto, you can't really go any higher.
To grind your cam is $135.00. For an exchange, we charge a deposit of $100.00 for the core which is refunded when you return a suitable replacement cam to us. Freight charges, if applicable, are extra.
Chris |
Shortshift Fordmods Parts Gopher
Age:45 Posts: 90 Joined: 12 Aug 2007 Location: Melbourne VIC, Australia
Posted: Tue Jun 03, 2008 9:22 pm Post subject: |
Chris, I have a query for you regarding the 1636 profile.
After installing the cam in my 3.9L, getting it dialed in and dynotuned it works well. However, the mechanic tuning it reckons it needs more fuel at idle. Cruising at 100km/h, the motor hesitates a little as if it's running lean. Under acceleration, there's no problems. With the original stock cam, the engine ran without any dramas.
Has Wade encountered this with cam testing, or heard any similar comments from other Ford owners? I've fitted reco AUXR6 injectors & a new fuel filter but still have the stock 250kPa fuel reg & ECU. The AFR are about 12-12.6.
Thanks |
Wade Cams
Posted: Wed Jun 04, 2008 3:56 pm Post subject: |
| Shortshift wrote: | Chris, I have a query for you regarding the 1636 profile.
Thanks |
The only situation that comes close to what you're experiencing is an instance where a guy bought a cam (from memory, a 1636), installed it and had a similar problem to what you're describing. It turned out that at some point, either a fuel line or vacuum line had been crimped.
Anyway, l have some questions.
Is your transmission manual or auto?
Did you reset the ECU after installing the cam?
What was the purpose for fitting the AU XR6 injectors?
Chris |
Posted: Wed Jun 04, 2008 6:19 pm Post subject: |
1. I've got a 4 speed auto gearbox. I read through all the posts and Wade's recommendations on this forum before choosing the cam.
2. I've reset the ECU several times, before and after it was dynoed.
3. The injectors have never been replaced in 17 years and since I've added extractors & modified the head, I thought I may as well install the AUXR6 injectors (which I'm told have a better spray pattern).
I'm happy with the cam and what it does performance wise. Just trying to work out if cam affects the air-fuel ratio much. Perhaps I need an adjustable fuel reg to fine tune the engine. |
Posted: Wed Jun 04, 2008 10:09 pm Post subject: |
| Ive done alot of asking around andwhen the time comes ill be getting the 1636 regrind and ill exchange my old one for the new one. Ill also need the shimms to go with it. how much would that be? |
Wade Cams
Posted: Thu Jun 05, 2008 4:25 pm Post subject: |
| braden_mal wrote: | | Ive done alot of asking around andwhen the time comes ill be getting the 1636 regrind and ill exchange my old one for the new one. Ill also need the shimms to go with it. how much would that be? |
You should be able to get the shims from your nearest Ford dealer. I believe they cost about $60 to $70. |
Wade Cams
Posted: Thu Jun 05, 2008 4:27 pm Post subject: |
| Shortshift wrote: | 1. I've got a 4 speed auto gearbox. I read through all the posts and Wade's recommendations on this forum before choosing the cam.
People l've spoken too haven't been able to shed much light on your problem. Just wondering, did you have the AUXR6 injectors in place before you put our cam in? |
ESP Fordmods - Getting Side Ways
Age:38 Posts: 462 Joined: 11 Nov 2004 Location: Coffs Harbour NSW, Australia
Posted: Thu Jun 05, 2008 4:41 pm Post subject: |
| G'day. I have a 1991 Capri,running the 1.6lt. dohc NA engine,extractors,2.5 inch hi flow cat and zosrt,cold air intake and injectors and fuel pump/regulator from a 2 lt engine.Any suggestions on a suitable performance cam would be appreciated.Thanks..... |
commandojones Fordmods Newbie
Age:20 Posts: 16 Joined: 04 Oct 2007 Location: Melbourne VIC, Australia
Posted: Thu Jun 05, 2008 5:01 pm Post subject: |
Hi guys,
Ive got a wade 1636 regrind cam in my old motor which is sitting at home. It was an EB II camshaft sent to Wade cams for the 1636 grind. Its only down 7,000kms tops. (put a tickford el motor in) If anyone is interested im looking to sell it for between $85-100. Id have to pull it out of the head i could throw in the etc new shims for $30. |
Posted: Thu Jun 05, 2008 6:12 pm Post subject: |
pm sent  |
Wade Cams
Posted: Fri Jun 06, 2008 7:20 am Post subject: |
| 1965tbird wrote: | pm sent  |
PM not received. |
WILDEB Fordmods Stock as a Rock
Age:19 Posts: 192 Joined: 11 Mar 2008 Location: Bendigo VIC, Australia
Posted: Fri Jun 06, 2008 7:33 am Post subject: |
| i have an EB 'S' on dual fuel, pod filter, it's a early 3.9L MPEFI model, auto. what cam will give me good power throughout the whole rev range. atm it's got nothing until 2000rpm |
Posted: Fri Jun 06, 2008 7:59 am Post subject: |
| Wade Cams wrote: | | Shortshift wrote: | 1. I've got a 4 speed auto gearbox. I read through all the posts and Wade's recommendations on this forum before choosing the cam.
I installed the cam first, injectors & vernier gear next, and then had it dialed in & dynoed. The car idled a bit better after the injectors were replaced. The oxygen sensor was replaced as well but that didn't alter anything. I think this is just a glitch with my engine alone if no-one else has any problems. |
Wade Cams
Posted: Fri Jun 06, 2008 1:42 pm Post subject: |
| Shortshift wrote: | | Wade Cams wrote: | | Shortshift wrote: | 1. I've got a 4 speed auto gearbox. I read through all the posts and Wade's recommendations on this forum before choosing the cam.
I've got no suggestions I'm afraid. It would certainly seem to a rare problem. Naturally, whilst l couldn't be 100% certain, l'd be reasonably confident that it's not a cam problem. |
Wade Cams
Posted: Fri Jun 06, 2008 1:47 pm Post subject: |
| EB S-pac wrote: | | i have an EB 'S' on dual fuel, pod filter, it's a early 3.9L MPEFI model, auto. what cam will give me good power throughout the whole rev range. atm it's got nothing until 2000rpm |
Firstly, no cam will give good power through the whole rev range. A cam that works well down low will generally "ease off" at the top end. Likewise, a cam that works well at the top end will, generally, not start working until 3000rpm or more.
The grind that we normally recommend where there's an auto is our 1636.
It starts to work from 2300/2500 and goes through to the rev limiter.
That would be our suggestion for you. |
[47 queries :: 0.54251 seconds ]
