FORUM OPEN FOR POSTING
Goto page Previous  1, 2, 3 ... 22, 23, 24, 25, 26, 27  Next
Post new topic   Reply to topic    Forum Index -> Wade Cams
stoj79
PostPosted: Sat Aug 30, 2008 9:01 pm    Post subject: Reply with quote
Hi Guys
Can anyone here give me some ideas on how the 1673 cam woudl run with a supercharger woudl it benefit ......? as im thinkn of doin the raptor kit but trying with the cam i have in atm
Wade Cams
Commercial Sponsor
PostPosted: Mon Sep 01, 2008 8:43 am    Post subject: Reply with quote
stoj79 wrote:
Hi Guys
The 1673 works fine with a supercharger. Not much more l can add really.
stoj79
PostPosted: Mon Sep 01, 2008 8:58 am    Post subject: Reply with quote
Hi Chris
Could u please reccomend me a cam to suit a supercharger setup something with not alot of overlap i currently have the 1673 and also could we make it somewhat more lopey at idle
cheers steve
sd1800
PostPosted: Tue Sep 02, 2008 9:03 am    Post subject: Reply with quote
Hi guys, I'm thinking of fitting a 1636 to my car listed in my signature. I asked a mechanic if he would be able to fit it for me but he advised against it, saying that installing a warmer cam will disrupt the internals of a motor with the mileage mine has(244,000 on the bottom end, about 75,000 on the head), and cause more problems than advantages.
Do I have anything to worry about or should I probably just leave it the way it is? Btw its a Auto.
Wade Cams
Commercial Sponsor
PostPosted: Tue Sep 02, 2008 4:02 pm    Post subject: Reply with quote
stoj79 wrote:
Hi Chris
cheers steve
Steve....more overlap is, shall we say, condusive to a lopey idle. Reduced overlap will make the idle smoother.
You could go the the 977B profile, which is just slightly "hotter" than the 1673. You could not expect to see a big difference however.
Chris
Wade Cams
Commercial Sponsor
PostPosted: Tue Sep 02, 2008 4:12 pm    Post subject: Reply with quote
Your mechanic has made a valid point. It is possible that, fitting a "warmer" cam into an engine with 244,000 on the clock could place a strain on a "tired" engine. It's not a hard and fast rule one way or the other. The engine is probably due for a freshen up now or in the not too distant future. Maybe you should consider doing the "freshen up" and improved cam at the same time.
Having said all that, you could also fit the cam and have no problems. Who knows.
Chris
stoj79
PostPosted: Tue Sep 02, 2008 7:04 pm    Post subject: Reply with quote
Thanks Chris
Ill see how i go with the 1673 for now i think in that case
Thanks for you4r advise
sd1800
PostPosted: Tue Sep 02, 2008 7:21 pm    Post subject: Reply with quote
Chris
Ok mate, thanks for your advice & I'll keep it in mind.
BaYa
PostPosted: Wed Sep 03, 2008 7:55 pm    Post subject: Reply with quote
Hey Chris
i don't know much about cams, but from the cam list in the "6 cylinder workshop" i saw the 1636 or 1673 being my best option then saw that you recommend the 1636 to anybody with and auto, which i have so im just wondering the power differences between the standard el xr6 cam and the wade 1636 cam ? also does it add a bit of a burble the the exaust note ?
thanks Richard
TROYMAN
View User Gallery (26)
PostPosted: Thu Sep 04, 2008 10:06 am    Post subject: Reply with quote
hi
is there any news on the availability of billet cams for el hybrid or au..
Wade Cams
Commercial Sponsor
PostPosted: Thu Sep 04, 2008 4:07 pm    Post subject: Reply with quote
BaYa wrote:
Hey Chris
thanks Richard
Richard, as far as the cam itself is concerned, the EL XR6 is virtually identical to a standard cam. The extra "power" that is attributed to the XR6, over a standard motor, must be achieved by other mods, the XR6 cam of itself will do "bugger all". So, the 1636 is an improvement, performance wise, over the XR6 cam. To be honest, l'm not sure about the exhaust note, l've never had the opportunity to listen to one.
Chris
Wade Cams
Commercial Sponsor
PostPosted: Thu Sep 04, 2008 4:09 pm    Post subject: Reply with quote
TROYMAN wrote:
hi
We got a couple of AU billets on Tuesday. They no sooner arrived and our supplier rang to say they had some concerned about the "hardness" values of batch of cams in question.
We're going to have to pre-grind a couple of lobes at random and then do a hardness test. Fingers crossed.
Chris
TROYMAN
PostPosted: Thu Sep 04, 2008 4:30 pm    Post subject: Reply with quote
Wade Cams wrote:
TROYMAN wrote:
hi
Chris
ok can you keep us posted?
im pretty keen on gettin a billet asap..
FordFairmont
PostPosted: Thu Sep 04, 2008 5:04 pm    Post subject: Reply with quote
Ive ran a few Wade regrinds and they perform just as well as a billet, and i cant say it ran any noisier than a billet. In fact my last Wade regrind made more power than my current Wade billet
Plus theyre 3 times cheaper than a billet lol
TROYMAN
PostPosted: Thu Sep 04, 2008 6:43 pm    Post subject: Reply with quote
i have no doubt that a re grind will do the job fine..
but i would prefer a billet.(no shims = no probs)
i had a re grind in my old 3.9 engine that went great but it had a strange habit of breaking the 2nd shims on the exhaust side (3 times actually) for some reason.? and the constant rattle p****d me of to the point of removing the shims and re fitting the std cam..
i know a few guys who run re grinds with no rattles or problems.
but ive just become fussy and a bit lazy and i like simplicity of fitting the cam without pulling the hla's apart..
and the price dont worrie me..
Wade Cams
Commercial Sponsor
PostPosted: Tue Sep 16, 2008 7:33 am    Post subject: Reply with quote
TROYMAN wrote:
Wade Cams wrote:
TROYMAN wrote:
hi
Chris
The hardness scare in respect to the recently delivered AU billets has been resolved. False alarm actually.
So, the AU billets are available for anyone who wants to get one ground.
eseriesaddict
PostPosted: Tue Sep 16, 2008 11:02 am    Post subject: Reply with quote
G'day
I have an ED Fairmont with a T5 box and an exhaust and a stage 1 Crow Cam. I am looking into putting in one of your 1673 cams and have been looking at Grechies build uo there and am inspired. Will the 1673 run fine with the stock ECU and is there anything else you would recommend doing to the motor to get a significant gain. I use is as a daily driver but also down for the legal drags every now and then. Would really appreciate your feedback
Thanks in advance
Jamo
Wade Cams
Commercial Sponsor
PostPosted: Tue Sep 16, 2008 2:07 pm    Post subject: Reply with quote
eseriesaddict wrote:
G'day
Thanks in advance
Jamo
The 1673 is OK with a std ECU. You need to reset it, and there is still a learning period afterwards, but it will run well, no problemo.
The more effort you're willing to put in to tuning it up properly, the better result you'll get.
Chris
89S-PACK
PostPosted: Wed Sep 17, 2008 10:51 pm    Post subject: Reply with quote
hi chris..
ive got a xf ute that has the 250 crossflow in it.
im currently recoing the motor. and wondered which cam would be better?
its on duel fuel. automatic. extractors. and i do tow with the ute.
so i cant go silly with it considering its a daily hack.
these 3 are the ones i found on your site.. but i dunno which one would be better
933
242b 328b
242a
would i need better springs with these?
the auto is standard.. and the reco engine basically is standard too.
also are these regrinds? if so how much?
and how soon could i get the cam profile i chose?
89S-PACK
PostPosted: Wed Sep 17, 2008 10:53 pm    Post subject: Reply with quote
oops forgot to mention..
the motor doesnt have est anymore. a xe electronic dizzy had been fitted in its place
Page 23 of 27
[47 queries :: 0.07534 seconds ]
