GRN-WGN Fordmods Stock as a Rock
Posts: 150 Joined: 30 Mar 2005 Location: geelong VIC, Australia
Posted: Tue Jun 05, 2007 5:29 pm Post subject: |
| y would the cam idle differently in a manual car to an auto car? iv got a manual ed xr6 on straight gas so what is the best cam for me? |
EF-XRAN Fordmods Stock as a Rock
Age:21 Posts: 153 Joined: 09 Feb 2006 Location: Perth WA, Australia
Posted: Thu Jun 07, 2007 5:30 pm Post subject: |
hey I'm looking at purchasing a 1636 off someone, but I want to check the base circle and journals with verniers/micrometer to make sure it's correct as someone I know has had trouble with a regrind before.
Gregory's manual says that for the EF head the journals should be 37.94-.96mm diameter with no more than .013mm out of round which is all good... but nowhere can I find what the base circle should be. Any help sooner rather than later greatly appreciated!
-Jaison |
Steady ED Fordmods Addict
Age:22 Posts: 6865 Joined: 01 Jun 2005 Location: Melbourne VIC, Australia
Posted: Thu Jun 07, 2007 6:22 pm Post subject: |
| EF-XRAN wrote: | hey I'm looking at purchasing a 1636 off someone, but I want to check the base circle and journals with verniers/micrometer to make sure it's correct as someone I know has had trouble with a regrind before.
-Jaison |
http://www.fordmods.com/forums/viewtopic.php?t=39726&start=0
That thread covers it.
From there...
| Wade Cams wrote: | Base circle diameter for the 94DA is 2.090"
Lobe lift EX. 0.227" IN. 0.237"
Chris
WADE CAMS |
Obviously for 94DA, but should be roughly comparable to whatever cam the 1636 is ground on. |
Posted: Thu Jun 07, 2007 8:23 pm Post subject: |
thanks mate
the 1636 is sitting here now, just waiting to get my head back and then maybe next weekend might see the rocker gear interchanged - the cam didn't need checking. Totally unused and still had red grease on it from when it was packed away to be transported! |
Wade Cams
Age:55 Posts: 280 Joined: 08 Nov 2004 Location: Melbourne VIC, Australia
Posted: Fri Jun 08, 2007 10:08 am Post subject: |
Has anyone posted an inquiry on this thread that hasn't received a reply?
Please let me know.....I'll apologise in advance if l've overlooked any posts.
I'd like to suggest that it would probably help if you were to post a new thread if your comments are based on a new inquiry. Alternatively, a PM would be good. When you get a stream of posts, it's hard to keep up. At least it is for people who suffer from oldtimers disease like l do.
Chris |
Posted: Fri Jun 08, 2007 6:58 pm Post subject: |
Just tried posting a new thread and it says I need to be a Mod to do it.
Regarding the 1636, is it ok on std springs? I have an ef series 1. The other thing I'm wondering is with the lift of the 1636 will it be ok on a standard EF head after being decked 20thou or will it put dents in my crowns?
Cheers,
Jais |
Wade Cams
Posted: Fri Jun 08, 2007 8:47 pm Post subject: |
| EF-XRAN wrote: | Just tried posting a new thread and it says I need to be a Mod to do it.
Cheers,
Jais |
Thanks Jais. It never occurred to me that there may be restrictions about posting a new thread. Oh well.
The 1636 will work fine with standard springs. I suspect it will also be OK with a "decked" EF head. I'll check on Monday with my technical guys. Actually...make that Tuesday. I forgot, Monday's a holiday.
Chris |
ISQUIK Fordmods Stock as a Rock
Posts: 197 Joined: 24 Nov 2006 Location: Frankganistan VIC, Australia
Posted: Mon Jun 11, 2007 4:48 pm Post subject: |
Chris,
With a cam re-grind what is actually done?
How is like added and profile altered?
Another question what cam profile would be recommended for an el I6 motor running upto about 15psi and a fair bit of head work?
Adam |
Wade Cams
Posted: Tue Jun 12, 2007 9:25 am Post subject: |
| ISQUIK wrote: | Chris,
Adam |
Thanks Adam
It's an often asked question. How can you remove material from a cam lobe and end up with more lift. In simplistic terms, you grind more off the base circle of the lobe than you do on the nose. i.e. If you reduced the base circle by 0.050" on radius and took almost nothing off the nose, you end up with just under 0.050" more lift than when you started.
As far as your recommendation is concerned, is your vehicle a manual or an auto? Is it just a daily drive?
Chris |
xf4ltrturbo Fordmods Parts Gopher
Posts: 58 Joined: 03 Jul 2005 Location: melbourne VIC, Australia
Posted: Tue Jun 12, 2007 7:08 pm Post subject: |
| hey guys can you please tell me wot kind of cam & price for eb 4ltr-straight lpg-gt3540r turbo-c9 auto with 2500 convertor-3.23 diff.want to aim for the 300kw mark @ the rears.comp is 7.6:1.ecu is wolf 3d but the old version.i would like a rough idle if possible but not extreme.thanks alot.jas...if you need any more info please let me know.... |
Age:24 Posts: 2188 Joined: 07 Feb 2005 Location: melbourne VIC, Australia
Posted: Tue Jun 12, 2007 8:09 pm Post subject: |
| Dansedgli wrote: | | Do you guys have any plans to develop cams for the BA motors? Both NA and turbo? |
You missed my question.  |
MikeSmith Fordmods Oompa Loompa
Age:20 Posts: 36 Joined: 10 Jul 2006 Location: Perth WA, Australia
Posted: Wed Jun 13, 2007 1:44 am Post subject: |
| Do you guys do cams for the AU as well or is just for the E series? |
Wade Cams
Posted: Wed Jun 13, 2007 7:57 am Post subject: |
| Dansedgli wrote: | | Dansedgli wrote: | | Do you guys have any plans to develop cams for the BA motors? Both NA and turbo? |
Sorry about that chief.
In short, we did do some development work on the BA cams some time ago. There were a number of technical issues that resulted and, at present, we don't have any plans to renew the development.
I believe other people in our industry have also had problems and are pulling away from doing anything at this time.
Sorry
Chris |
Wade Cams
Posted: Wed Jun 13, 2007 7:58 am Post subject: |
| MikeSmith wrote: | | Do you guys do cams for the AU as well or is just for the E series? |
We are in the process of producing a profile for the AU that is similar, specs wise, to the E series 1636 profile. Stay tuned.
Chris |
Posted: Wed Jun 13, 2007 8:05 am Post subject: |
| Thanks for the reply. |
Wade Cams
Posted: Wed Jun 13, 2007 8:06 am Post subject: |
| xf4ltrturbo wrote: | | hey guys can you please tell me wot kind of cam & price for eb 4ltr-straight lpg-gt3540r turbo-c9 auto with 2500 convertor-3.23 diff.want to aim for the 300kw mark @ the rears.comp is 7.6:1.ecu is wolf 3d but the old version.i would like a rough idle if possible but not extreme.thanks alot.jas...if you need any more info please let me know.... |
I couldn't imagine any cam that we have that could get even close to 200rwkw, much less 300. I don't claim to be an expert on the E series 6 motor but l would have thought that even a massively worked engine with twin turbos could get 250rwkws. I could be wrong.
Anyway, we've got nothing that will achieve the result you're looking for.
Chris |
Age:19 Posts: 1017 Joined: 27 Mar 2006 Location: Brisbane QLD, Australia
Posted: Wed Jun 13, 2007 4:36 pm Post subject: |
| Wade Cams wrote: | | xf4ltrturbo wrote: | | hey guys can you please tell me wot kind of cam & price for eb 4ltr-straight lpg-gt3540r turbo-c9 auto with 2500 convertor-3.23 diff.want to aim for the 300kw mark @ the rears.comp is 7.6:1.ecu is wolf 3d but the old version.i would like a rough idle if possible but not extreme.thanks alot.jas...if you need any more info please let me know.... |
Chris |
a guy on this forum got 450odd rwkw from a single turbo setup, a fair few are getting around 250rwkw.. |
Posted: Wed Jun 13, 2007 8:21 pm Post subject: |
| thanks for the reply |
wild_ef Fordmods Tyre Shredder
Age:19 Posts: 311 Joined: 09 Jun 2007 Location: Rockingham WA, Australia
Posted: Wed Jun 13, 2007 8:51 pm Post subject: |
yeah pyro is around 450kw?? (soz for off topic)ive read through this forum n cant find the exact answer im looking for
which would suit my motor better 1604, 1636 or 1673?
car is ef fairmont auto only engine mods are exhaust and extractors, dont plan on changing ecu or diff gears anything like that.
tyou site says 1604 suits autos so is that my best bet? |
Wade Cams
Posted: Thu Jun 14, 2007 7:48 am Post subject: |
| skidder wrote: | | Wade Cams wrote: | | xf4ltrturbo wrote: | | hey guys can you please tell me wot kind of cam & price for eb 4ltr-straight lpg-gt3540r turbo-c9 auto with 2500 convertor-3.23 diff.want to aim for the 300kw mark @ the rears.comp is 7.6:1.ecu is wolf 3d but the old version.i would like a rough idle if possible but not extreme.thanks alot.jas...if you need any more info please let me know.... |
Chris |
My apologies "Skidder", you are quite correct. My thinking revolved around a N/A engine rather than a turbo. Total brain fade.
Anyway....can you tell me how much boost you are running, or planning to run?
Chris |
[47 queries :: 0.0753 seconds ]
