FORUM OPEN FOR POSTING
Goto page 1, 2, 3 ... 20, 21, 22  Next
Post new topic   Reply to topic    Forum Index -> Wade Cams
Wade Cams
Commercial Sponsor
PostPosted: Mon Apr 23, 2007 4:08 pm    Post subject: FORUM OPEN FOR POSTING Reply with quote
Members are advised that the WADE CAMS forum has been modified to allow members to post topics direct to our forum.
Obviously, we would ask that posts be confined to topics specifically related to WADE CAMS.
Cheers from the team at Wade Cams
MooseMan
PostPosted: Mon Apr 23, 2007 4:17 pm    Post subject: Reply with quote
Can you guys give me info on any cam you might have to suit the EL hybrid motor? I have a march 98 build EL fairmont and want an aftermarket cam. Can you help?
horis
PostPosted: Mon Apr 23, 2007 6:11 pm    Post subject: Reply with quote
how much for a 1636cam including postage to brisbane
Wade Cams
Commercial Sponsor
PostPosted: Tue Apr 24, 2007 8:18 am    Post subject: Reply with quote
We should be able to help you there. We need to know as much as possible about the engine mods you have, or are planning....Manual or auto.....and what you want to achieve. In other words, is it just a daily drive or, a daily drive combined with legal drags....that sort of thing.
Chris
Wade Cams
Commercial Sponsor
PostPosted: Tue Apr 24, 2007 8:21 am    Post subject: Reply with quote
I'm assuming you're talking about a regrind.
To do a regrind cam, the cost is $122.00. Registered Post to Brisbane would be approx. $20.00. If we supply an exchange cam, there is a deposit of $110.00 added to the cost. This deposit is refunded to you when you return a suitable replacment cam to us.
Also note, as with all our reground cams, you will need to fit an extra set of 1.9mm standard shims. You can purchase these from your local Ford dealer for about $60.00.
Chris
rushed
PostPosted: Tue Apr 24, 2007 3:50 pm    Post subject: Reply with quote
when there is news back on how the 1636>977b cam is going, post them up please, as im after a cam for my new motor and this sounds good just want to see where power band is, 1/4 improvment times
Damo
PostPosted: Tue Apr 24, 2007 5:35 pm    Post subject: Reply with quote
Are you still producing the 1521A as a billet ? also do you sell upgraded valve springs ?
horis
PostPosted: Tue Apr 24, 2007 6:19 pm    Post subject: Reply with quote
what if i supplied one down there first as i got a spare standard cam sittin in the garage so i got all the shims needed as i have the spare motor
TURBO_GHIA
PostPosted: Tue Apr 24, 2007 8:11 pm    Post subject: Reply with quote
what cams do you do for turbo setups? on a EL i6? and prices
Wade Cams
Commercial Sponsor
PostPosted: Thu Apr 26, 2007 7:37 am    Post subject: Reply with quote
Yes, we still supply the 1521A cam as a billet.
Yes, we can supply "performance" valve springs.
Wade Cams
Commercial Sponsor
PostPosted: Thu Apr 26, 2007 7:39 am    Post subject: Reply with quote
Yes, that's fine. It's up to you if you want to send your own cam for grinding.
Wade Cams
Commercial Sponsor
PostPosted: Thu Apr 26, 2007 7:41 am    Post subject: Reply with quote
Please advise.....manual or auto? How much boost are you going to run?
TURBO_GHIA
PostPosted: Thu Apr 26, 2007 5:26 pm    Post subject: Reply with quote
auto,12psi
Wade Cams
Commercial Sponsor
PostPosted: Fri Apr 27, 2007 8:05 am    Post subject: Reply with quote
TURBO_GHIA wrote:
auto,12psi
With the auto, and presumably a std converter, you'd be limited to the 1636 profile. There's no point putting a cam in that's suited to the turbo but that's too much for the transmission.
If you're running a high stall, you could consider a single pattern cam such as the 977B (open up the lobe centre to 115).
Either profile on your cam is $122.00. Exchange, add $110.00 deposit.
Freight, extra, if applicable.
Chris
nlbxr6
View User Gallery (17)
PostPosted: Fri Apr 27, 2007 10:31 pm    Post subject: Valve springs to suit Reply with quote
I will be purchasing a camshaft from you guys shortly
Could you advise on availability and price on a good set of valve springs
and which camshaft will be best suited
I6 Tickford engine T04 3.9 ACL pistons balanced mild port work custom
plenum up to around 16 psi 5 speed with 3.27 diff
locknut
PostPosted: Sun May 06, 2007 3:12 pm    Post subject: Reply with quote
Hi Chris, I'll be calling you tomorrow about the 1636 to order this week for my EA, it's blown a head gasket, and we're putting in a new cam at the same time.
Other thing is a suggestion, if you could maybe add a thread to this area with all the Ford 6cyl + 8cyl cam profile names + specs + rpm ranges (approx) with a comments field, eg: "good idle, suit std ECU" or "needs extractors and exhaust" or "requires porting + ECU modifications" etc..
I just can't get to see this info on the site? is it in development, or that area down?
locknut
PostPosted: Sun May 06, 2007 7:56 pm    Post subject: Reply with quote
Kenwood Maverick
PostPosted: Mon May 07, 2007 3:10 pm    Post subject: Reply with quote
never ran the 1636, but locknut i would suggest looking at the 1636977b, its working magic in my EA atm. Going on the dyno on saturday, you should come for a run up with us to katoomba and get ya beast measured, i think data_mine is still coming from ACT??
locknut
PostPosted: Tue May 08, 2007 7:34 am    Post subject: Reply with quote
Cheers Mav, I did enquire about that cam, but in al honesty Chris suggested the slightly less aggressive 1636 as a more sensible option due to the k's on my car.
This will be my first cam in any car, so it's exciting none-the-less icon_biggrin.gif
Because the 1636 is a more low-mid range cam, I'm also thinking the 4499's would suit it rather than the 4480's...
pHaT`eL
PostPosted: Tue May 08, 2007 2:01 pm    Post subject: Reply with quote
G'day , Ive got a 98 EL Fairmont, and have been thinking about getting a cam for it.
Its a hybrid motor, with an auto, extractors, exhaust, etc, and is a daily driver.
Have you got anything to suit?
Cheers, Pete.
Page 1 of 22
[47 queries :: 0.05651 seconds ]
