Timmeh Moderator
Posts: 6205 Joined: 06 Nov 2004 Location: Perth WA, Australia
Posted: Thu May 08, 2008 1:54 pm Post subject: |
| ELXR6lookalike wrote: | | pacemaker used to make a header to suit gt50P's on s-series but stopped making them due to low demand. they told me they don't have anything to suit that application anymore. |
Guess I'm sticking with the ELGT headers then. |
ELXR6lookalike Fordmods - Getting Side Ways
Posts: 414 Joined: 20 Jun 2005 Location: melbourne VIC, Australia
Posted: Thu May 08, 2008 1:57 pm Post subject: |
| there are headers out there that are designed for E7's but still work with GT40P's it's just a bit of hit or miss as to which ones do and don't work. I have hi-tech's on my LTD with GT40P's and i couldn't be happier, there cheap and there designed for E7's but fit the 40P's. I have 8.8mm top gun leads with 45deg boots on them and haven't got a problem, although i have billet lead seperators which help and the leads are custom made too be a little longer than stock. |
richie Fordmods Stock as a Rock
Age:55 Posts: 163 Joined: 09 Nov 2004 Location: perth WA, Australia
Posted: Thu May 08, 2008 3:10 pm Post subject: Re: Headers for GT40P heads. |
| steven13 wrote: | Hi guys, have had a read through posts but couldn't find no real answer. I have Hitech headers on my EL XR8 and have installed GT40P heads. Only spark plug I have trouble with is number 4 cyc with leads and need to loosen pipes to get to plug. Are there any headers out there that you don't have to loosen or remove headers just to change plugs, plus still use original leads with 45 deg boot. If not where do you guys get your leads made up. Mine on no4 needs protection as I've already melted 1 lead.
Thanks Steve |
I too ran hitech's with the GT40P's - #4 plug was a problem. Heated the bend in the tube & knocked it in a bit with a ball pein hammer - no problem after that.
I dont think the Hitech's really suit the GT40P's ( if they are the same as I had on mine) as they were still very restrictive - I dont think they can move that volume of gas. Tossed them & bolted on Pacies PH4000's - gases certainly flowed better but may have lost a little down low.
Richie |
s-tranzor Fordmods Tyre Shredder
Age:24 Posts: 302 Joined: 29 May 2007 Location: Perth WA, Australia
Posted: Thu May 08, 2008 3:22 pm Post subject: |
| ^^The HM headers I am replacing have a prob with #2 and #5. Could sort the prob out like you did, but need more flow in the end. and banging in some clearance would probably add more flow restriction. If the pipes dropped down an extra centimeter or 2 there would be no problems with lead clearance... sux. |
Posted: Thu May 08, 2008 3:36 pm Post subject: |
| Scaffy wrote: | | s-tranzor wrote: | | Scaffy wrote: | By the sounds of things I'm glad I never fitted the GT40Ps to my engine. The plugs come in and out of the twisted wedge heads a piece of piss!  |
They come out of the GT40ps the same... just the lead boot that gets stuck on some types of headers. |
Ah ok. Then the DiFillipos are the go then cos there's plenty of clearance. I think my boots are 45s.
They seem to be a little big for my application at the moment though. Not sure whether to downsize to tri-ys til I stroke it or just leave them as is. |
Geez Scaffy, why didnt you say something before? We could just swapped headers and saved an a*** of money on new headers haha, the HM's I have at the moment are Tri-Y. |
Age:30 Posts: 923 Joined: 26 Nov 2006 Location: Perth WA, Australia
Posted: Thu May 08, 2008 9:46 pm Post subject: |
Just what I was thinking earlier mate!
One thing to look out for on the De Fillipos is the welds. I've had problems with them leaking from day dot. Had the gaskets changed a number of times, all to no avail. Took it to Prestige and Dom had a look and listen. As it turns out, they're not leaking from the gasket, it's the vertical welds between the primary and the flange. Because they're larger primaries, they have to weld the verts on the inside so there's still clearance for the bolts. It's some of these welds that have failed. I'm yet to get it fixed, just need the time. |
Age:24 Posts: 1581 Joined: 25 May 2006 Location: Perth WA, Australia
Posted: Fri May 09, 2008 12:02 am Post subject: |
Advance Headers make a GT40P INTO E SERIES HEADER.
I have em in my car, I'll take a pic tomorrow and show them.
I had them installed when I was planning to use them, glad I still went with the advance headers over Pacemakers, they did great things for the car stock (189 rwhp, e7 heads and HO manifold, auto) and I might be looking towards GT40p heads, or more. |
Timmeh Moderator
Posted: Fri May 09, 2008 9:47 am Post subject: |
schnoods do you know what part number?
I've had a look at their website and they have E series and AU series V8 headers but nothing specific for AU heads on E series. |
Posted: Fri May 09, 2008 12:54 pm Post subject: |
| Scaffy wrote: | Just what I was thinking earlier mate!
Oh ok, thanks for the tip Scaffy. The extractors just landed @ Dom's today so I'll ask him to have a quick lookie before they get put on this wednesday  |
ALS008 Fordmods Parts Gopher
Posts: 60 Joined: 26 Apr 2008 Location: Melbourne VIC, Australia
Posted: Mon May 12, 2008 9:36 pm Post subject: |
Does anyone know who sells/disributes hurricane headers in Vic, from what i have read these seem to be the go in the old windsors along with a twin 2.25" systerm.
Also when you guys talk about a good twin system, do you mean twin the whole way trough. I get it will be twin from the cats to the diff, but is it possible for to fit twin pipes over the diff and to the back of the car. It seems a tight area where the factory pipes run around the guards and bumper. Could you guys post some pics of you twin systems, im keen to see them?? |
Vic Cruise Moderator
Age:37 Posts: 5489 Joined: 05 Nov 2004 Location: Melbourne VIC, Australia
Posted: Mon May 19, 2008 9:47 pm Post subject: |
| PH4000 will fit the GT40P heads but a couple of plugs need a 90° boot while the rest can be a regular 45°. |
Posted: Wed Jun 11, 2008 12:06 pm Post subject: |
| Does anyone still use recomment Genie Extractors. All the places i talked too said " Genie arn't what Genie used to be 15 yrs ago, Go with Pacemaker" |
BuNtEr Technical Contributor
Age:41 Posts: 3228 Joined: 12 Feb 2007 Location: your mums NSW, Australia
Posted: Wed Jun 11, 2008 1:43 pm Post subject: |
| Timmeh wrote: | | What pacemakers will fit GT40Ps on E series leads? |
i think you will find they are the p4000 headders from PM |
Posted: Wed Jun 11, 2008 1:44 pm Post subject: |
Posted: Thu Jun 12, 2008 12:25 pm Post subject: |
| ALS008 wrote: | | Does anyone still use recomment Genie Extractors. All the places i talked too said " Genie arn't what Genie used to be 15 yrs ago, Go with Pacemaker" |
Anyone - your thoughts?? I have been quoted:
* $850 for pacies fitted
* $750 for hi-tech fitted
* $800 for Genie fitted |
Steady ED Fordmods Addict
Age:22 Posts: 6728 Joined: 01 Jun 2005 Location: Melbourne VIC, Australia
Posted: Thu Jun 12, 2008 1:01 pm Post subject: |
| Don't get genies with 40Ps, they suck. |
Posted: Thu Jun 12, 2008 1:03 pm Post subject: |
| Steady ED wrote: | | Don't get genies with 40Ps, they suck. |
What's the result? Bad scavenging? |
Posted: Thu Jun 12, 2008 1:08 pm Post subject: |
| Vic wrote: | | Steady ED wrote: | | Don't get genies with 40Ps, they suck. |
No, bad doing plugs and F**k all lead clearance
Other then that they are good.
Daves got genies on his, so they seem to work okay  |
