red rocket Fordmods Parts Gopher
Age:35 Posts: 60 Joined: 05 Nov 2004 Location: kilsyth VIC, Australia
Posted: Thu Jan 13, 2005 6:29 pm Post subject: Help identifing ef/el ecu's |
Ok at the wreckers i do maintance for they have a big box full of eec-v but when they pulled them out they havent marked what model they have come out of. So does anyone one no the part numbers, want to see if they have anything worth puttin in the ol' ef.
Now from what i have been told the inside of the plug for ef is blue but the only blue one there was marked out of a au but there was plenty of red socket ones with numbers like 6bdd and so on.
can anyone help out here identifing what they have got. |
Posted: Thu Jan 13, 2005 11:06 pm Post subject: |
| The first number identifies the year of the EEC, 6bdd means its a 1996 EEC which is probably an EL one (The EL EEC's should have less pins compared with the EF and AU ones as far as I am aware, so that could also help). So look for I6 EEC's starting with 4 and maybe 5. |
XR9UTE EFI Guru
Age:43 Posts: 1412 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Fri Jan 14, 2005 11:51 am Post subject: |
EF 4.0L and 5.0L are 104pin.
EL 4.0L are 60pin.
EL 5.0L are 104pin.
Pete. |
smee Fordmods Stock as a Rock
Posts: 180 Joined: 07 Nov 2004 Location: Widebay QLD, Australia
Posted: Mon Jan 17, 2005 8:14 pm Post subject: |
| @pete, wouldn't know what a AU1 I6 auto 3.23 pre SmartShield ECU has on it? |
XR9UTE EFI Guru
Posted: Tue Jan 18, 2005 12:32 pm Post subject: |
In terms of what? Catch code? No, but it would have to be a very early part# Like an F8 or F9 prefix.
Pete. |
Posted: Tue Jan 18, 2005 4:33 pm Post subject: |
what i am trying to find out is what model these ecu's came out of,ie falcon or fairmont etc.
but all of them are out of el's so there no good to me as i have a ef. |
4.9 EF Futura Moderator
Posted: Tue Jan 18, 2005 4:43 pm Post subject: |
Will need to know the catch code for falcon, fairmont etc. AFAIK there isnt a comprehensive list of these anywhere.
BTW a 60pin EEC could be anything from XF to ED or EL (EF/AU have 104pin, as do EF/EL/AU V8). |
AU2SR Technical Contributor
Age:39 Posts: 169 Joined: 05 Nov 2004 Location: MELBOURNE VIC, Australia
Posted: Tue Jan 18, 2005 5:43 pm Post subject: Re: Help identifing ef/el ecu's |
| red rocket wrote: | Ok at the wreckers i do maintance for they have a big box full of eec-v but when they pulled them out they havent marked what model they have come out of. So does anyone one no the part numbers, want to see if they have anything worth puttin in the ol' ef.
Jot down the numbers amber and e-mail them to my work e-mail and i will identify them 4 you |
MrLandau
Posted: Tue Jan 18, 2005 9:35 pm Post subject: |
EMF had a full listing on the XE-EL computers as a PDF document - I have a print out at home but I am at work
Maybe someone else has downloaded it (Drone maybe?)
Shane |
Amber Fordmods Junkie
Age:26 Posts: 5402 Joined: 05 Nov 2004 Location: Sunny/Raining/Freezing/Boiling Melbourne! VIC, Australia
Posted: Wed Jan 19, 2005 11:02 am Post subject: |
| that sounds like what i'm looking for if you could find that list that would be great. |
el_747 Fordmods Parts Gopher
Age:23 Posts: 85 Joined: 05 Nov 2004 Location: Melbourne VIC, Australia
Posted: Fri Jan 21, 2005 6:13 pm Post subject: |
i got my part number off my EL ecu 96DA12A650BB does anyone know if its a EL ex cop ecu.
Cheers Rick |
Posts: 2013 Joined: 06 Nov 2004 Location: Canberra - The Nations Capital ACT, Australia
Posted: Fri Jan 21, 2005 7:23 pm Post subject: |
I found these EF catch codes in an old FordMods web page.
4TED - EF GLI DUAL FUEL I6
5DCA - EFII FAIRMONT GHIA TICKFORD
4DEG - EF FAIRMONT V8
4DKF - EF GLI V8
4DCC - EF FAIRMONT GHIA I6
5DBB - XH -97 PANEL VAN I6
All auto's.
Don't know if this help you.
TW. |
Age:27 Posts: 4680 Joined: 24 Nov 2004 Location: Canberra ACT, Australia
Posted: Fri Jan 21, 2005 7:51 pm Post subject: |
I've got an EL I6 Cop ECU here (60-pin).
Catch Code: 6DNB
PArt #: 96DA-12A650-NB
Barcode: HH1EA236S0VW
My Stock ECU.
Catch Code: 6DBD
Posted: Fri Jan 21, 2005 9:31 pm Post subject: |
| 4DCG - EF Fairmont 4.0L 3.23 auto |
xr8 dismantler
Age:37 Posts: 3060 Joined: 06 Nov 2004 Location: MELBOURNE VIC, Australia
Posted: Fri Jan 21, 2005 11:04 pm Post subject: |
| red rocket wrote: | what i am trying to find out is what model these ecu's came out of,ie falcon or fairmont etc.
i think i know about this box full of computers
are these numbers among the ones you have
96da 12a650 - le is south african export 4ltr auto (6DLE)
96da 12a650 - nb police 4 ltr auto (6DNB)
96dt 12a650 - ad el xr6 manual (6TAD)
Last edited by xr8 dismantler on Tue Jan 25, 2005 10:54 pm, edited 1 time in total |
Posted: Sat Jan 22, 2005 12:28 am Post subject: |
| xr8 dismantler wrote: | | red rocket wrote: | what i am trying to find out is what model these ecu's came out of,ie falcon or fairmont etc.
96da 12a650 - le is south african export 4ltr auto (6DNB)
96da 12a650 - nb police 4 ltr auto (6DLE)
96dt 12a650 - ad el xr6 manual (6TAD) |
I think you're first two catch code / part numbers are mixed up. |
Nicko Moderator
Posts: 10886 Joined: 05 Nov 2004 Location: SE Melb VIC, Australia
Posted: Tue Jan 25, 2005 11:21 pm Post subject: |
there was nothing with the follwoing requiremnets made was there
Tickford 6 Cylinder EL (dizzy rather than coil pack)
Manual
3.45 diff
With ghia features, Speed sensitive power steering, climate etc?
is there any tweecer support yet to flash these bastards so i can get exactly what i want? |
Posted: Thu Jan 27, 2005 8:36 am Post subject: |
BTW most non-XR8 EF V8's (V8 Futura, V8 monty etc.) have a 4DED catch code.
Nick - NO EF/EL ECU supported by tweecer yet... and you should know by now it doesnt flash anything  |
