HELP...My EL is not starting/shiffting properly...
97GLIWAGON
PostPosted: Wed Jul 09, 2008 7:39 am    Post subject: HELP...My EL is not starting/shiffting properly... Reply with quote
My 97 EL Wagon isn't starting properly sometimes. It will crank but won't turn over there is a batt symbol when im trying to start but it's brand new battery and i had it tested and the reading is fine.
Also when driving it won't shift out of 1st sometimes or get's stuck in 2nd. It will then keep up high revs and won't change. If i stomp it a bit it'll then sometimes change.
Also when idling in P or N it will rev up and down between 800-950.
This all started after i degreased the enigne bay the other day with high pressure water. I covered up the distributor with a plastic bag so no water got to it at all. I was careful where i was spraying the water as well.
Can anyone explain what is going on?
Cheers,
Simon
97GLIWAGON
PostPosted: Wed Jul 09, 2008 10:49 pm    Post subject: Reply with quote
So the idling has settled down. But the auto is still playing up heaps...Any suggestion's?
Id like to try and give this a go before i take it to an Auto Elect.
roobin
PostPosted: Thu Jul 10, 2008 9:02 pm    Post subject: Re: HELP...My EL is not starting/shiffting properly... Reply with quote
Cheers,
Simon
Had the same problem with my old XD after degreasing the enging bay.
Found out everything was worn out.
Replaced the lot and all okay.
motortronics
PostPosted: Thu Jul 10, 2008 9:33 pm    Post subject: Re: HELP...My EL is not starting/shiffting properly... Reply with quote
Cheers.
Simon
Hello Simon, I am not a mechanic and don't pretend to be but from past experience there is a solenoid that controls the auto changing. Before you do anything drastic see a mechanic, it may only be the solenoid. Also the battery symbol, is that the light that goes out when the engine starts? If so it is fine for it to show while you are cranking the engine,and doesn't mean there is anything wrong with the battery. If it doesn't go out after the engine starts it is more likely to be the alternator. The hard to start bit could be any number of things.
Regards,
Noel
nvk-351
PostPosted: Thu Jul 10, 2008 10:43 pm    Post subject: Reply with quote
Convert it to manual
I did and im not looking back
97GLIWAGON
PostPosted: Sat Jul 12, 2008 1:23 am    Post subject: Re: HELP...My EL is not starting/shiffting properly... Reply with quote
When u say replaced everything what do u mean?
97GLIWAGON
PostPosted: Mon Jul 14, 2008 8:43 am    Post subject: Reply with quote
More help please!
97GLIWAGON
PostPosted: Tue Jul 15, 2008 1:13 pm    Post subject: Reply with quote
Had it checked out on the transmisson scanner, result was TBS located on the throttle body. It's the little black switch on the T/B when u look at it.
Going to fit one my self and see how it goes...Should resolve the problem.
WagonDad
View User Gallery (19)
PostPosted: Tue Jul 15, 2008 10:06 pm    Post subject: Reply with quote
Before you buy the new TPS (throttle position sensor) check the voltage at the TPS, refer to the TPS and Base idle sticky in the V8 forum. My car wasn't starting properly, winding over a few times before firing up. Turns out when you adjust the base idle up to help with a bigger cam you need to adjust the TPS to get the correct voltage. I had to file out the locating holes to adjust the TPS, the V8's already have elongated holes.
97GLIWAGON
PostPosted: Tue Jul 15, 2008 10:43 pm    Post subject: Reply with quote
I got the TPS for free!
97GLIWAGON
PostPosted: Tue Jul 15, 2008 10:44 pm    Post subject: Reply with quote
Has solved the problem! Perfect now!
[38 queries :: 0.04904 seconds ]
