muirs2004 Fordmods Newbie
Posts: 6 Joined: 23 Sep 2007 Location: dunedin New Zealand
Posted: Wed Oct 03, 2007 10:26 pm Post subject: HELP PLEASE |
I have a au11 on stright gas and it wont start,it fires,but wont run,as said it fires up but then wont run,does anyone have any ideas want might cause this??Could the smart lock key do this?As i read in my hand book if key is wrong it would do this.But its the same key i have always had,Can it lose its code??Any help would be great. |
Disco Frank Fordmods Junkie
Age:29 Posts: 13770 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Thu Oct 04, 2007 8:55 pm Post subject: |
the code will not get lost from the key!
if your key is wrong the key would either
a, not fit
b,wont turn the engine
i would take the car to a lpg mech
as it sounds like not enough gas is been sent to the engine
is the tank full? |
impraven Fordmods Parts Gopher
Posts: 79 Joined: 08 May 2007 Location: Brisvegas QLD, Australia
Posted: Wed Oct 17, 2007 6:57 am Post subject: |
| Yeah i second that, get a pro to have a look at it, chances are he will be able to work it out quickly and you wont blow yourself up! |
harddriver Fordmods Stock as a Rock
Age:33 Posts: 141 Joined: 08 Apr 2007 Location: Sth Australia SA, Australia
Posted: Thu Oct 18, 2007 8:07 pm Post subject: |
| make sure all your lpg solanoids r clicking and staying on |
brad17djr Fordmods Stock as a Rock
Age:20 Posts: 109 Joined: 05 Sep 2007 Location: blue mountains/Oakhurst NSW, Australia
Posted: Thu Oct 18, 2007 8:58 pm Post subject: |
| clean out ur idler jet and clean ur throttle body it's probly blocked with gum if not make shure ur solanoids arn't cracked i work at ford and thats whatmost of the problems relate too |
LPGUTE Fordmods Oompa Loompa
Age:18 Posts: 25 Joined: 11 Aug 2007 Location: Parramatta NSW, Australia
Posted: Fri Oct 19, 2007 6:51 pm Post subject: |
| i had a similar problem, it maybe the gas converter. take it to a LPG mech |
