Help reading dyno graph
Swine
PostPosted: Fri Aug 03, 2007 8:25 pm    Post subject: Help reading dyno graph Reply with quote
Are the figures on the right of the graph torque readings? If so can they be converted to Nm torque?.
Swine
PostPosted: Fri Aug 03, 2007 8:27 pm    Post subject: Reply with quote
dang
schnoods
PostPosted: Fri Aug 03, 2007 8:44 pm    Post subject: Reply with quote
They bottom3 lines looks like the torque curve, but the axis on the right doesnt look right, as if it has one too many numbers to be NM.
Swine
PostPosted: Fri Aug 03, 2007 9:02 pm    Post subject: Reply with quote
Yeah thats my problem what kcuf is the N reading
Jim Beam
PostPosted: Fri Aug 03, 2007 10:41 pm    Post subject: Reply with quote
Newtons and newtons metres are like centremetres and metres.
Swine
PostPosted: Sat Aug 04, 2007 9:03 am    Post subject: Reply with quote
So does mean its got 687nm of torque then.
Casper
PostPosted: Sat Aug 04, 2007 10:14 am    Post subject: Reply with quote
No, those numbers represent "tractive effort". There is no way to accurately convert them to Nm.
schnoods
PostPosted: Sat Aug 04, 2007 12:41 pm    Post subject: Reply with quote
Going by the bottom green line you have 465 nm. the top 3 lines are the power curve and the bottom 3 lines are the torque curve. Considering it had 400 stock its a pretty good effort.
smiley235
PostPosted: Sat Aug 04, 2007 2:35 pm    Post subject: Reply with quote
No they're not. 1 metre is 100 cm.
A newton is a measurement of force required to accelerate 1 kg at 1ms^2. so thats kg.m/s^2
Whereas a newton metre value is the actual force exerted through that metre.
NM isn't simply a scaled down unit of Newton.
Jim Beam
PostPosted: Sat Aug 04, 2007 4:06 pm    Post subject: Reply with quote
I probably should have payed more attention in physics then
Swine
PostPosted: Sat Aug 04, 2007 4:43 pm    Post subject: Reply with quote
Ill just go back and get a graph showing Nm then.
[38 queries :: 0.05321 seconds ]
