dmangion Fordmods Newbie
Posts: 2 Joined: 21 Oct 2007 Location: Albury NSW, Australia
Posted: Sun Oct 21, 2007 8:45 pm Post subject: HELP - Replacing a front indicator EF |
I'm hoping someone out there can help me.
I am a GIRL and don't know an awful lot about cars but I need to replace my front driver's indicator (someone hit me in a car park) and I really don't want to pay a mechanic to do it. I figure that if I can build a house I can replace an indicator.
I have purchased a new unit from ebay and had a quick look under the bonnet today but couldn't immediately see how to unscrew the indicator. Can anyone tell me (preferably step-by-step) how to go about replacing it?
I also had look in the technical documents but can't seem to find the right topic.
And no, I'm not blonde. |
Age:24 Posts: 3570 Joined: 13 Mar 2006 Location: Dubbo NSW, Australia
Posted: Sun Oct 21, 2007 9:22 pm Post subject: |
Corner Light
1) Unscrew the Screw on top of the light.
2) Gently BUT Firmly hit the light towards the front of the car and it should pop/slide out of it's holder
3) Turn the bulb holder anti-clockwise and pull
4) Ditch the f**k light
5) put the plug in and turn clockwise
6) slide\pop the light into the hole
7) rescrew the screw in and there ya go
Repeator / Flasher
1) get a flat screw driver slide underneath the flasher
2) turn plug anti-clockwise and pull
3) put plug in new repeator turn clockwise
4) slide the flasher in until it clicks.
Cheers Geoff |
Posted: Mon Oct 22, 2007 1:57 pm Post subject: |
Thanks Geoff,
You're a star! I'll put your instructions to use straight after work.
Donna |
revcore Fordmods - Getting Side Ways
Age:32 Posts: 2637 Joined: 05 Nov 2004 Location: Bairnsdale VIC, Australia
Posted: Mon Oct 22, 2007 2:02 pm Post subject: |
| Hi Donna, Welcome to fordmods. |
Sommers NL Fordmods Stock as a Rock
Age:29 Posts: 143 Joined: 06 Apr 2007 Location: Nundah QLD QLD, Australia
Posted: Tue Oct 23, 2007 7:02 pm Post subject: |
hey im a girl, and worked it out, as above, its not that hard!! one screw (bit hard to see unless you look for it) you might have to remove the plastic that sits on the top around the headlights, any problems PM me,
Sommer |
